Errors while building USB DWC OTG driver
Deval Shah
deval.maker at gmail.com
Fri Jun 3 08:20:05 UTC 2016
Hello,
I was going through last years mailing list for debugging the issue. I
found this https://lists.rtems.org/pipermail/devel/2015-June/011741.html.
Can someone explain how to get the linker map file ?
On Wed, Jun 1, 2016 at 11:01 AM, Sebastian Huber <
> Hello Deval,
> I would use a hardware debugger or Qemu to tackle this problem.
> On 31/05/16 19:32, Deval Shah wrote:
>> Hello,
>> I have managed to resolve previous errors and the driver is finally
>> building. I want to test this on hardware now. I tried running "USB01"
>> testsuit for this. But I could not see any output on minicom.
>> Is there any debug flag/macro which I can turn on in order to get all the
>> error log? Or any other debug method for raspberry pi hardware ?
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160603/70c633c4/attachment-0002.html>
