Strong APA Scheduler Implementation
Thu Jun 30 08:07:52 UTC 2016
Hello Darshit,
I update the smpstrongapa01 test to use table driven test actions to
carry out test cases:
https://git.rtems.org/rtems/tree/testsuites/smptests/smpstrongapa01/init.c#n103
This should be enough to thoroughly test this scheduler. You can run the
test via:
qemu-system-arm -no-reboot -net none -nographic -M realview-pbx-a9 -m
256M -smp 4 -icount 8 -kernel smpstrongapa01.exe
Please update the ticket
https://devel.rtems.org/ticket/2510
as soon as possible with your ideas with respect to
* the data structures, e.g. per thread Scheduler_strong_APA_Node and per
scheduler instance Scheduler_strong_APA_Context,
* the algorithms to block and unblock a thread, and
* test scenarios.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
