[PATCH 1/2] Subject: Add original BBBIO PWM driver to BBB BSP
Punit Vara punitvara at gmail.com
Thu Jun 30 11:57:42 UTC 2016
	This patch perform following things:
        - adds original BBBIO PWM code as it is.
        - not added to Makefile otherwise it will break build
        This code is added from
        https://github.com/VegetableAvenger/BBBIOlib/blob/master/BBBio_lib/BBBiolib_PWMSS.c
 c/src/lib/libbsp/arm/beagle/include/bbb-pwm.h |  41 +++
 c/src/lib/libbsp/arm/beagle/pwm/pwm.c         | 407 ++++++++++++++++++++++++++
 2 files changed, 448 insertions(+)
 create mode 100644 c/src/lib/libbsp/arm/beagle/include/bbb-pwm.h
 create mode 100644 c/src/lib/libbsp/arm/beagle/pwm/pwm.c
diff --git a/c/src/lib/libbsp/arm/beagle/include/bbb-pwm.h b/c/src/lib/libbsp/arm/beagle/include/bbb-pwm.h
new file mode 100644
index 0000000..761eae2
--- /dev/null
+++ b/c/src/lib/libbsp/arm/beagle/include/bbb-pwm.h
@@ -0,0 +1,41 @@
+#ifndef LIBBSP_ARM_BEAGLE_BBB_PWM_H
+#define LIBBSP_ARM_BEAGLE_BBB_PWM_H
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ * @brief  BeagleBone Black PWM Macros.
+#define BBBIO_PWMSS_COUNT       3
+#define BBBIO_PWMSS0           0
+#define BBBIO_PWMSS1           1
+#define BBBIO_PWMSS2           2
+#define MUXMODE0               0
+#define MUXMODE1                1
+#define MUXMODE2               2
+#define MUXMODE3               3
+#define MUXMODE4               4
+#define MUXMODE5               5
+#define MUXMODE6               6
+#define MUXMODE7               7
+#define EPWM_GROUP1    1
+#define EPWM_GROUP2    2
+#define EPWM_GROUP0    0
+int BBBIO_PWMSS_Setting(unsigned int PWMID , float HZ ,float dutyA ,float dutyB);
+int BBBIO_PWM_Init();
+void BBBIO_PWM_Release();
+int BBBIO_PWMSS_Status(unsigned int PWMID);
+void BBBIO_ehrPWM_Enable(unsigned int PWMSS_ID);
+void BBBIO_ehrPWM_Disable(unsigned int PWMSS_ID);
+#ifdef __cplusplus
+#endif /* LIBBSP_ARM_BEAGLE_BBB_PWM_H */
diff --git a/c/src/lib/libbsp/arm/beagle/pwm/pwm.c b/c/src/lib/libbsp/arm/beagle/pwm/pwm.c
index 0000000..f65ff89
--- /dev/null
+++ b/c/src/lib/libbsp/arm/beagle/pwm/pwm.c
@@ -0,0 +1,407 @@
+#include <stdio.h>
+#include <stdlib.h>
+#include <sys/mman.h>
+#include <sys/stat.h>
+#include <fcntl.h>
+#include <errno.h>
+#include <time.h>
+#include "BBBiolib.h"
+ * PWMSS Registers
+ * @Source : AM335x Technical Reference Manual ,page 1991
+ *           Table 15-5. PWMSS REGISTERS
+#define PWMSS0_MMAP_ADDR	0x48300000
+#define PWMSS1_MMAP_ADDR	0x48302000
+#define PWMSS2_MMAP_ADDR	0x48304000
+#define PWMSS_MMAP_LEN		0x1000
+#define PWMSS_IDVER	0x0
+#define PWMSS_SYSCONFIG	0x4
+#define PWMSS_CLKCONFIG	0x8
+#define PWMSS_CLKSTATUS	0xC
+/* EPWM Registers
+ * @Source : AM335x Technical Reference Manual ,page 2084
+ *           Table 15-58. EPWM REGISTERS
+#define EPWM_TBCTL	0x0
+#define EPWM_TBSTS	0x2
