[PATCH] Subject: Add PWM driver for beagle bone black
Ketul Shah ketulshah1993 at gmail.com
Thu Jun 23 17:08:06 UTC 2016
Hi Punit,
Great to see PWM driver working....
Besides Martin has suggested, I would like to add few points.
On 21 June 2016 at 21:56, Punit Vara <punitvara at gmail.com> wrote:
>         This patch adds required definitions, registers definitions and
> testsuit to
>         test pwm driver for beagle bone black.
>  c/src/lib/libbsp/arm/beagle/Makefile.am      |   3 +
>  c/src/lib/libbsp/arm/beagle/pwm/bbb-pwm.c    | 345
>  c/src/lib/libbsp/shared/include/gpio.h       |  11 +
>  c/src/lib/libcpu/arm/shared/include/am335x.h | 349
>  testsuites/samples/Makefile.am               |   2 +-
>  testsuites/samples/configure.ac              |   1 +
>  testsuites/samples/pwm/Makefile.am           |  19 ++
>  testsuites/samples/pwm/init.c                |  70 ++++++
>  testsuites/samples/pwm/pwm.doc               |   9 +
>  testsuites/samples/pwm/pwm.scn               |   3 +
>  10 files changed, 810 insertions(+), 2 deletions(-)
>  create mode 100644 c/src/lib/libbsp/arm/beagle/pwm/bbb-pwm.c
>  create mode 100644 testsuites/samples/pwm/Makefile.am
>  create mode 100644 testsuites/samples/pwm/init.c
>  create mode 100644 testsuites/samples/pwm/pwm.doc
>  create mode 100644 testsuites/samples/pwm/pwm.scn
> diff --git a/c/src/lib/libbsp/arm/beagle/Makefile.am
> b/c/src/lib/libbsp/arm/beagle/Makefile.am
> index 20d3092..68bdbd4 100644
> --- a/c/src/lib/libbsp/arm/beagle/Makefile.am
> +++ b/c/src/lib/libbsp/arm/beagle/Makefile.am
> @@ -117,6 +117,9 @@ libbsp_a_SOURCES += misc/i2c.c
>  # GPIO
>  libbsp_a_SOURCES += gpio/bbb-gpio.c
> +#pwm
> +libbsp_a_SOURCES += pwm/bbb-pwm.c
>  #RTC
>  libbsp_a_SOURCES += rtc.c
>  libbsp_a_SOURCES += ../../shared/tod.c
> diff --git a/c/src/lib/libbsp/arm/beagle/pwm/bbb-pwm.c
> b/c/src/lib/libbsp/arm/beagle/pwm/bbb-pwm.c
> new file mode 100644
> index 0000000..a2f1107
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/beagle/pwm/bbb-pwm.c
> @@ -0,0 +1,345 @@
> +/* This file is based on following licence
> + * Copyright (c) 2015, Shabaz, VegetableAvenger
> + * Copyright (c) 2016, Punit Vara
> + * Added clock functions and improved pwm_enable function
> + * All rights reserved.
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions are
> met:
> + * Redistributions of source code must retain the above copyright notice,
> this
> + * list of conditions and the following disclaimer.
> + * Redistributions in binary form must reproduce the above copyright
> notice,
> + * this list of conditions and the following disclaimer in the
> documentation
> + * and/or other materials provided with the distribution.
> + * Neither the name of BBBIOlib nor the names of its
> + * contributors may be used to endorse or promote products derived from
> + * this software without specific prior written permission.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE ARE
> + * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
> LIABLE
> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> CONSEQUENTIAL
> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE
> GOODS OR
> + * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
> HOWEVER
> + * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
> LIABILITY,
> + * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF
> THE USE
> + * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
> +#include<libcpu/am335x.h>
> +#include<stdio.h>
> +#include<bsp/gpio.h>
> +#include<bsp/bbb-gpio.h>
> +#include<bsp.h>
> +#define BASE_CLOCK 100000000
> + * @brief This function intilize clock and pinmuxing for pwm sub system.
> + * @param PWMSS_ID It is the instance number of EPWM of pwm sub system.
> +void pwm_init(unsigned int baseAddr, unsigned int PWMSS_ID)
> +  module_clk_config(PWMSS_ID);
> +  EPWMPinMuxSetup();
> +  EPWM_clock_enable(baseAddr);
> +  pwmss_tbclk_enable(PWMSS_ID);
> + * \brief   This function Enables TBCLK(Time Base Clock) for specific
> + *          EPWM instance of pwmsubsystem.
