Driver complaint to SD Host Controller Specification 3.0
Mudit Jain
muditjain18011995 at gmail.com
Fri Jun 3 11:20:47 UTC 2016
Hi,
Yes Sebastian, that change was not required. I have rebased, removing that
change and have pushed the same. Link
<https://github.com/spark1729/rtems-libbsd/commits/rpi_sd_card>
Andre, as per your feedback, I have removed the ofw bus.
In the latest commit I have followed the FreeBSD port guidelines given
libbsd.txt using the tools to port the code.
Github Link : Link
These files have been added to libbsd.py that were ported to the
rtems-libbsd tree from the FreeBSD one using freebsd-to-rtems.py
sys/arm/broadcom/bcm2835/bcm2835_dma.c
sys/arm/broadcom/bcm2835/bcm2835_dma.h
sys/arm/broadcom/bcm2835/bcm2835_mbox.c
sys/arm/broadcom/bcm2835/bcm2835_mbox.h
sys/arm/broadcom/bcm2835/bcm2835_mbox_prop.h
sys/arm/broadcom/bcm2835/bcm2835_sdhci.c
sys/arm/broadcom/bcm2835/bcm2835_vcbus.h
Changes have been done on top of this to
>>remove the dependency on the ofw bus
>>make it compatible with RTEMS
The corresponding changes are done to libbsd_waf.py and waf build completes
successfully.
Presently I have ported the mailbox code as well. As per Andre's suggestion
I will be looking at the mailbox support that was added by Yang Quiao last
year
Reasons for replacing the files - sdhci.c & sdhci.h :
1. The previous sdhci.c had the bsp specific logics and generic sd driver
code together. Presently it is more modular in nature such that bcm_sdhci.c
uses the generic functions
defined in sdhci.c and implements the driver specific functions.
2. The structures namely *bcm_sdhci_softc and sdhci_slot *have changed
which are extensively used by bcm specific code.
Thanks
<https://github.com/spark1729/rtems-libbsd/commits/rpi_sd_card>Mudit
On Wed, Jun 1, 2016 at 1:56 PM, André Marques <andre.lousa.marques at gmail.com
> wrote:
> Hello mudit,
> Às 09:13 de 30-05-2016, Mudit Jain escreveu:
> Hi all,
> I have ported the code from the present FreeBSD.
> Link : https://github.com/spark1729/rtems-libbsd/commits/rpi_sd_card
> Kindly review the same and suggest changes.
> The commits are a bit unstructured, the second last one being a huge one.
> I will be breaking it down into smaller and logical patches while
> submitting.
> Files changed/added in the three commits are as follows :
> freebsd/sys/dev/ofw/ofw_bus.h
> freebsd/sys/dev/ofw/ofw_bus_if.c
> freebsd/sys/dev/ofw/ofw_bus_if.h
> freebsd/sys/dev/ofw/ofw_bus_subr.c
> freebsd/sys/dev/ofw/ofw_bus_subr.h
> freebsd/sys/sys/queue.h
> freebsd/sys/contrib/libfdt/libfdt_env.h
> freebsd/sys/dev/fdt/fdt_common.c
> freebsd/sys/dev/fdt/fdt_common.h
> freebsd/sys/sys/slicer.h
> freebsd/sys/dev/mbox/mbox_if.c
> freebsd/sys/dev/mbox/mbox_if.h
> freebsd/sys/dev/ofw/ofw_if.c
> freebsd/sys/dev/ofw/ofw_if.h
> freebsd/sys/dev/ofw/ofwvar.h
> freebsd/sys/dev/ofw/openfirm.c
> freebsd/sys/dev/ofw/openfirm.h
> freebsd/sys/dev/sdhci/bcm2835_dma.c
> freebsd/sys/dev/sdhci/bcm2835_dma.h
> freebsd/sys/dev/sdhci/bcm2835_mbox.c
> freebsd/sys/dev/sdhci/bcm2835_mbox.h
> freebsd/sys/dev/sdhci/bcm2835_mbox_prop.h
> freebsd/sys/dev/sdhci/bcm2835_sdhci.c
> freebsd/sys/dev/sdhci/bcm2835_vcbus.h
> freebsd/sys/dev/sdhci/sdhci.c
> freebsd/sys/dev/sdhci/sdhci.h
> freebsd/sys/dev/sdhci/sdhci_if.c
> freebsd/sys/dev/sdhci/sdhci_if.h
> Files added to the build process [ libbsd_waf.py ]
> Errors and how they were resolved :
> 1. The *_if.m files were converted into *_if.c and *_if.h using the
> following script : Link
> <http://opensource.apple.com//source/smb/smb-66/kernel/sys5/kern/makeobjops.pl?txt>
> 2. fdt and ofw support was added as the driver had dependencies on that.
> 3. *taskqueue_swi_giant* global is not provided by RTEMS. That was
> solved by adding a new field to the *sdhci slot* structure - *sdhci_tq*.
> 4. BUS_PHYSADDR used in bcm_sdhci.c is a macro defined in
> arm/include/bus.h. This macro is copied bcm_sdhci.c.
> Presently the SD driver module is built from bcm_sdhci.c using the
> generic and other functions defined in sdhci.c. However for modularity a
> different
> Question :
> 1. Presently I have just kept the bcm2835 specific code in /dev/sdhci/
> directory. I don't think that would be ideal, I wanted to discuss the
> positioning of the bcm2835 specific files.
> 2. Presently the SD driver module is built from bcm_sdhci.c using the
> generic and other functions defined in sdhci.c. Is this fine ?
> 3. I have used the *.start_actual *in nexus-devices.h for *rpi_dma_res *as*
> 0x7e007000. *Is this the correct value ? Link
> <https://www.kernel.org/doc/Documentation/devicetree/bindings/dma/brcm,bcm2835-dma.txt>
> Note : I have not added the macro LIBBSP_ARM_RASPBERRYPI_BSP_H to bcm2835
> specific code. I will be doing that.
> waf builds everything that was added successfully.
> Thanks
> Mudit
> Hello Mudit,
> My feedback from a quick skim through your code:
> There is already some mailbox support from Yang Quiao's last year GSOC, so
> if anything is missing from his work please improve it.
> The ofw bus is not necessary for the sdhci driver in RTEMS, so that can be
> left out.
> As Sebastian suggested, you need to follow the FreeBSD port guidelines,
> and also do not replace entire files (e.g..: sdhci.c and sdhci.h).
> --André Marques
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160603/4e0b86d4/attachment-0002.html>
