[PATCH 2/2] Subject: Update PWM driver imported from BBBIO
Punit Vara punitvara at gmail.com
Thu Jun 30 11:58:11 UTC 2016
        This patch performs following things:
            - adds registers to appropriate header file
            - Changes APIs to build RTEMS successful
            I have tested PWM driver with RGB LED and multimeter
            https://youtu.be/jhjZO9amdSA
            This code generate more accurate frequency compare to TI SW code.
            There is licence issue with TISW as well. So BBBIO code has been added from
            https://github.com/VegetableAvenger/BBBIOlib/blob/master/BBBio_lib/BBBiolib_PWMSS.c
 c/src/lib/libbsp/arm/beagle/Makefile.am       |   4 +
 c/src/lib/libbsp/arm/beagle/include/bbb-pwm.h | 155 +++++-
 c/src/lib/libbsp/arm/beagle/preinstall.am     |   4 +
 c/src/lib/libbsp/arm/beagle/pwm/pwm.c         | 772 ++++++++++++++------------
 c/src/lib/libcpu/arm/shared/include/am335x.h  |  97 +++-
 5 files changed, 657 insertions(+), 375 deletions(-)
diff --git a/c/src/lib/libbsp/arm/beagle/Makefile.am b/c/src/lib/libbsp/arm/beagle/Makefile.am
index 20d3092..bf9a909 100644
--- a/c/src/lib/libbsp/arm/beagle/Makefile.am
+++ b/c/src/lib/libbsp/arm/beagle/Makefile.am
@@ -41,6 +41,7 @@ include_bsp_HEADERS += include/irq.h
 include_bsp_HEADERS += include/i2c.h
 include_bsp_HEADERS += include/beagleboneblack.h
 include_bsp_HEADERS += include/bbb-gpio.h
+include_bsp_HEADERS += include/bbb-pwm.h
 include_libcpu_HEADERS =
 include_libcpu_HEADERS += ../../../libcpu/arm/shared/include/arm-cp15.h
@@ -117,6 +118,9 @@ libbsp_a_SOURCES += misc/i2c.c
 # GPIO
 libbsp_a_SOURCES += gpio/bbb-gpio.c
+#pwm
+libbsp_a_SOURCES += pwm/pwm.c
 #RTC
 libbsp_a_SOURCES += rtc.c
 libbsp_a_SOURCES += ../../shared/tod.c
diff --git a/c/src/lib/libbsp/arm/beagle/include/bbb-pwm.h b/c/src/lib/libbsp/arm/beagle/include/bbb-pwm.h
index 761eae2..6eb6fcb 100644
--- a/c/src/lib/libbsp/arm/beagle/include/bbb-pwm.h
+++ b/c/src/lib/libbsp/arm/beagle/include/bbb-pwm.h
@@ -1,3 +1,23 @@
+ * @file
+ * @ingroup arm_beagle
+ * @brief BeagleBone Black BSP definitions.
+ * Copyright (c) 2016 Punit Vara <punitvara at gmail.com>
+/** Some constants are taken from
+ * https://github.com/VegetableAvenger/BBBIOlib/blob/master/BBBio_lib/BBBiolib_PWMSS.h
 #ifndef LIBBSP_ARM_BEAGLE_BBB_PWM_H
 #define LIBBSP_ARM_BEAGLE_BBB_PWM_H
@@ -8,31 +28,118 @@ extern "C" {
  * @brief  BeagleBone Black PWM Macros.
-#define BBBIO_PWMSS_COUNT       3
-#define BBBIO_PWMSS0           0
-#define BBBIO_PWMSS1           1
-#define BBBIO_PWMSS2           2
-#define MUXMODE0               0
-#define MUXMODE1                1
-#define MUXMODE2               2
-#define MUXMODE3               3
-#define MUXMODE4               4
-#define MUXMODE5               5
-#define MUXMODE6               6
-#define MUXMODE7               7
-#define EPWM_GROUP1    1
-#define EPWM_GROUP2    2
-#define EPWM_GROUP0    0
-int BBBIO_PWMSS_Setting(unsigned int PWMID , float HZ ,float dutyA ,float dutyB);
-int BBBIO_PWM_Init();
-void BBBIO_PWM_Release();
-int BBBIO_PWMSS_Status(unsigned int PWMID);
-void BBBIO_ehrPWM_Enable(unsigned int PWMSS_ID);
-void BBBIO_ehrPWM_Disable(unsigned int PWMSS_ID);
+#define BBB_CONTROL_CONF_GPMC_AD(n)   (0x800 + (n * 4))
+#define BBB_CONTROL_CONF_LCD_DATA(n)   (0x8a0 + (n * 4))
+#define BBB_PWMSS_COUNT       3
+#define BBB_PWMSS0  0
+#define BBB_PWMSS1  1
+#define BBB_PWMSS2  2
+#define BBB_P8_13_2B  3
+#define BBB_P8_19_2A  4
+#define BBB_P8_45_2A  5
+#define BBB_P8_46_2B  6
+#define BBB_P8_34_1B  7
+#define BBB_P8_36_1A  8
+#define BBB_P9_14_1A  9
+#define BBB_P9_16_1B  10
+#define BBB_P9_21_0B  11
+#define BBB_P9_22_0A  12
+#define BBB_P9_29_0B  13
+#define BBB_P9_31_0A  14
+#define BBB_MUX0      0
+#define BBB_MUX1      1
+#define BBB_MUX2      2
+#define BBB_MUX3      3
+#define BBB_MUX4      4
+#define BBB_MUX5      5
+#define BBB_MUX6      6
+#define BBB_MUX7      7
+#define BBB_EPWM1     1
+#define BBB_EPWM2     2
+#define BBB_EPWM0     0
+ * @brief  BeagleBone Black PWM API.
+ * @brief This function intilize clock and pinmuxing for pwm sub system.
+ * @param PWMSS_ID It is the instance number of EPWM of pwm sub system.