> + * \param   instance  It is the instance number of EPWM of pwmsubsystem.
> +void pwmss_tbclk_enable(unsigned int instance)
> +       switch(instance)
> +               case 0:
> +                       REG(AM335X_PADCONF_BASE + CONTROL_PWMSS_CTRL) |=
> +                               BBBIO_PWMSS_CTRL_PWMSS0_TBCLKEN;
> +                       break;
> +               case 1:
> +                               BBBIO_PWMSS_CTRL_PWMSS1_TBCLKEN;
> +                       break;
> +               case 2:
> +                               BBBIO_PWMSS_CTRL_PWMSS2_TBCLKEN;
> +                       break;
> +               default:
> +                       break;
> + * \brief   This function Enables pinmuxing for PWM module.
> +void EPWMPinMuxSetup(void)
> +  REG(AM335X_PADCONF_BASE + CONTROL_CONF_GPMC_AD(9)) = BBB_MUXMODE(4);
> +  REG(AM335X_PADCONF_BASE + CONTROL_CONF_GPMC_AD(8)) = BBB_MUXMODE(4);
> +  REG(AM335X_PADCONF_BASE + CONTROL_CONF_LCD_DATA(0)) = BBB_MUXMODE(3);
> +  REG(AM335X_PADCONF_BASE + CONTROL_CONF_LCD_DATA(1)) = BBB_MUXMODE(3);
> +  REG(AM335X_PADCONF_BASE + CONTROL_CONF_LCD_DATA(11)) = BBB_MUXMODE(2);
> +  REG(AM335X_PADCONF_BASE + CONTROL_CONF_LCD_DATA(10)) = BBB_MUXMODE(2);
> +  REG(AM335X_PADCONF_BASE + CONTROL_CONF_GPMC_AD(2)) = BBB_MUXMODE(6);
> +  REG(AM335X_PADCONF_BASE + CONTROL_CONF_GPMC_AD(3)) = BBB_MUXMODE(6);
> +  REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_D0) = BBB_MUXMODE(3);
> +  REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_SCLK) = BBB_MUXMODE(3);
> +  REG(AM335X_PADCONF_BASE + AM335X_CONF_MCASP0_FSX) = BBB_MUXMODE(1);
> +  REG(AM335X_PADCONF_BASE + AM335X_CONF_MCASP0_ACLKX) = BBB_MUXMODE(1);
> + * \brief   This functions enables clock for EHRPWM module in PWMSS
> subsystem.
> + * \param   baseAdd   It is the Memory address of the PWMSS instance used.
> + * \return  None.
> +void EPWM_clock_enable(unsigned int baseAdd)
> +       REG(baseAdd + PWMSS_CLKCONFIG) |= PWMSS_CLK_EN_ACK;
> + * \brief   This function configures the L3 and L4_PER system clocks.
> + *          It also configures the system clocks for the specified ePWMSS
> + *          instance.
> + * \param   instanceNum    The instance number of ePWMSS whose system
> clocks
> + *                         have to be configured.
> + * 'instanceNum' can take one of the following values:
> + * (0 <= instanceNum <= 2)
> + * \return  None.
> +void module_clk_config(unsigned int instanceNum)
> +       if(0 == instanceNum)
> +               REG(BBBIO_CM_PER_ADDR + CM_PER_EPWMSS0_CLKCTRL) |=
> +                       CM_PER_EPWMSS0_CLKCTRL_MODULEMODE_ENABLE;
> +       else if(1 == instanceNum)
> +               REG(BBBIO_CM_PER_ADDR + CM_PER_EPWMSS1_CLKCTRL) |=
> +                       CM_PER_EPWMSS1_CLKCTRL_MODULEMODE_ENABLE;
> +       else if(2 == instanceNum)
> +               REG(BBBIO_CM_PER_ADDR + CM_PER_EPWMSS2_CLKCTRL) |=
> +                       CM_PER_EPWMSS2_CLKCTRL_MODULEMODE_ENABLE;
> +       else
> + * \brief   This API enables the particular PWM module.
> + * \param   baseAddr    Base Address of the PWM Module Registers.
