ARM SMP Clock driver errors
Darshit Shah
darnir at gmail.com
Wed Jun 22 07:57:16 UTC 2016
On 06/22, Sebastian Huber wrote:
>On 21/06/16 07:29, Sebastian Huber wrote:
>> On 20/06/16 15:40, Darshit Shah wrote:
>>> Hi,
>>> Last week the clock driver for SMP ARM BSPs was fixed which allowed
>>> me to start executing the SMP tests for my GSoC project. However,
>>> today I seem to be stuck with a clock driver issue again.
>>> When I try to execute SMP tests, the tests exit with no output and a
>>> exit code of 0. On trying to run them in QEMU and breaking on
>>> _Terminate(), I found out that the tests exit because of an
>>> `RTEMS_FATAL_SOURCE_BSP` error which propagates from the
>>> `a9mpcore_clock_secondary_initialization` method. The complete
>>> backtrace is:
>> In this case something is wrong with your BSP build. In bspopts.h you
>> must find this:
>> find -name bspopts.h | xargs grep CLOCK_DRIVER_USE_ONLY_BOOT_PROCESSOR
>> ./arm-rtems4.12/c/realview_pbx_a9_qemu_smp/lib/libbsp/arm/realview-pbx-a9/include/bspopts.h:#define
>> CLOCK_DRIVER_USE_ONLY_BOOT_PROCESSOR 1
>> ./arm-rtems4.12/realview_pbx_a9_qemu_smp/lib/include/bspopts.h:#define
>I checked commit 3d9fd2ce55575e603fa9e781cc66f553e917fd3b and everything
>(except some timing dependent tests) works fine for the
>realview_pbx_a9_qemu and realview_pbx_a9_qemu_smp BSPs.
I just nuked my existing build directory and everything worked again.
Not sure why the build went bad. I guess I'll need to constantly keep
deleting the build directory everytime I see any kind of failure.
>Sebastian Huber, embedded brains GmbH
>Address : Dornierstr. 4, D-82178 Puchheim, Germany
>Phone : +49 89 189 47 41-16
>Fax : +49 89 189 47 41-09
>E-Mail : sebastian.huber at embedded-brains.de
>PGP : Public key available on request.
>Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
Thanking You,
Darshit Shah
Type: application/pgp-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160622/4ea22409/attachment-0002.bin>