+ * @return true if successful
+bool beagle_pwm_init(uint32_t pwmss_id);
+/* PWMSS setting
+ *      set pulse argument of epwm module
+ *      @param pwm_id    : EPWMSS number , 0~2
+ *      @param pwm_freq : frequency to be generated
+ *      @param dutyA    : Duty Cycle in ePWM A
+ *      @param dutyB    : Duty Cycle in ePWM B
+ *      @return         : 1 for success , 0 for failed
+ *      @example        :  PWMSS_Setting(0 , 50.0f , 50.0f , 25.0f);      // Generate 50HZ pwm in PWM0 ,
+ *        // duty cycle is 50% for ePWM0A , 25% for ePWM0B
+ *      @Note :
+ *              find an number nearst 65535 for TBPRD , to improve duty precision,
+ *              Using big TBPRD can increase the range of CMPA and CMPB ,
+ *              and it means we can get better precision on duty cycle.
+ *              EX : 20.25% duty cycle
+ *                  on TBPRD = 62500 , CMPA = 12656.25 ( .25 rejection) , real duty : 20.2496% (12656 /62500)
+ *                  on TBPRD = 6250  , CMPA = 1265.625 ( .625 rejection), real duty : 20.24%   (1265 6250)
+ *                  on TBPRD = 500   , CMPA = 101.25   ( .25 rejection) , real duty : 20.2%    (101/500)
+ *              Divisor = CLKDIV * HSPCLKDIV
+ *                      1 TBPRD : 10 ns (default)
+ *                      65535 TBPRD : 655350 ns
+ *                      65535 TBPRD : 655350 * Divisor ns  = X TBPRD : Cyclens
+ *              accrooding to that , we must find a Divisor value , let X nearest 65535 .
+ *              so , Divisor must  Nearest Cyclens/655350
+int beagle_pwmss_setting(uint32_t pwm_id, float pwm_freq, float dutyA, float dutyB);
+ * @brief   This API enables the particular PWM module.
+ * @param   pwmid  It is the instance number of EPWM of pwm sub system.
+bool beagle_ehrpwm_enable(uint32_t pwmid);
+ * @brief   This API disables the HR sub-module.
+bool beagle_ehrpwm_disable(uint32_t pwmid);
+ * @brief   This function Enables pinmuxing for PWM module.
+ * @param   pin_no  It is individual pin at which freuqency need to be generated.
+ *                  It should be according to pwm sub system.
+ * @param   pwm_id  It is the instance number of EPWM of pwmsubsystem.
+bool beagle_epwm_pinmux_setup(uint32_t pin_no, uint32_t pwm_id);
 #ifdef __cplusplus
diff --git a/c/src/lib/libbsp/arm/beagle/preinstall.am b/c/src/lib/libbsp/arm/beagle/preinstall.am
index 3701a2b..8a7ff8b 100644
--- a/c/src/lib/libbsp/arm/beagle/preinstall.am
+++ b/c/src/lib/libbsp/arm/beagle/preinstall.am
@@ -118,6 +118,10 @@ $(PROJECT_INCLUDE)/bsp/bbb-gpio.h: include/bbb-gpio.h $(PROJECT_INCLUDE)/bsp/$(d
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/bbb-gpio.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/bbb-gpio.h
+$(PROJECT_INCLUDE)/bsp/bbb-pwm.h: include/bbb-pwm.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/bbb-pwm.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/bbb-pwm.h
 $(PROJECT_INCLUDE)/libcpu/arm-cp15.h: ../../../libcpu/arm/shared/include/arm-cp15.h $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/arm-cp15.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/arm-cp15.h
diff --git a/c/src/lib/libbsp/arm/beagle/pwm/pwm.c b/c/src/lib/libbsp/arm/beagle/pwm/pwm.c
index f65ff89..dca7b8c 100644
--- a/c/src/lib/libbsp/arm/beagle/pwm/pwm.c
+++ b/c/src/lib/libbsp/arm/beagle/pwm/pwm.c
@@ -1,407 +1,479 @@
-#include <stdio.h>
-#include <stdlib.h>
-#include <sys/mman.h>
-#include <sys/stat.h>
-#include <fcntl.h>
-#include <errno.h>
-#include <time.h>
-#include "BBBiolib.h"
- * PWMSS Registers
+ * @file
- * @Source : AM335x Technical Reference Manual ,page 1991
- *           Table 15-5. PWMSS REGISTERS
-#define PWMSS0_MMAP_ADDR	0x48300000
-#define PWMSS1_MMAP_ADDR	0x48302000
-#define PWMSS2_MMAP_ADDR	0x48304000
-#define PWMSS_MMAP_LEN		0x1000
-#define PWMSS_IDVER	0x0
-#define PWMSS_SYSCONFIG	0x4
-#define PWMSS_CLKCONFIG	0x8
-#define PWMSS_CLKSTATUS	0xC
+ * @brief Support for PWM for the BeagleBone Black.