> + * \return  None
> +void ehrPWM_Enable(unsigned int baseAddr)
> +       REG16(baseAddr + EHRPWM_AQCTLA) = 0x2 | (0x3 << 4);
> +       REG16(baseAddr + EHRPWM_AQCTLB) = 0x2 | (0x3 << 8);
> +       REG16(baseAddr + EHRPWM_TBCNT) = 0;
> +       REG16(baseAddr + EHRPWM_TBCTL) |=  TBCTL_FREERUN  |
> TBCTL_CTRMODE_UP;
> + * \brief   This API disables the HR sub-module.
> + * \return  None
> +void ehrPWM_Disable(unsigned int baseAddr)
> +       REG16(baseAddr + EHRPWM_TBCTL) = 0x3;
> +       REG16(baseAddr + EHRPWM_AQCTLA) = 0x1 | ( 0x3 << 4 );
> +       REG16(baseAddr + EHRPWM_AQCTLB) = 0x1 | ( 0x3 << 8 );
> +/* PWMSS setting
> + *      set pulse argument of epwm module
> + *      @param PWMID    : EPWMSS number , 0~2
> + *      @param HZ       : pulse HZ
> + *      @param dutyA    : Duty Cycle in ePWM A
> + *      @param dutyB    : Duty Cycle in ePWM B
> + *      @return         : 1 for success , 0 for failed
> + *      @example        :  PWMSS_Setting(0 , 50.0f , 50.0f , 25.0f);
> // Generate 50HZ pwm in PWM0 ,
>       // duty cycle is 50% for ePWM0A , 25% for ePWM0B
> + *      @Note :
> + *              find an number nearst 65535 for TBPRD , to improve duty
> precision,
> + *              Using big TBPRD can increase the range of CMPA and CMPB ,
> + *              and it means we can get better precision on duty cycle.
> + *              EX : 20.25% duty cycle
> + *                  on TBPRD = 62500 , CMPA = 12656.25 ( .25 rejection) ,
> real duty : 20.2496% (12656 /62500)
> + *                  on TBPRD = 6250  , CMPA = 1265.625 ( .625 rejection),
> real duty : 20.24%   (1265 6250)
> + *                  on TBPRD = 500   , CMPA = 101.25   ( .25 rejection) ,
> real duty : 20.2%    (101/500)
> + *              Divisor = CLKDIV * HSPCLKDIV
> + *                      1 TBPRD : 10 ns (default)
> + *                      65535 TBPRD : 655350 ns
> + *                      65535 TBPRD : 655350 * Divisor ns  = X TBPRD :
> Cyclens
> + *              accrooding to that , we must find a Divisor value , let X
> nearest 65535 .
> + *              so , Divisor must  Nearest Cyclens/655350
> +int PWMSS_Setting(unsigned int baseAddr, float HZ, float dutyA, float
> dutyB)
> +       unsigned int  z,p,y;
> +       int param_error =1;
> +       if(HZ < 0)
> +               param_error =0;
> +       if(dutyA < 0.0f || dutyA > 100.0f || dutyB < 0.0f || dutyB >
> 100.0f)
> +               param_error = 0;
> +       if(param_error == 0) {
> +               printf("ERROR in parameter \n");
> +       dutyA /= 100.0f;
> +       dutyB /= 100.0f;
> +       /*Compute necessary TBPRD*/
> +       float Cyclens = 0.0f;
> +       float Divisor =0;
> +       int i,j;
> +       const float CLKDIV_div[] = {1.0,2.0,4.0,8.0,16.0,32.0,64.0,128.0};
> +       const float HSPCLKDIV_div[] = {1.0, 2.0, 4.0, 6.0, 8.0, 10.0,12.0,
> 14.0};
> +       int NearCLKDIV =7;
> +       int NearHSPCLKDIV =7;
> +       int NearTBPRD =0;
> +       Cyclens = 1000000000.0f / HZ; /** 10^9 /Hz compute time per cycle
> (ns)
> +       Divisor = (Cyclens / 655350.0f);  /** am335x provide (128* 14)
> divider,
> +                                          *  and per TBPRD means 10ns
> when divider
> +                                          *  and max TBPRD is 65535 so
> max cycle
> +                                          *  is 128 * 8 * 14 * 65535 *
> 10ns
> +       if(Divisor > (128 * 14)) {
> +               printf("Can't generate %f HZ",HZ);
> +               return 0;
> +       else {
> +               for (i=0;i<8;i++) {
> +                       for(j=0 ; j<8; j++) {
> +                               if((CLKDIV_div[i] * HSPCLKDIV_div[j]) <
> (CLKDIV_div[NearCLKDIV]
> HSPCLKDIV_div[NearHSPCLKDIV]) && (CLKDIV_div[i] * HSPCLKDIV_div[j] >
> Divisor)) {
> +                                       NearCLKDIV = i;
