Fwd: [PATCH 1/2] score: Add and use Watchdog_Clock for clock types.
Tue Jun 21 14:22:35 UTC 2016
On Tue, Jun 21, 2016 at 1:48 AM, Sebastian Huber
> On 16/06/16 08:09, Sebastian Huber wrote:
>>> diff --git a/cpukit/score/include/rtems/score/threadqimpl.h
>>> b/cpukit/score/include/rtems/score/threadqimpl.h
>>> index 73d4de2..f59a334 100644
>>> --- a/cpukit/score/include/rtems/score/threadqimpl.h
>>> +++ b/cpukit/score/include/rtems/score/threadqimpl.h
>>> @@ -349,6 +349,7 @@ Thread_Control *_Thread_queue_Do_dequeue(
>>>    *       executing,
>>>    *       STATES_WAITING_FOR_MUTEX,
>>>    *       WATCHDOG_NO_TIMEOUT,
>>> + *       WATCHDOG_RELATIVE,
>>>    *       0,
>>>    *       &queue_context
>>> @@ -362,6 +363,7 @@ Thread_Control *_Thread_queue_Do_dequeue(
>>>    * @param[in] state The new state of the thread.
>>>    * @param[in] timeout Interval to wait.  Use WATCHDOG_NO_TIMEOUT to
>>> block
>>>    * potentially forever.
>>> + * @param[in] clock The kind of clock used for the interval.
>>>    * @param[in] queue_context The thread queue context of the lock
>>> acquire.
>>>   void _Thread_queue_Enqueue_critical(
>>> @@ -370,6 +372,7 @@ void _Thread_queue_Enqueue_critical(
>>>     Thread_Control                *the_thread,
>>>     States_Control                 state,
>>>     Watchdog_Interval              timeout,
>>> +  Watchdog_Clock                 clock,
>>>     Thread_queue_Context          *queue_context
>> We already have a lot of parameters for the
>> _Thread_queue_Enqueue_critical(). I would rather move the timeout parameters
>> to the queue_context, since this is more efficient.
>> The Watchdog_Interval is 32-bit, thus not suitable for the absolute
>> timeouts.
>> A value of 0 is valid for absolute timeouts, see what happens if you get
>> that wrong
>> https://www.wired.com/2016/02/dont-set-your-iphone-back-to-1970-no-matter-what/
>> So, I would move the WATCHDOG_NO_TIMEOUT to your new Watchdog_Clock.
> From IRC log:
> [19:44] <gedare> sebhub: Does it make sense to you to redefine
> Watchdog_Interval as a struct containing a union for the interval and an
> enum for the Clock "Discipline" (relative/absolute)?
> [19:45] <gedare> ^the union for uint32_t relative, uint64_t absolute--or
> else we make all intervals 64-bit
> No, I would not change Watchdog_Interval. We should keep the ticks based
> services as is. The problem is that _Thread_queue_Enqueue_critical() doesn't
> support absolute timeouts currently. I would do something like the attached.
> We have
>   Thread_queue_Queue            *queue,
>   const Thread_queue_Operations *operations,
>   Per_CPU_Control *cpu_self;
>   bool             success;
> #if defined(RTEMS_MULTIPROCESSING)
>   if ( _Thread_MP_Is_receive( the_thread ) && the_thread->receive_packet ) {
>     the_thread = _Thread_MP_Allocate_proxy( state );
> #endif
>   _Thread_Lock_set( the_thread, &queue->Lock );
>   the_thread->Wait.return_code = STATUS_SUCCESSFUL;
>   _Thread_Wait_set_queue( the_thread, queue );
>   _Thread_Wait_set_operations( the_thread, operations );
>   ( *operations->enqueue )( queue, the_thread );
> Thus, we would have to store the timeout related parameters to the stack
> anyway, since ( *operations->enqueue )( queue, the_thread ) is a function
> call which cannot be optimized way (except maybe through link-time
> optimization). So, there is no overhead due to the use of the queue context.
Thanks, that makes sense. I mocked together the changes to put the
timeout parameters into the context. I will work on adding the little
bit needed to use 64-bit intervals for absolute.
Do you have a preference between "Watchdog_Discipline" and
"Watchdog_Clock"? I think Discipline may be nicer.
I did not put the initialization of the timeout parameters to a
default, instead I made each producer of a threadq_enqueue to
explicitly set the parameters. Perhaps a sane default of NO_TIMEOUT is
good, and will reduce the size of my patch.
Tomorrow I'll work on cleaning this up some more. Wrapping the
WATCHDOG_NO_TIMEOUT in the Watchdog_Discipline makes the structure no
longer match with the Per_CPU_Watchdog_index values. So a little bit
of massaging has to be done there.
Type: text/x-diff
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160621/df485dc2/attachment-0002.bin>