-/* EPWM Registers
- * @Source : AM335x Technical Reference Manual ,page 2084
- *           Table 15-58. EPWM REGISTERS
-#define EPWM_TBCTL	0x0
-#define EPWM_TBSTS	0x2
-#define EPWM_TBPHSHR	0x4
-#define EPWM_TBPHS	0x6
-#define EPWM_TBCNT	0x8
-#define EPWM_TBPRD	0xA
-#define EPWM_CMPCTL	0xE
-#define EPWM_CMPAHR	0x10
-#define EPWM_CMPA	0x12
-#define EPWM_CMPB	0x14
-#define EPWM_AQCTLA	0x16
-#define EPWM_AQCTLB	0x18
-#define EPWM_AQSFRC	0x1A
-#define EPWM_AQCSFRC	0x1C
-#define EPWM_DBCTL	0x1E
-#define EPWM_DBRED	0x20
-#define EPWM_DBFED	0x22
-extern int memh;
-extern volatile unsigned int *CM_ptr;	/*c ontrol module */
-volatile unsigned int *cm_per_addr;
-const unsigned int PWMSS_AddressOffset[]={PWMSS0_MMAP_ADDR,
-					  PWMSS1_MMAP_ADDR,
-					  PWMSS2_MMAP_ADDR};
-volatile unsigned int *pwmss_ptr[3]     ={NULL, NULL, NULL} ;
-volatile unsigned int *epwm_ptr[3]      ={NULL, NULL, NULL} ;
-volatile unsigned int *ecap_ptr[3]      ={NULL, NULL, NULL} ;
-volatile unsigned int *eqep_ptr[3]      ={NULL, NULL, NULL} ;
+/** This file is based on
+  * https://github.com/VegetableAvenger/BBBIOlib/blob/master/BBBio_lib/BBBiolib_PWMSS.c
-#define TBCTL_CTRMODE_UP        0x0
-#define TBCTL_CTRMODE_DOWN      0x1
-#define TBCTL_CTRMODE_UPDOWN    0x2
-#define TBCTL_CTRMODE_FREEZE    0x3
-/* PWMSS Timebase clock check
- * 	check the timenase clock enable or not
- *	@param PWMSS_ID :  PWM sumsystem ID (BBBIO_PWMSS0 ,BBBIO_PWMSS1, BBBIO_PWMSS2)
- *	@return : 0 for disable timebase clock , 1 for enable for timebase clock
+#include <libcpu/am335x.h>
+#include <stdio.h>
+#include <bsp/gpio.h>
+#include <bsp/bbb-gpio.h>
+#include <bsp.h>
+#include <bsp/bbb-pwm.h>
+/* Currently these definitions are for BeagleBone Black board only
+ * Later on Beagle-xM board support can be added in this code.
+ * After support gets added if condition should be removed
-static int PWMSS_TB_clock_check(unsigned int PWMSS_ID)
-	volatile unsigned int* reg;
-	unsigned int reg_value ;
-	/* Control module check */
-	reg =(void *)CM_ptr + BBBIO_PWMSS_CTRL;
-	reg_value = *reg ;
+#if IS_AM335X
-	return (reg_value & (1 << PWMSS_ID)) ;
+ * @brief This function select PWM module to be enabled
+ * @param pwm_id It is the instance number of EPWM of pwm sub system.
+ * @return Base Address of respective pwm instant.
+static uint32_t select_pwmss(uint32_t pwm_id)
+uint32_t baseAddr=0;
+   if (pwm_id == BBB_PWMSS0)
+	baseAddr = AM335X_EPWM_0_REGS;
+	return baseAddr;
+   else if (pwm_id == BBB_PWMSS1)
+	baseAddr = AM335X_EPWM_1_REGS;
+	return baseAddr;
+   else if (pwm_id == BBB_PWMSS2)
+	baseAddr = AM335X_EPWM_2_REGS;
+	return baseAddr;
+   else
+	printf("Invalid PWM Id\n");
+	return 0;
-/* PWM subsystem system control
- * 	enable or disable module clock
- *	@param PWMSS_ID :  PWM sumsystem ID (BBBIO_PWMSS0 ,BBBIO_PWMSS1, BBBIO_PWMSS2).
- *	@param enable : 0 for disable , else for enable .
- *	@return : 1 for success ,  0 for error
-static int PWMSS_module_ctrl(unsigned int PWMSS_ID, int enable)
-	volatile unsigned int *reg = NULL;
-	unsigned int module_set[] = {BBBIO_PWMSS0, BBBIO_PWMSS1, BBBIO_PWMSS2};
-	unsigned int module_clk_set[] = {BBBIO_CM_PER_EPWMSS0_CLKCTRL, BBBIO_CM_PER_EPWMSS1_CLKCTRL, BBBIO_CM_PER_EPWMSS2_CLKCTRL};
-	int ret = 1;
-	reg = (void*)cm_per_addr + module_clk_set[PWMSS_ID];
-	if(enable) {
-		if(PWMSS_TB_clock_check(module_set[PWMSS_ID])) {
-			/* Enable module clock */
-			*reg = 0x2;	/* Module enable and fully functional */
-			return ret;
-#ifdef BBBIO_LIB_DBG
-		else {
-			printf("PWMSS_module_ctrl : PWMSS-%d timebase clock disable in Control Module\n", PWMSS_ID);
-#endif
-		ret = 0 ;
-	*reg = 0x3 << 16;	/* Module is disabled and cannot be accessed */
-	return ret;
-/* PWM init
- *	iolib_init will run this function automatically
- *      @return         : 1 for success , 0 for failed
-	int i = 0;
-	if (memh == 0) {
-		printf("BBBIO_PWM_Init: memory not mapped?\n");
-#endif
-		return 0;
-	/* Create Memory map */
-	for (i = 0 ; i < 3 ; i ++) {
-		pwmss_ptr[i] = mmap(0, PWMSS_MMAP_LEN, PROT_READ | PROT_WRITE, MAP_SHARED, memh, PWMSS_AddressOffset[i]);
-		if(pwmss_ptr[i] == MAP_FAILED) {