> +                                       NearHSPCLKDIV = j;
> +               printf("BBBIO CLKDIV = %d and HSPCLKDIV =
> %d\n",NearCLKDIV,NearHSPCLKDIV);
> +                REG16(baseAddr + EHRPWM_TBCTL) &= ~(TBCTL_CLKDIV_MASK |
> TBCTL_HSPCLKDIV_MASK);
> +               REG16(baseAddr + EHRPWM_TBCTL) = (REG16(baseAddr +
> EHRPWM_TBCTL) &
> +                (~EHRPWM_TBCTL_CLKDIV)) | ((NearCLKDIV <<
> TBCTL_CLKDIV_SHIFT) & EHRPWM_TBCTL_CLKDIV);
> EHRPWM_TBCTL) &
> +                (~EHRPWM_TBCTL_HSPCLKDIV)) | ((NearHSPCLKDIV <<
> +                TBCTL_HSPCLKDIV_SHIFT) & EHRPWM_TBCTL_HSPCLKDIV);
> +               NearTBPRD = (Cyclens / (10.0 * CLKDIV_div[NearCLKDIV] *
> HSPCLKDIV_div[NearHSPCLKDIV]));
> EHRPWM_TBCTL) &
> +                (~EHRPWM_PRD_LOAD_SHADOW_MASK)) |
> (((bool)EHRPWM_SHADOW_WRITE_DISABLE <<
> +                EHRPWM_TBCTL_PRDLD_SHIFT) & EHRPWM_PRD_LOAD_SHADOW_MASK);
> EHRPWM_TBCTL) &
> +                (~EHRPWM_COUNTER_MODE_MASK)) | (((unsigned
> int)EHRPWM_COUNT_UP <<
> +                EHRPWM_TBCTL_CTRMODE_SHIFT) &  EHRPWM_COUNTER_MODE_MASK);
> +               printf("writing TBPRD = %x \n",NearTBPRD);
> +               /*setting clock divider and freeze time base*/
> +       //      configure_tbclk(baseAddr, HZ);
> +               REG16(baseAddr + EHRPWM_CMPB) = (unsigned
> short)((float)(NearTBPRD) * dutyB);
> +               z = REG16(baseAddr + EHRPWM_CMPB);
> +               printk("read CMPB = %x\t",z);
> +               REG16(baseAddr + EHRPWM_CMPA) = (unsigned
> short)((float)(NearTBPRD) * dutyA);
> +               p = REG16(baseAddr + EHRPWM_CMPA);
> +               printk("read CMPA = %x\n",p);
> +               REG16(baseAddr + EHRPWM_TBPRD) = (unsigned short)NearTBPRD;
> +               y = REG16(baseAddr + EHRPWM_TBPRD);
> +               printk("TBPRD read = %x \n",y);
> +               printf("\nfinished setting \n");
> +       return 1;
> +int PWMSS_TB_clock_check(unsigned int PWMSS_ID)
> +       unsigned int reg_value,value;
> +       /*control module check*/
> +       reg_value = REG(BBBIO_CONTROL_MODULE + BBBIO_PWMSS_CTRL);
> +       value = reg_value & (1 << PWMSS_ID);
> +       printf("\n PWMSS_CTRL =  %d and reg_value = %d
> \n",value,reg_value);
> +       return (reg_value & (1 << PWMSS_ID));
> diff --git a/c/src/lib/libbsp/shared/include/gpio.h
> b/c/src/lib/libbsp/shared/include/gpio.h
> index 7d8f67b..2a89f1d 100644
> --- a/c/src/lib/libbsp/shared/include/gpio.h
> +++ b/c/src/lib/libbsp/shared/include/gpio.h
> @@ -947,6 +947,17 @@ extern rtems_status_code
> rtems_gpio_bsp_disable_interrupt(
> +extern void pwmss_tbclk_enable(unsigned int instance);
> +extern void EPWM_clock_enable(unsigned int baseAdd);
> +extern void module_clk_config(unsigned int instanceNum);
> +extern void EPWMPinMuxSetup(void);
> +extern int PWMSS_Setting(unsigned int baseAddr, float HZ, float dutyA,
> float dutyB);
> +extern void ehrPWM_Disable(unsigned int baseAddr);
> +extern void ehrPWM_Enable(unsigned int baseAddr);
> +extern int PWMSS_TB_clock_check(unsigned int PWMSS_ID);
> +extern void pwm_init(unsigned int baseAddr, unsigned int PWMSS_ID);
>  #ifdef __cplusplus
>  #endif /* __cplusplus */
> diff --git a/c/src/lib/libcpu/arm/shared/include/am335x.h
> b/c/src/lib/libcpu/arm/shared/include/am335x.h
> index 2009cef..b89a188 100644
> --- a/c/src/lib/libcpu/arm/shared/include/am335x.h
> +++ b/c/src/lib/libcpu/arm/shared/include/am335x.h
> @@ -467,4 +467,351 @@
>  #define AM335X_CONF_EXT_WAKEUP 0xA00
>  #define AM335X_CONF_RTC_KALDO_ENN 0xA04
>  #define AM335X_CONF_USB0_DRVVBUS 0xA1C
> -#define AM335X_CONF_USB1_DRVVBUS 0xA34
> \ No newline at end of file
> +#define AM335X_CONF_USB1_DRVVBUS 0xA34
> +/* Added by punit vara
> +   PWMSS register definitions */
> +#define PWMSS_CLOCK_CONFIG               0x08
Remove these kind of white spaces ....
