Strong APA Scheduler Implementation
Darshit Shah
darnir at gmail.com
Wed Jun 29 09:56:58 UTC 2016
Hi,
For the strong APA scheduler, I have added support for storing affinity
sets to the Thread node structure. This code was mostly borrowed from
the existing code in the priority affinity SMP scheduler. Currently, it
was copied, but it should be possible to simply reuse the entire code as
well. I'm not sure what the preferred method would be. I've pushed this
code to my GitHub repository[1] under the branch strongapa.
When implementing the scheduler, I'd like to be able to run the existing
tests in the testsuite, such as the smpschedaffinity* tests and others.
However, most of these tests explicitly use the
PRIORITY_AFFINITY_SMP_SCHEDULER in the test itself. I ported one test by
copying it and changing the scheduler to STRONG_APA_SCHEDULER, but I was
wondering if there would be an easier way to run all the tests without
having to copy them first. A global declaration that I can use somewhere
to compile all the tests with a particular scheduler. That would make
testing very easy.
Next, I wanted to discuss the actual implementation of the scheduler.
First, I'll explain my understanding of the scheduler's internal
working, so if there's a flaw there, it can be caught early on.
When a new task is created, a new thread node is created for it. Task
arrival is signalled by the rtems_task_start() method which will invoke
the Unblock operation in the scheduler for that thread node. It is
during this unblock operation that we need to decide whether this task
can be immediately scheduled or not. And if it is scheduled, on which
processor should it execute. These decisions are made independently. The
unblock operation will invoke the enqueue_fifo operation which tries to
push the task to the end of the ready queue. The enqueue_fifo operation
tries to get the "lowest_scheduled" task, which is basically the victim
task that must be descheduled to allow for the new task to be executed.
The _Scheduler_SMP_Allocate_processor_lazy() method then tries to
context switch the threads on the processor on which the victim thread
was executing.
However, none of this allows for shifting of tasks. That is, trying to
see if the victim thread that was descheduled, can be rescheduled on
another processor by replacing a lower priority task. Could this be done
by calling the Unblock() operation in the victim thread during the
allocate_processor operation?
Now, the main question that I face when trying to implement the
scheduler. As I understand, the scheduler operations try to find the
victim thread and then replace it with the newly arrived task. However,
for the strong APA scheduler, we may need to shift a few tasks around
for the most optimum scheduling decision. And these shifts cannot be
computed iteratively. That is, we cannot simply invoke the Unblock()
operation on the victim thread as I suggested earlier. The entire
mapping of tasks to processors will be generated together. So, where
exactly should I implement this algorithm? Because it doesn't seem like
it can be easily split into the logical sections of get_lowest_scheduled
and allocate_processor that the existing algorithms use.
[1]: https://github.com/darnir/rtems
Thanking You,
Darshit Shah
Type: application/pgp-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160629/ed1a293c/attachment.bin>