-			printf("BBBIO_PWM_Init: PWMSS %d mmap failure!\n", i);
-#endif
-			goto INIT_ERROR ;
+  switch(pwm_id)  {
+	case BBB_PWMSS2:
+		switch(pin_no) {
+			case BBB_P8_13_2B:
+		 		REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_GPMC_AD(9)) = BBB_MUXMODE(BBB_MUX4);
+		 		break;
+			case BBB_P8_19_2A:
+				REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_GPMC_AD(8)) = BBB_MUXMODE(BBB_MUX4);
+		 		break;
+			case BBB_P8_45_2A:
+		 		REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_LCD_DATA(0)) = BBB_MUXMODE(BBB_MUX3);
+		 		break;
+			case BBB_P8_46_2B:
+		 		REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_LCD_DATA(1)) = BBB_MUXMODE(BBB_MUX3);
+		 		break;
+ 			default :
+				printf("Invalid pin for module 2\n");
+				break;
-		ecap_ptr[i] = (void *)pwmss_ptr[i] + 0x100 ;
-		eqep_ptr[i] = (void *)pwmss_ptr[i] + 0x180 ;
-		epwm_ptr[i] = (void *)pwmss_ptr[i] + 0x200 ;
-		if(!PWMSS_module_ctrl(i, 1)) {
-			printf("BBBIO_PWM_Init: PWMSS %d clock  failure!\n", i);
-#endif
-			goto INIT_ERROR ;
+		break;
+	case BBB_PWMSS1:
+		switch(pin_no) {
+			case BBB_P8_34_1B:
+		 		REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_LCD_DATA(11)) = BBB_MUXMODE(BBB_MUX2);
+		 		break;
+			case BBB_P8_36_1A:
+		 		REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_LCD_DATA(10)) = BBB_MUXMODE(BBB_MUX2);
+		 		break;
+			case BBB_P9_14_1A:
+		 		REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_GPMC_AD(2)) = BBB_MUXMODE(BBB_MUX6);
+		 		break;
+			case BBB_P9_16_1B:
+		 		REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_GPMC_AD(3)) = BBB_MUXMODE(BBB_MUX6);
+		 		break;
+			default :
+				printf("Invalid pin for module 1\n");
+				break;
+		break;
+	case BBB_PWMSS0:
+		switch(pin_no) {
+			case BBB_P9_21_0B:
+		 		REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_D0) = BBB_MUXMODE(BBB_MUX3);
+		 		break;
+			case BBB_P9_22_0A:
+		 		REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_SCLK) = BBB_MUXMODE(BBB_MUX3);
+		 		break;
+			case BBB_P9_29_0B:
+		 		REG(AM335X_PADCONF_BASE + AM335X_CONF_MCASP0_FSX) = BBB_MUXMODE(BBB_MUX1);
+		 		break;
+			case BBB_P9_31_0A:
+		 		REG(AM335X_PADCONF_BASE + AM335X_CONF_MCASP0_ACLKX) = BBB_MUXMODE(BBB_MUX1);
+		 		break;
+			default:
+				printf("Invalid pin for module 0\n");
+				break;
-	return 1;
-INIT_ERROR :
-	BBBIO_PWM_Release();
-	return 0;
+		break;
+	default:
+		printf("PWM output is not available on this pin\n");
+		break;
+return true;
+ * @brief   This function Enables TBCLK(Time Base Clock) for specific
+ *          EPWM instance of pwmsubsystem.
+ * @param   instance  It is the instance number of EPWM of pwmsubsystem.
+static bool pwmss_tbclk_enable(unsigned int instance)
-	int i = 0;
-	for(i = 0 ; i < 3 ; i ++) {
-		if(pwmss_ptr[i] != NULL) {
-			munmap((void *)pwmss_ptr[i], PWMSS_MMAP_LEN);
-			pwmss_ptr[i] = NULL;
-			ecap_ptr[i] = NULL;
-			eqep_ptr[i] = NULL;
-			epwm_ptr[i] = NULL;
+uint32_t enable_bit;
+bool is_valid = true;
+  if (instance == BBB_PWMSS0)
+    	enable_bit = AM335X_PWMSS_CTRL_PWMSS0_TBCLKEN;
+  else if (instance == BBB_PWMSS1)
+     	enable_bit = AM335X_PWMSS_CTRL_PWMSS1_TBCLKEN;
+  else if (instance == BBB_PWMSS2)
+     	enable_bit = AM335X_PWMSS_CTRL_PWMSS2_TBCLKEN;
+  else
+     	is_valid = false;
+  if (is_valid)
+    	REG(AM335X_PADCONF_BASE + AM335X_PWMSS_CTRL) |= enable_bit;
+  return is_valid;
+ * @brief   This functions enables clock for EHRPWM module in PWMSS subsystem.
+ * @return  None.
+static void epwm_clock_enable(uint32_t pwm_id)
+	uint32_t baseAddr;
+	baseAddr = select_pwmss(pwm_id);
+        REG(baseAddr - AM335X_EPWM_REGS + AM335X_PWMSS_CLKCONFIG) |= AM335X_PWMSS_CLK_EN_ACK;
-/* PWMSS status (no effect now)
- * 	set pluse rgument of epwm module
+ * @brief   This function configures the L3 and L4_PER system clocks.
+ *          It also configures the system clocks for the specified ePWMSS
+ *          instance.
- *      @param PWMID    : EPWMSS number , 0~3
+ * @param   pwmss_id    The instance number of ePWMSS whose system clocks
+ *                         have to be configured.
+ * 'pwmss_id' can take one of the following values:
+ * (0 <= pwmss_id <= 2)
+ * @return  None.