> +#define PWMSS_CLOCK_STATUS               0x0C
For processor specific macros you can follow the convention like
AM335X_GPIO0_BASE
This would be more convenient to developer for debugging/developing purpose.
Kindly follow the same whenever you define macros to processor specific
file.
> +#define PWMSS_ECAP_CLK_EN_ACK_SHIFT      0x00
> +#define PWMSS_ECAP_CLK_STOP_ACK_SHIFT    0x01
> +#define PWMSS_EHRPWM_CLK_EN_ACK_SHIFT    0x08
> +#define PWMSS_EHRPWM_CLK_STOP_ACK_SHIFT  0x09
> +#define PWMSS_ECAP_CLK_EN_ACK            0x01
> +#define PWMSS_ECAP_CLK_STOP_ACK          0x02
> +#define PWMSS_EHRPWM_CLK_EN_ACK          0x100
> +#define PWMSS_EHRPWM_CLK_STOP_ACK        0x200
Also try to follow standard conventions along with proper indentation.
> +/** @brief Base addresses of PWMSS memory mapped registers.
> +#define SOC_PWMSS0_REGS                     (0x48300000)
> +#define SOC_PWMSS1_REGS                     (0x48302000)
> +#define SOC_PWMSS2_REGS                     (0x48304000)
> +#define SOC_ECAP_REGS                       (0x00000100)
> +#define SOC_EQEP_REGS                       (0x00000180)
> +#define SOC_EPWM_REGS                       (0x00000200)
> +#define SOC_ECAP_0_REGS                     (SOC_PWMSS0_REGS +
> SOC_ECAP_REGS)
> +#define SOC_ECAP_1_REGS                     (SOC_PWMSS1_REGS +
> SOC_ECAP_REGS)
> +#define SOC_ECAP_2_REGS                     (SOC_PWMSS2_REGS +
> SOC_ECAP_REGS)
> +#define SOC_EQEP_0_REGS                     (SOC_PWMSS0_REGS +
> SOC_EQEP_REGS)
> +#define SOC_EQEP_1_REGS                     (SOC_PWMSS1_REGS +
> SOC_EQEP_REGS)
> +#define SOC_EQEP_2_REGS                     (SOC_PWMSS2_REGS +
> SOC_EQEP_REGS)
> +#define SOC_EPWM_0_REGS                     (SOC_PWMSS0_REGS +
> SOC_EPWM_REGS)
> +#define SOC_EPWM_1_REGS                     (SOC_PWMSS1_REGS +
> SOC_EPWM_REGS)
> +#define SOC_EPWM_2_REGS                     (SOC_PWMSS2_REGS +
> SOC_EPWM_REGS)
> +#define CONTROL_PWMSS_CTRL   (0x664)
> +#define CONTROL_PWMSS_CTRL_PWMSS0_TBCLKEN   (0x00000001u)
> +#define CONTROL_PWMSS_CTRL_PWMMS1_TBCLKEN   (0x00000002u)
> +#define CONTROL_PWMSS_CTRL_PWMSS2_TBCLKEN   (0x00000004u)
> +#define SOC_PRCM_REGS                        (0x44E00000)
> +#define CM_PER_EPWMSS0_CLKCTRL   (0xd4)
> +#define CM_PER_EPWMSS0_CLKCTRL_MODULEMODE_ENABLE   (0x2u)
> +#define CM_PER_EPWMSS0_CLKCTRL_IDLEST_FUNC   (0x0u)
> +#define CM_PER_EPWMSS0_CLKCTRL_IDLEST_SHIFT   (0x00000010u)
> +#define CM_PER_EPWMSS0_CLKCTRL_IDLEST   (0x00030000u)
> +#define CM_PER_EPWMSS1_CLKCTRL   (0xcc)
> +#define CM_PER_EPWMSS1_CLKCTRL_MODULEMODE_ENABLE   (0x2u)
> +#define CM_PER_EPWMSS1_CLKCTRL_MODULEMODE   (0x00000003u)
> +#define CM_PER_EPWMSS1_CLKCTRL_IDLEST_FUNC   (0x0u)
> +#define CM_PER_EPWMSS1_CLKCTRL_IDLEST_SHIFT   (0x00000010u)
> +#define CM_PER_EPWMSS1_CLKCTRL_IDLEST   (0x00030000u)
> +/* TBCTL */
This comment could be more descriptive .