+#define EPWM_TBPHSHR	0x4
+#define EPWM_TBPHS	0x6
+#define EPWM_TBCNT	0x8
+#define EPWM_TBPRD	0xA
+#define EPWM_CMPCTL	0xE
+#define EPWM_CMPAHR	0x10
+#define EPWM_CMPA	0x12
+#define EPWM_CMPB	0x14
+#define EPWM_AQCTLA	0x16
+#define EPWM_AQCTLB	0x18
+#define EPWM_AQSFRC	0x1A
+#define EPWM_AQCSFRC	0x1C
+#define EPWM_DBCTL	0x1E
+#define EPWM_DBRED	0x20
+#define EPWM_DBFED	0x22
+extern int memh;
+extern volatile unsigned int *CM_ptr;	/*c ontrol module */
+volatile unsigned int *cm_per_addr;
+const unsigned int PWMSS_AddressOffset[]={PWMSS0_MMAP_ADDR,
+					  PWMSS1_MMAP_ADDR,
+					  PWMSS2_MMAP_ADDR};
+volatile unsigned int *pwmss_ptr[3]     ={NULL, NULL, NULL} ;
+volatile unsigned int *epwm_ptr[3]      ={NULL, NULL, NULL} ;
+volatile unsigned int *ecap_ptr[3]      ={NULL, NULL, NULL} ;
+volatile unsigned int *eqep_ptr[3]      ={NULL, NULL, NULL} ;
+#define TBCTL_CTRMODE_UP        0x0
+#define TBCTL_CTRMODE_DOWN      0x1
+#define TBCTL_CTRMODE_UPDOWN    0x2
+#define TBCTL_CTRMODE_FREEZE    0x3
+/* PWMSS Timebase clock check
+ * 	check the timenase clock enable or not
+ *	@param PWMSS_ID :  PWM sumsystem ID (BBBIO_PWMSS0 ,BBBIO_PWMSS1, BBBIO_PWMSS2)
+ *	@return : 0 for disable timebase clock , 1 for enable for timebase clock
+static int PWMSS_TB_clock_check(unsigned int PWMSS_ID)
+	volatile unsigned int* reg;
+	unsigned int reg_value ;
+	/* Control module check */
+	reg =(void *)CM_ptr + BBBIO_PWMSS_CTRL;
+	reg_value = *reg ;
+	return (reg_value & (1 << PWMSS_ID)) ;
+/* PWM subsystem system control
+ * 	enable or disable module clock
+ *	@param PWMSS_ID :  PWM sumsystem ID (BBBIO_PWMSS0 ,BBBIO_PWMSS1, BBBIO_PWMSS2).
+ *	@param enable : 0 for disable , else for enable .
+ *	@return : 1 for success ,  0 for error
+static int PWMSS_module_ctrl(unsigned int PWMSS_ID, int enable)
+	volatile unsigned int *reg = NULL;
+	unsigned int module_set[] = {BBBIO_PWMSS0, BBBIO_PWMSS1, BBBIO_PWMSS2};
+	unsigned int module_clk_set[] = {BBBIO_CM_PER_EPWMSS0_CLKCTRL, BBBIO_CM_PER_EPWMSS1_CLKCTRL, BBBIO_CM_PER_EPWMSS2_CLKCTRL};
+	int ret = 1;
+	reg = (void*)cm_per_addr + module_clk_set[PWMSS_ID];
+	if(enable) {
+		if(PWMSS_TB_clock_check(module_set[PWMSS_ID])) {
+			/* Enable module clock */
+			*reg = 0x2;	/* Module enable and fully functional */
+			return ret;
+#ifdef BBBIO_LIB_DBG
+		else {
+			printf("PWMSS_module_ctrl : PWMSS-%d timebase clock disable in Control Module\n", PWMSS_ID);
+#endif
+		ret = 0 ;
+	*reg = 0x3 << 16;	/* Module is disabled and cannot be accessed */
+	return ret;
+/* PWM init
+ *	iolib_init will run this function automatically
+ *      @return         : 1 for success , 0 for failed
+	int i = 0;
+	if (memh == 0) {
+		printf("BBBIO_PWM_Init: memory not mapped?\n");
+#endif
+		return 0;
+	/* Create Memory map */
+	for (i = 0 ; i < 3 ; i ++) {