+static void module_clk_config(uint32_t pwmss_id)
-	int param_error = 1;
-	if (memh == 0)
-            param_error = 0;
-    	if (PWMID > 2)		/* if input is not EPWMSS 0~ WPEMSS 2 */
-            param_error = 0;
-    	if (param_error == 0) {
-		printf("BBBIO_PWM_Status: parameter error!\n");
-#endif
-		return 0;
-	reg_value = *reg >> PWMID & 0x01 ;
-	if(reg_value == 0) {
-		printf("PWMSS [%d] Timebase clock Disable , Control Module [pwmss_ctrl register]\n", PWMID);
-	else {
-		reg=(void *)pwmss_ptr[PWMID] + PWMSS_CLKSTATUS;
+        if(pwmss_id == 0)
+                REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_EPWMSS0_CLKCTRL) |=
+                        AM335X_CM_PER_EPWMSS0_CLKCTRL_MODULEMODE_ENABLE;
+	 while(AM335X_CM_PER_EPWMSS0_CLKCTRL_MODULEMODE_ENABLE !=
+              (REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_EPWMSS0_CLKCTRL) &
+               AM335X_CM_PER_EPWMSS0_CLKCTRL_MODULEMODE));
+	 while((AM335X_CM_PER_EPWMSS0_CLKCTRL_IDLEST_FUNC <<
+               AM335X_CM_PER_EPWMSS0_CLKCTRL_IDLEST_SHIFT) !=
+               AM335X_CM_PER_EPWMSS0_CLKCTRL_IDLEST));
+        else if(pwmss_id == 1)
+                REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_EPWMSS1_CLKCTRL) |=
+                        AM335X_CM_PER_EPWMSS1_CLKCTRL_MODULEMODE_ENABLE;
+	while(AM335X_CM_PER_EPWMSS1_CLKCTRL_MODULEMODE_ENABLE !=
+              (REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_EPWMSS1_CLKCTRL) &
+               AM335X_CM_PER_EPWMSS1_CLKCTRL_MODULEMODE));
+        while((AM335X_CM_PER_EPWMSS1_CLKCTRL_IDLEST_FUNC <<
+               AM335X_CM_PER_EPWMSS1_CLKCTRL_IDLEST_SHIFT) !=
+               AM335X_CM_PER_EPWMSS1_CLKCTRL_IDLEST));
+        else if(pwmss_id == 2)
+                REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_EPWMSS2_CLKCTRL) |=
+                        AM335X_CM_PER_EPWMSS2_CLKCTRL_MODULEMODE_ENABLE;
+	while(AM335X_CM_PER_EPWMSS2_CLKCTRL_MODULEMODE_ENABLE !=
+              (REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_EPWMSS2_CLKCTRL) &
+               AM335X_CM_PER_EPWMSS2_CLKCTRL_MODULEMODE));
+        while((AM335X_CM_PER_EPWMSS2_CLKCTRL_IDLEST_FUNC <<
+               AM335X_CM_PER_EPWMSS2_CLKCTRL_IDLEST_SHIFT) !=
+                AM335X_CM_PER_EPWMSS2_CLKCTRL_IDLEST));
+        else
+		printf("Please enter valid pwm Id \n");
-		printf("PWMSS [%d] :\tCLKSTOP_ACK %d , CLK_EN_ACK %d , CLKSTOP_ACK %d , CLK_EN_ACK %d , CLKSTOP_ACK %d , CLK_EN_ACK %d\n",
-			PWMID ,
-			reg_value >>9 & 0x1 ,
-			reg_value >>8 & 0x1 ,
-			reg_value >>5 & 0x1 ,
-			reg_value >>4 & 0x1 ,
-			reg_value >>1 & 0x1 ,
-			reg_value >>0 & 0x1 );
-	return 1 ;
+  bool status = true;
+  if((pwmss_id <3) & (pwmss_id >=0))
+  module_clk_config(pwmss_id);
+  epwm_clock_enable(pwmss_id);
+  pwmss_tbclk_enable(pwmss_id);
+  return status;
+  else {
+	status =false;
+  return status;
 /* PWMSS setting
- *      @param PWMID    : EPWMSS number , 0~2
- *      @param HZ    	: pluse HZ
- *      @example        :  BBBIO_PWMSS_Setting(0 , 50.0f , 50.0f , 25.0f); 	// Generate 50HZ pwm in PWM0 ,
- *										// duty cycle is 50% for ePWM0A , 25% for ePWM0B
- * 	@Note :
- * 		find an number nearst 65535 for TBPRD , to improve duty precision,
+ *      @Note :
- *		Using big TBPRD can increase the range of CMPA and CMPB ,
- * 		and it means we can get better precision on duty cycle.
- *		EX : 20.25% duty cycle
- *		Divisor = CLKDIV * HSPCLKDIV
- *     			1 TBPRD : 10 ns (default)
- *			65535 TBPRD : 655350 ns
- *			65535 TBPRD : 655350 * Divisor ns  = X TBPRD : Cyclens
- * 		accrooding to that , we must find a Divisor value , let X nearest 65535 .
- * 		so , Divisor must  Nearest Cyclens/655350
-	volatile unsigned short* reg16 ;
-        if (memh == 0)
-            param_error = 0;
-        if (PWMID > 2)              // if input is not EPWMSS 0~ WPEMSS 2