> +#define EHRPWM_TBCTL_FREE_SOFT  (0xC000u)
> +#define EHRPWM_TBCTL_FREE_SOFT_SHIFT (0x000Eu)
> +#define EHRPWM_TBCTL_PHSDIR     (0x2000u)
> +#define EHRPWM_TBCTL_PHSDIR_SHIFT    (0x000Du)
> +#define EHRPWM_TBCTL_CLKDIV     (0x1C00u)
> +#define EHRPWM_TBCTL_CLKDIV_SHIFT    (0x000Au)
> +#define EHRPWM_TBCTL_CLKDIV_DIVBY1   (0x0000u)
> +#define EHRPWM_TBCTL_CLKDIV_DIVBY2   (0x0001u)
> +#define EHRPWM_TBCTL_CLKDIV_DIVBY4   (0x0002u)
> +#define EHRPWM_TBCTL_CLKDIV_DIVBY8   (0x0003u)
> +#define EHRPWM_TBCTL_CLKDIV_DIVBY16  (0x0004u)
> +#define EHRPWM_TBCTL_CLKDIV_DIVBY32  (0x0005u)
> +#define EHRPWM_TBCTL_CLKDIV_DIVBY64  (0x0006u)
> +#define EHRPWM_TBCTL_CLKDIV_DIVBY128 (0x0007u)
> +#define EHRPWM_TBCTL_HSPCLKDIV  (0x0380u)
> +#define EHRPWM_TBCTL_HSPCLKDIV_SHIFT (0x0007u)
> +#define EHRPWM_TBCTL_HSPCLKDIV_DIVBY1 (0x0000u)
> +#define EHRPWM_TBCTL_HSPCLKDIV_DIVBY2 (0x0001u)
> +#define EHRPWM_TBCTL_HSPCLKDIV_DIVBY4 (0x0002u)
> +#define EHRPWM_TBCTL_HSPCLKDIV_DIVBY6 (0x0003u)
> +#define EHRPWM_TBCTL_HSPCLKDIV_DIVBY8 (0x0004u)
> +#define EHRPWM_TBCTL_HSPCLKDIV_DIVBY10 (0x0005u)
> +#define EHRPWM_TBCTL_HSPCLKDIV_DIVBY12 (0x0006u)
> +#define EHRPWM_TBCTL_HSPCLKDIV_DIVBY14 (0x0007u)
> +#define EHRPWM_TBCTL_SWFSYNC    (0x0040u)
> +#define EHRPWM_TBCTL_SWFSYNC_SHIFT   (0x0006u)
> +#define EHRPWM_TBCTL_SYNCOSEL   (0x0030u)
> +#define EHRPWM_TBCTL_SYNCOSEL_SHIFT  (0x0004u)
> +#define EHRPWM_TBCTL_SYNCOSEL_EPWMXSYNCI (0x0000u)
> +#define EHRPWM_TBCTL_SYNCOSEL_TBCTRZERO (0x0001u)
> +#define EHRPWM_TBCTL_SYNCOSEL_TBCTRCMPB (0x0002u)
> +#define EHRPWM_TBCTL_SYNCOSEL_DISABLE   (0x0003u)
> +#define EHRPWM_TBCTL_PRDLD      (0x0008u)
> +#define EHRPWM_TBCTL_PRDLD_SHIFT     (0x0003u)
> +#define EHRPWM_TBCTL_PHSEN      (0x0004u)
> +#define EHRPWM_TBCTL_PHSEN_SHIFT     (0x0002u)
> +#define EHRPWM_TBCTL_CTRMODE    (0x0003u)
> +#define EHRPWM_TBCTL_CTRMODE_SHIFT   (0x0000u)
> +#define EHRPWM_TBCTL_CTRMODE_UP      (0x0000u)
> +#define EHRPWM_TBCTL_CTRMODE_DOWN    (0x0001u)
> +#define EHRPWM_TBCTL_CTRMODE_UPDOWN  (0x0002u)
> +#define EHRPWM_TBCTL_CTRMODE_STOPFREEZE (0x0003u)
> +/* TBPRD */
> +#define EHRPWM_TBPRD_TBPRD      (0xFFFFu)
> +#define EHRPWM_TBPRD_TBPRD_SHIFT     (0x0000u)
> +/* CMPA */
> +#define EHRPWM_CMPA_CMPA        (0xFFFFu)
> +#define EHRPWM_CMPA_CMPA_SHIFT       (0x0000u)
> +/* CMPB */
Try to make all these comments as descriptive as possible.