+		pwmss_ptr[i] = mmap(0, PWMSS_MMAP_LEN, PROT_READ | PROT_WRITE, MAP_SHARED, memh, PWMSS_AddressOffset[i]);
+		if(pwmss_ptr[i] == MAP_FAILED) {
+			printf("BBBIO_PWM_Init: PWMSS %d mmap failure!\n", i);
+#endif
+			goto INIT_ERROR ;
+		ecap_ptr[i] = (void *)pwmss_ptr[i] + 0x100 ;
+		eqep_ptr[i] = (void *)pwmss_ptr[i] + 0x180 ;
+		epwm_ptr[i] = (void *)pwmss_ptr[i] + 0x200 ;
+		if(!PWMSS_module_ctrl(i, 1)) {
+			printf("BBBIO_PWM_Init: PWMSS %d clock  failure!\n", i);
+#endif
+			goto INIT_ERROR ;
+	return 1;
+INIT_ERROR :
+	BBBIO_PWM_Release();
+	return 0;
+	int i = 0;
+	for(i = 0 ; i < 3 ; i ++) {
+		if(pwmss_ptr[i] != NULL) {
+			munmap((void *)pwmss_ptr[i], PWMSS_MMAP_LEN);
+			pwmss_ptr[i] = NULL;
+			ecap_ptr[i] = NULL;
+			eqep_ptr[i] = NULL;
+			epwm_ptr[i] = NULL;
+/* PWMSS status (no effect now)
+ * 	set pluse rgument of epwm module
+ *      @param PWMID    : EPWMSS number , 0~3
+	int param_error = 1;
+	if (memh == 0)
+            param_error = 0;
+    	if (PWMID > 2)		/* if input is not EPWMSS 0~ WPEMSS 2 */
+            param_error = 0;
+    	if (param_error == 0) {
+		printf("BBBIO_PWM_Status: parameter error!\n");
+#endif
+		return 0;
+	reg_value = *reg >> PWMID & 0x01 ;
+	if(reg_value == 0) {
+		printf("PWMSS [%d] Timebase clock Disable , Control Module [pwmss_ctrl register]\n", PWMID);
+	else {
+		reg=(void *)pwmss_ptr[PWMID] + PWMSS_CLKSTATUS;
+		printf("PWMSS [%d] :\tCLKSTOP_ACK %d , CLK_EN_ACK %d , CLKSTOP_ACK %d , CLK_EN_ACK %d , CLKSTOP_ACK %d , CLK_EN_ACK %d\n",
+			PWMID ,
+			reg_value >>9 & 0x1 ,
+			reg_value >>8 & 0x1 ,
+			reg_value >>5 & 0x1 ,
+			reg_value >>4 & 0x1 ,
+			reg_value >>1 & 0x1 ,
+			reg_value >>0 & 0x1 );
+	return 1 ;
+/* PWMSS setting
+ *      @param PWMID    : EPWMSS number , 0~2
+ *      @param HZ    	: pluse HZ
+ *      @param dutyA    : Duty Cycle in ePWM A
+ *      @param dutyB    : Duty Cycle in ePWM B
+ *      @example        :  BBBIO_PWMSS_Setting(0 , 50.0f , 50.0f , 25.0f); 	// Generate 50HZ pwm in PWM0 ,
+ *										// duty cycle is 50% for ePWM0A , 25% for ePWM0B
+ * 	@Note :
+ * 		find an number nearst 65535 for TBPRD , to improve duty precision,
+ *		Using big TBPRD can increase the range of CMPA and CMPB ,
+ * 		and it means we can get better precision on duty cycle.
+ *		EX : 20.25% duty cycle
+ *                  on TBPRD = 62500 , CMPA = 12656.25 ( .25 rejection) , real duty : 20.2496% (12656 /62500)
+ *                  on TBPRD = 6250  , CMPA = 1265.625 ( .625 rejection), real duty : 20.24%   (1265 6250)
+ *                  on TBPRD = 500   , CMPA = 101.25   ( .25 rejection) , real duty : 20.2%    (101/500)
+ *		Divisor = CLKDIV * HSPCLKDIV
+ *     			1 TBPRD : 10 ns (default)
+ *			65535 TBPRD : 655350 ns
+ *			65535 TBPRD : 655350 * Divisor ns  = X TBPRD : Cyclens
+ * 		accrooding to that , we must find a Divisor value , let X nearest 65535 .