-            param_error = 0;
-	if (HZ < 0 )
-	    param_error = 0;
-	if(dutyA < 0.0f || dutyA > 100.0f || dutyB < 0.0f || dutyB > 100.0f)
-	    param_error = 0;
-		printf("BBBIO_PWMSS_Setting: parameter error!\n");
-#endif
-		return 0;
-	dutyA /= 100.0f ;
-	dutyB /= 100.0f ;
-	/* compute neccessary TBPRD */
-	float Cyclens =0.0f ;
-	float Divisor =0;
-	int i , j ;
-	const float CLKDIV_div[] = {1.0 ,2.0 ,4.0 ,8.0 ,16.0 ,32.0 , 64.0 , 128.0};
-	const float HSPCLKDIV_div[] ={1.0 ,2.0 ,4.0 ,6.0 ,8.0 ,10.0 , 12.0 , 14.0};
-	int NearCLKDIV =7;
-	int NearHSPCLKDIV =7;
-	int NearTBPRD =0;
-	Cyclens = 1000000000.0f / HZ ; /* 10^9 / HZ , comput time per cycle (ns) */
-	Divisor =  (Cyclens / 655350.0f) ;	/* am335x provide (128*14) divider , and per TBPRD means 10 ns when divider /1 ,
-						 * and max TBPRD is 65535 , so , the max cycle is 128*14* 65535 *10ns
-	printf("Cyclens %f , Divisor %f\n", Cyclens, Divisor);
-#endif
-	if(Divisor > (128 * 14)) {
-		printf("BBBIO_PWMSS_Setting : Can't generate %f HZ \n", HZ);
-#endif
-		return 0;
-	else {
-		/* using Exhaustive Attack metho */
-		for(i = 0 ; i < 8 ; i ++) {
-			for(j = 0 ; j < 8 ; j ++) {
-				if((CLKDIV_div[i] * HSPCLKDIV_div[j]) < (CLKDIV_div[NearCLKDIV] * HSPCLKDIV_div[NearHSPCLKDIV]) &&
-				  ((CLKDIV_div[i] * HSPCLKDIV_div[j]) > Divisor)) {
-					NearCLKDIV = i ;
-					NearHSPCLKDIV = j ;
+  int param_error =1;
+  if(pwm_freq < 0)
+	param_error =0;
+  if(dutyA < 0.0f || dutyA > 100.0f || dutyB < 0.0f || dutyB > 100.0f)
+	param_error = 0;
+  if(param_error == 0) {
+	printf("ERROR in parameter \n");
+  dutyA /= 100.0f;
+  dutyB /= 100.0f;
+  /*Compute necessary TBPRD*/
+  float Cyclens = 0.0f;
+  float Divisor =0;
+  int i,j;
+  const float CLKDIV_div[] = {1.0,2.0,4.0,8.0,16.0,32.0,64.0,128.0};
+  const float HSPCLKDIV_div[] = {1.0, 2.0, 4.0, 6.0, 8.0, 10.0,12.0, 14.0};
+  int NearCLKDIV =7;
+  int NearHSPCLKDIV =7;
+  int NearTBPRD =0;
+  /** 10^9 /Hz compute time per cycle (ns) */
+  Cyclens = 1000000000.0f / pwm_freq;
+  /** am335x provide (128* 14) divider and per TBPRD means 10ns when divider
+    * and max TBPRD is 65535 so max cycle is 128 * 8 * 14 * 65535 * 10ns */
+  Divisor = (Cyclens / 655350.0f);
+  if(Divisor > (128 * 14)) {
+	printf("Can't generate %f HZ",pwm_freq);
+	return 0;
+  else {
+	for (i=0;i<8;i++) {
+		for(j=0 ; j<8; j++) {
+			if((CLKDIV_div[i] * HSPCLKDIV_div[j]) < (CLKDIV_div[NearCLKDIV]
+						* HSPCLKDIV_div[NearHSPCLKDIV]) && (CLKDIV_div[i] * HSPCLKDIV_div[j] > Divisor)) {
+				NearCLKDIV = i;
+				NearHSPCLKDIV = j;
-		printf("nearest CLKDIV %f , HSPCLKDIV %f\n" ,CLKDIV_div[NearCLKDIV] ,HSPCLKDIV_div[NearHSPCLKDIV]);
-#endif
-		NearTBPRD = (Cyclens / (10.0 *CLKDIV_div[NearCLKDIV] *HSPCLKDIV_div[NearHSPCLKDIV])) ;
-		printf("nearest TBPRD %d, %f %f\n ",NearTBPRD,NearTBPRD * dutyA, NearTBPRD * dutyB);
-#endif
-		/* setting clock diver and freeze time base */
-		reg16=(void*)epwm_ptr[PWMID] +EPWM_TBCTL;
-		*reg16 = TBCTL_CTRMODE_FREEZE | (NearCLKDIV << 10) | (NearHSPCLKDIV << 7);
-		/*  setting duty A and duty B */
-		reg16=(void*)epwm_ptr[PWMID] +EPWM_CMPB;
-		*reg16 =(unsigned short)((float)NearTBPRD * dutyB);
-		reg16=(void*)epwm_ptr[PWMID] +EPWM_CMPA;
-		*reg16 =(unsigned short)((float)NearTBPRD * dutyA);
-		reg16=(void*)epwm_ptr[PWMID] +EPWM_TBPRD;
-		*reg16 =(unsigned short)NearTBPRD;
-		/* reset time base counter */
-		reg16 = (void *)epwm_ptr[PWMID] + EPWM_TBCNT;
-		*reg16 = 0;
-	return 1;
+  REG16(baseAddr + AM335X_EPWM_TBCTL) &= ~(AM335X_TBCTL_CLKDIV_MASK | AM335X_TBCTL_HSPCLKDIV_MASK);
+  REG16(baseAddr + AM335X_EPWM_TBCTL) = (REG16(baseAddr + AM335X_EPWM_TBCTL) &
+  (~AM335X_EPWM_TBCTL_CLKDIV)) | ((NearCLKDIV
+  << AM335X_EPWM_TBCTL_CLKDIV_SHIFT) & AM335X_EPWM_TBCTL_CLKDIV);
+  (~AM335X_EPWM_TBCTL_HSPCLKDIV)) | ((NearHSPCLKDIV <<
+  AM335X_EPWM_TBCTL_HSPCLKDIV_SHIFT) & AM335X_EPWM_TBCTL_HSPCLKDIV);