> +#define EHRPWM_CMPB_CMPB        (0xFFFFu)
> +#define EHRPWM_CMPB_CMPB_SHIFT       (0x0000u)
> +/* REVID */
> +#define EHRPWM_REVID_REV        (0xFFFFFFFFu)
> +#define EHRPWM_REVID_REV_SHIFT       (0x00000000u)
> +#define EHRPWM_TBCTL            (0x0)
> +#define EHRPWM_TBSTS            (0x2)
> +#define EHRPWM_TBPHSHR          (0x4)
> +#define EHRPWM_TBPHS            (0x6)
> +#define EHRPWM_TBCTR            (0x8)
> +#define EHRPWM_TBPRD            (0xA)
> +#define EHRPWM_CMPCTL           (0xE)
> +#define EHRPWM_CMPAHR           (0x10)
> +#define EHRPWM_CMPA             (0x12)
> +#define EHRPWM_CMPB             (0x14)
> +#define EHRPWM_AQCTLA           (0x16)
> +#define EHRPWM_AQCTLB           (0x18)
> +#define EHRPWM_AQSFRC           (0x1A)
> +#define EHRPWM_AQCSFRC          (0x1C)
> +#define EHRPWM_DBCTL            (0x1E)
> +#define EHRPWM_DBRED            (0x20)
> +#define EHRPWM_DBFED            (0x22)
> +#define EHRPWM_TZSEL            (0x24)
> +#define EHRPWM_TZCTL            (0x28)
> +#define EHRPWM_TZEINT           (0x2A)
> +#define EHRPWM_TZFLG            (0x2C)
> +#define EHRPWM_TZCLR            (0x2E)
> +#define EHRPWM_TZFRC            (0x30)
> +#define EHRPWM_ETSEL            (0x32)
> +#define EHRPWM_ETPS             (0x34)
> +#define EHRPWM_ETFLG            (0x36)
> +#define EHRPWM_ETCLR            (0x38)
> +#define EHRPWM_ETFRC            (0x3A)
> +#define EHRPWM_PCCTL            (0x3C)
> +#define EHRPWM_HRCNFG           (0x1040)
> +/* TB Period load */
> +#define EHRPWM_PRD_LOAD_SHADOW_MASK             EHRPWM_TBCTL_PRDLD
> +/* Counter mode */
> +#define EHRPWM_COUNTER_MODE_MASK                EHRPWM_TBCTL_CTRMODE
> +#define EHRPWM_COUNT_UP                         (EHRPWM_TBCTL_CTRMODE_UP
> +#define EHRPWM_COUNT_DOWN
>  (EHRPWM_TBCTL_CTRMODE_DOWN << \
> +#define EHRPWM_COUNT_UP_DOWN
> (EHRPWM_TBCTL_CTRMODE_UPDOWN << \
> +#define EHRPWM_COUNT_STOP
>  (EHRPWM_TBCTL_CTRMODE_STOPFREEZE << \
> +/* Synchronization */
> +#define EHRPWM_SYNC_ENABLE                      EHRPWM_TBCTL_PHSEN
> +//#define EHRPWM_SW_FORCED_SYNC                 0x1
> +#define EHRPWM_SYNCOUT_MASK                     EHRPWM_TBCTL_SYNCOSEL
> +#define EHRPWM_SYNCOUT_SYNCIN
>  (EHRPWM_TBCTL_SYNCOSEL_EPWMXSYNCI << \
> EHRPWM_TBCTL_SYNCOSEL_SHIFT)
> +#define EHRPWM_SYNCOUT_COUNTER_EQUAL_ZERO
>  (EHRPWM_TBCTL_SYNCOSEL_TBCTRZERO << \