+ * 		so , Divisor must  Nearest Cyclens/655350
+	volatile unsigned short* reg16 ;
+        if (memh == 0)
+            param_error = 0;
+        if (PWMID > 2)              // if input is not EPWMSS 0~ WPEMSS 2
+            param_error = 0;
+	if (HZ < 0 )
+	    param_error = 0;
+	if(dutyA < 0.0f || dutyA > 100.0f || dutyB < 0.0f || dutyB > 100.0f)
+	    param_error = 0;
+		printf("BBBIO_PWMSS_Setting: parameter error!\n");
+#endif
+		return 0;
+	dutyA /= 100.0f ;
+	dutyB /= 100.0f ;
+	/* compute neccessary TBPRD */
+	float Cyclens =0.0f ;
+	float Divisor =0;
+	int i , j ;
+	const float CLKDIV_div[] = {1.0 ,2.0 ,4.0 ,8.0 ,16.0 ,32.0 , 64.0 , 128.0};
+	const float HSPCLKDIV_div[] ={1.0 ,2.0 ,4.0 ,6.0 ,8.0 ,10.0 , 12.0 , 14.0};
+	int NearCLKDIV =7;
+	int NearHSPCLKDIV =7;
+	int NearTBPRD =0;
+	Cyclens = 1000000000.0f / HZ ; /* 10^9 / HZ , comput time per cycle (ns) */
+	Divisor =  (Cyclens / 655350.0f) ;	/* am335x provide (128*14) divider , and per TBPRD means 10 ns when divider /1 ,
+						 * and max TBPRD is 65535 , so , the max cycle is 128*14* 65535 *10ns
+	printf("Cyclens %f , Divisor %f\n", Cyclens, Divisor);
+#endif
+	if(Divisor > (128 * 14)) {
+		printf("BBBIO_PWMSS_Setting : Can't generate %f HZ \n", HZ);
+#endif
+		return 0;
+	else {
+		/* using Exhaustive Attack metho */
+		for(i = 0 ; i < 8 ; i ++) {
+			for(j = 0 ; j < 8 ; j ++) {
+				if((CLKDIV_div[i] * HSPCLKDIV_div[j]) < (CLKDIV_div[NearCLKDIV] * HSPCLKDIV_div[NearHSPCLKDIV]) &&
+				  ((CLKDIV_div[i] * HSPCLKDIV_div[j]) > Divisor)) {
+					NearCLKDIV = i ;
+					NearHSPCLKDIV = j ;
+		printf("nearest CLKDIV %f , HSPCLKDIV %f\n" ,CLKDIV_div[NearCLKDIV] ,HSPCLKDIV_div[NearHSPCLKDIV]);
+#endif
+		NearTBPRD = (Cyclens / (10.0 *CLKDIV_div[NearCLKDIV] *HSPCLKDIV_div[NearHSPCLKDIV])) ;
+		printf("nearest TBPRD %d, %f %f\n ",NearTBPRD,NearTBPRD * dutyA, NearTBPRD * dutyB);
+#endif
+		/* setting clock diver and freeze time base */
+		reg16=(void*)epwm_ptr[PWMID] +EPWM_TBCTL;
+		*reg16 = TBCTL_CTRMODE_FREEZE | (NearCLKDIV << 10) | (NearHSPCLKDIV << 7);
+		/*  setting duty A and duty B */
+		reg16=(void*)epwm_ptr[PWMID] +EPWM_CMPB;
+		*reg16 =(unsigned short)((float)NearTBPRD * dutyB);
+		reg16=(void*)epwm_ptr[PWMID] +EPWM_CMPA;
+		*reg16 =(unsigned short)((float)NearTBPRD * dutyA);
+		reg16=(void*)epwm_ptr[PWMID] +EPWM_TBPRD;
+		*reg16 =(unsigned short)NearTBPRD;
+		/* reset time base counter */
+		reg16 = (void *)epwm_ptr[PWMID] + EPWM_TBCNT;
+		*reg16 = 0;
+	return 1;
+/* Enable/Disable ehrPWM module
+ *      @param PWMID    : PWMSS number , 0~2
+ *      @return         : void
+ *      @example        : BBBIO_PWMSS_Enable(0) ;// Enable PWMSS 0
+	volatile unsigned short *reg16 ;
+	reg16=(void*)epwm_ptr[PWMSS_ID] +EPWM_AQCTLA;
+	*reg16 = 0x2 | ( 0x3 << 4) ;
+	reg16=(void*)epwm_ptr[PWMSS_ID] +EPWM_AQCTLB;
+	*reg16 = 0x2 | ( 0x3 << 8) ;
+	reg16 = (void *)epwm_ptr[PWMSS_ID] + EPWM_TBCNT;
+	*reg16 = 0;
+        reg16=(void *)epwm_ptr[PWMSS_ID] + EPWM_TBCTL;
+	*reg16 &= ~0x3;
+        *reg16 |= 0x3;
+	*reg16 = 0x1 | ( 0x3 << 4) ;
+	*reg16 = 0x1 | ( 0x3 << 8) ;
+	*reg16 = 0;
2.7.1