+  NearTBPRD = (Cyclens / (10.0 * CLKDIV_div[NearCLKDIV] * HSPCLKDIV_div[NearHSPCLKDIV]));
+  (~AM335X_EPWM_PRD_LOAD_SHADOW_MASK)) | (((bool)AM335X_EPWM_SHADOW_WRITE_DISABLE <<
+  AM335X_EPWM_TBCTL_PRDLD_SHIFT) & AM335X_EPWM_PRD_LOAD_SHADOW_MASK);
+  (~AM335X_EPWM_COUNTER_MODE_MASK)) | (((unsigned int)AM335X_EPWM_COUNT_UP <<
+  AM335X_TBCTL_CTRMODE_SHIFT) &  AM335X_EPWM_COUNTER_MODE_MASK);
+  /*setting clock divider and freeze time base*/
+  REG16(baseAddr + AM335X_EPWM_CMPB) = (unsigned short)((float)(NearTBPRD) * dutyB);
+  REG16(baseAddr + AM335X_EPWM_CMPA) = (unsigned short)((float)(NearTBPRD) * dutyA);
+  REG16(baseAddr + AM335X_EPWM_TBPRD) = (unsigned short)NearTBPRD;
+  REG16(baseAddr + AM335X_EPWM_TBCNT) = 0;
+  return 1;
-/* Enable/Disable ehrPWM module
- *      @param PWMID    : PWMSS number , 0~2
- *      @return         : void
- *      @example        : BBBIO_PWMSS_Enable(0) ;// Enable PWMSS 0
-	volatile unsigned short *reg16 ;
-	reg16=(void*)epwm_ptr[PWMSS_ID] +EPWM_AQCTLA;
-	*reg16 = 0x2 | ( 0x3 << 4) ;
-	reg16=(void*)epwm_ptr[PWMSS_ID] +EPWM_AQCTLB;
-	*reg16 = 0x2 | ( 0x3 << 8) ;
-	reg16 = (void *)epwm_ptr[PWMSS_ID] + EPWM_TBCNT;
-	*reg16 = 0;
-        reg16=(void *)epwm_ptr[PWMSS_ID] + EPWM_TBCTL;
-	*reg16 &= ~0x3;
+  if((pwmid<3) & (pwmid >=0)) {
+  baseAddr = select_pwmss(pwmid);
+  REG16(baseAddr + AM335X_EPWM_AQCTLA) = AM335X_EPWM_AQCTLA_ZRO_XAHIGH | (AM335X_EPWM_AQCTLA_CAU_EPWMXATOGGLE << AM335X_EPWM_AQCTLA_CAU_SHIFT);
+  REG16(baseAddr + AM335X_EPWM_AQCTLB) = AM335X_EPWM_AQCTLB_ZRO_XBHIGH | (AM335X_EPWM_AQCTLB_CBU_EPWMXBTOGGLE << AM335X_EPWM_AQCTLB_CBU_SHIFT);
+  REG16(baseAddr + AM335X_EPWM_TBCTL) |=  AM335X_TBCTL_FREERUN  | AM335X_TBCTL_CTRMODE_UP;
+  return status;
+  else {
+	status =false;
+	return status;
-        *reg16 |= 0x3;
-	*reg16 = 0x1 | ( 0x3 << 4) ;
-	*reg16 = 0x1 | ( 0x3 << 8) ;
-	*reg16 = 0;
+  REG16(baseAddr + AM335X_EPWM_TBCTL) = AM335X_EPWM_TBCTL_CTRMODE_STOPFREEZE;
+  REG16(baseAddr + AM335X_EPWM_AQCTLA) = AM335X_EPWM_AQCTLA_ZRO_XALOW | (AM335X_EPWM_AQCTLA_CAU_EPWMXATOGGLE << AM335X_EPWM_AQCTLA_CAU_SHIFT);
+  REG16(baseAddr + AM335X_EPWM_AQCTLB) = AM335X_EPWM_AQCTLA_ZRO_XBLOW | (AM335X_EPWM_AQCTLB_CBU_EPWMXBTOGGLE << AM335X_EPWM_AQCTLB_CBU_SHIFT);
+  return status;
+  else {
+ 	status = false;
+	return status;
+#endif
+/* For support of BeagleboardxM */
+#if IS_DM3730
+/* Currently this section is just to satisfy
+ * GPIO API and to make the build successful.
+ * Later on support can be added here.
+uint32_t select_pwmss(uint32_t pwm_id)
+return -1;
+bool pwmss_tbclk_enable(unsigned int instance)
+return false;
+return false;
+return false;
+return false;
+return -1;
+return false;
+#endif
diff --git a/c/src/lib/libcpu/arm/shared/include/am335x.h b/c/src/lib/libcpu/arm/shared/include/am335x.h
index 2009cef..156e7a5 100644
--- a/c/src/lib/libcpu/arm/shared/include/am335x.h
+++ b/c/src/lib/libcpu/arm/shared/include/am335x.h
@@ -467,4 +467,99 @@
 #define AM335X_CONF_EXT_WAKEUP 0xA00
 #define AM335X_CONF_RTC_KALDO_ENN 0xA04
 #define AM335X_CONF_USB0_DRVVBUS 0xA1C
-#define AM335X_CONF_USB1_DRVVBUS 0xA34
\ No newline at end of file
+#define AM335X_CONF_USB1_DRVVBUS 0xA34
+/* Registers for PWM Subsystem */
+#define AM335X_PWMSS_CTRL		(0x664)
+#define AM335X_CM_PER_EPWMSS0_CLKCTRL    (0xD4)
+#define AM335X_CM_PER_EPWMSS1_CLKCTRL    (0xCC)
+#define AM335X_CM_PER_EPWMSS2_CLKCTRL    (0xD8)
+#define AM335X_CONTROL_MODULE 		(0x44e10000)
+#define AM335X_CM_PER_ADDR		(0x44e00000)
+#define AM335X_PWMSS_CLKSTATUS			(0xC)
+#define AM335X_PWMSS0_MMAP_ADDR        0x48300000
+#define AM335X_PWMSS1_MMAP_ADDR        0x48302000
+#define AM335X_PWMSS2_MMAP_ADDR        0x48304000
+#define AM335X_PWMSS_MMAP_LEN          0x1000
+#define AM335X_PWMSS_IDVER     	0x0
+#define AM335X_PWMSS_SYSCONFIG 	0x4
+#define AM335X_PWMSS_CLKCONFIG 	0x8
+#define AM335X_PWMSS_CLK_EN_ACK        0x100
+#define AM335X_PWMSS_CLKSTATUS 	0xC
+#define AM335X_EPWM_TBCTL      	0x0
+#define AM335X_EPWM_TBSTS      	0x2
+#define AM335X_EPWM_TBPHSHR    	0x4
+#define AM335X_EPWM_TBPHS      	0x6
+#define AM335X_EPWM_TBCNT      	0x8
+#define AM335X_EPWM_TBPRD      	0xA
+#define AM335X_EPWM_CMPCTL     	0xE
+#define AM335X_EPWM_CMPAHR     	0x10
+#define AM335X_EPWM_CMPA       	0x12
+#define AM335X_EPWM_CMPB       	0x14
+#define AM335X_EPWM_AQCTLA     	0x16
+#define AM335X_EPWM_AQCTLB     	0x18
+#define AM335X_EPWM_AQSFRC     	0x1A
+#define AM335X_EPWM_AQCSFRC    	0x1C
+#define AM335X_EPWM_DBCTL      	0x1E
+#define AM335X_EPWM_DBRED      	0x20
+#define AM335X_EPWM_DBFED      	0x22
+#define AM335X_TBCTL_CTRMODE_UP        0x0
+#define AM335X_TBCTL_CTRMODE_DOWN      0x1
+#define AM335X_TBCTL_CTRMODE_UPDOWN    0x2
+#define AM335X_TBCTL_CTRMODE_FREEZE    0x3
+#define AM335X_EPWM_AQCTLA_ZRO_XALOW  	      (0x0001u)
+#define AM335X_EPWM_AQCTLA_ZRO_XAHIGH 	      (0x0002u)
+#define AM335X_EPWM_AQCTLA_CAU_EPWMXATOGGLE   (0x0003u)
+#define AM335X_EPWM_AQCTLA_CAU_SHIFT          (0x0004u)
+#define AM335X_EPWM_AQCTLA_ZRO_XBLOW  	      (0x0001u)
+#define AM335X_EPWM_AQCTLB_ZRO_XBHIGH 	      (0x0002u)
+#define AM335X_EPWM_AQCTLB_CBU_EPWMXBTOGGLE   (0x0003u)
+#define AM335X_EPWM_AQCTLB_CBU_SHIFT          (0x0008u)
+#define AM335X_EPWM_TBCTL_CTRMODE_STOPFREEZE  (0x0003u)
+#define AM335X_PWMSS_CTRL_PWMSS0_TBCLKEN      (0x00000001u)
+#define AM335X_PWMSS_CTRL_PWMSS1_TBCLKEN      (0x00000002u)
+#define AM335X_PWMSS_CTRL_PWMSS2_TBCLKEN      (0x00000004u)
+#define AM335X_CM_PER_EPWMSS0_CLKCTRL_MODULEMODE_ENABLE   (0x2u)
+#define AM335X_CM_PER_EPWMSS1_CLKCTRL_MODULEMODE_ENABLE   (0x2u)
+#define AM335X_CM_PER_EPWMSS2_CLKCTRL_MODULEMODE_ENABLE   (0x2u)
+#define AM335X_TBCTL_CLKDIV_MASK              (3 << 10)
+#define AM335X_TBCTL_HSPCLKDIV_MASK           (3 << 7)
+#define AM335X_EPWM_TBCTL_CLKDIV              (0x1C00u)
+#define AM335X_EPWM_TBCTL_CLKDIV_SHIFT        (0x000Au)
+#define AM335X_EPWM_TBCTL_HSPCLKDIV           (0x0380u)
+#define AM335X_EPWM_TBCTL_HSPCLKDIV_SHIFT     (0x0007u)
+#define AM335X_EPWM_TBCTL_PRDLD               (0x0008u)
+#define AM335X_EPWM_PRD_LOAD_SHADOW_MASK      AM335X_EPWM_TBCTL_PRDLD
+#define AM335X_EPWM_SHADOW_WRITE_ENABLE       0x0
+#define AM335X_EPWM_SHADOW_WRITE_DISABLE      0x1
+#define AM335X_EPWM_TBCTL_PRDLD_SHIFT         (0x0003u)
+#define AM335X_EPWM_TBCTL_CTRMODE             (0x0003u)
+#define AM335X_EPWM_COUNTER_MODE_MASK         AM335X_EPWM_TBCTL_CTRMODE
+#define AM335X_TBCTL_FREERUN                  (2 << 14)
+#define AM335X_TBCTL_CTRMODE_UP               (0x0000u)
+#define AM335X_TBCTL_CTRMODE_SHIFT            (0x0000u)
+#define AM335X_EPWM_COUNT_UP                  (AM335X_TBCTL_CTRMODE_UP << \
+#define AM335X_EPWM_REGS                       (0x00000200)
+#define AM335X_EPWM_0_REGS                     (AM335X_PWMSS0_MMAP_ADDR + AM335X_EPWM_REGS)
+#define AM335X_EPWM_1_REGS                     (AM335X_PWMSS1_MMAP_ADDR + AM335X_EPWM_REGS)
+#define AM335X_EPWM_2_REGS                     (AM335X_PWMSS2_MMAP_ADDR + AM335X_EPWM_REGS)
+#define AM335X_CM_PER_EPWMSS0_CLKCTRL_MODULEMODE   (0x00000003u)
+#define AM335X_CM_PER_EPWMSS0_CLKCTRL_IDLEST_FUNC  (0x0u)
+#define AM335X_CM_PER_EPWMSS0_CLKCTRL_IDLEST_SHIFT (0x00000010u)
+#define AM335X_CM_PER_EPWMSS0_CLKCTRL_IDLEST       (0x00030000u)
+#define AM335X_CM_PER_EPWMSS1_CLKCTRL_MODULEMODE   (0x00000003u)
+#define AM335X_CM_PER_EPWMSS1_CLKCTRL_IDLEST       (0x00030000u)
+#define AM335X_CM_PER_EPWMSS1_CLKCTRL_IDLEST_FUNC  (0x0u)
+#define AM335X_CM_PER_EPWMSS1_CLKCTRL_IDLEST_SHIFT (0x00000010u)
+#define AM335X_CM_PER_EPWMSS2_CLKCTRL_MODULEMODE   (0x00000003u)
+#define AM335X_CM_PER_EPWMSS2_CLKCTRL_IDLEST_FUNC  (0x0u)
+#define AM335X_CM_PER_EPWMSS2_CLKCTRL_IDLEST_SHIFT (0x00000010u)
+#define AM335X_CM_PER_EPWMSS2_CLKCTRL_IDLEST       (0x00030000u)
2.7.1