> +#define EHRPWM_SYNCOUT_COUNTER_EQUAL_COMPAREB
>  (EHRPWM_TBCTL_SYNCOSEL_TBCTRCMPB << \
> +#define EHRPWM_SYNCOUT_DISABLE
> (EHRPWM_TBCTL_SYNCOSEL_DISABLE << \
> +/* Shadow */
> +#define EHRPWM_SHADOW_WRITE_ENABLE              0x0
> +#define EHRPWM_SHADOW_WRITE_DISABLE             0x1
> +/* Time base clock */
> +#define EHRPWM_TBCTL_CLKDIV_1                   (0x0001u)
> +#define EHRPWM_TBCTL_CLKDIV_2                   (0x0002u)
> +#define EHRPWM_TBCTL_CLKDIV_4                   (0x0004u)
> +#define EHRPWM_TBCTL_CLKDIV_8                   (0x0008u)
> +#define EHRPWM_TBCTL_CLKDIV_16                  (0x0010u)
> +#define EHRPWM_TBCTL_CLKDIV_32                  (0x0020u)
> +#define EHRPWM_TBCTL_CLKDIV_64                  (0x0040u)
> +#define EHRPWM_TBCTL_CLKDIV_128                 (0x0080u)
> +#define EHRPWM_TBCTL_HSPCLKDIV_1                (0x0001u)
> +#define EHRPWM_TBCTL_HSPCLKDIV_2                (0x0002u)
> +#define EHRPWM_TBCTL_HSPCLKDIV_4                (0x0004u)
> +#define EHRPWM_TBCTL_HSPCLKDIV_6                (0x0006u)
> +#define EHRPWM_TBCTL_HSPCLKDIV_8                (0x0008u)
> +#define EHRPWM_TBCTL_HSPCLKDIV_10               (0x000Au)
> +#define EHRPWM_TBCTL_HSPCLKDIV_12               (0x000Cu)
> +#define EHRPWM_TBCTL_HSPCLKDIV_14               (0x000Eu)
> +/* Count direction after sync */
> +#define EHRPWM_COUNT_DOWN_AFTER_SYNC            0x0
> +#define EHRPWM_COUNT_UP_AFTER_SYNC              0x1
> +/* Counter Compare */
> +#define EHRPWM_SHADOW_A_EMPTY                   (0x0 <<
> EHRPWM_CMPCTL_SHDWAFULL_SHIFT)
> +#define EHRPWM_SHADOW_A_FULL                    (EHRPWM_CMPCTL_SHDWAFULL)
> +#define EHRPWM_SHADOW_B_EMPTY                   (0x0 <<
> EHRPWM_CMPCTL_SHDWBFULL_SHIFT)
> +#define EHRPWM_SHADOW_B_FULL                    (EHRPWM_CMPCTL_SHDWBFULL)
> +#define EHRPWM_CMPCTL_NOT_OVERWR_SH_FL          0x0
> +#define EHRPWM_CMPCTL_OVERWR_SH_FL              0x1
> +/* Compare register load */
> +#define EHRPWM_COMPB_LOAD_MASK                  EHRPWM_CMPCTL_LOADBMODE
> +#define EHRPWM_COMPB_LOAD_COUNT_EQUAL_ZERO
> (EHRPWM_CMPCTL_LOADBMODE_TBCTRZERO << \
> EHRPWM_CMPCTL_LOADBMODE_SHIFT)
> +#define EHRPWM_COMPB_LOAD_COUNT_EQUAL_PERIOD
> (EHRPWM_CMPCTL_LOADBMODE_TBCTRPRD << \
> +#define EHRPWM_COMPB_LOAD_COUNT_EQUAL_ZERO_OR_PERIOD \
> (EHRPWM_CMPCTL_LOADBMODE_ZEROORPRD << \
> +#define EHRPWM_COMPB_NO_LOAD
> (EHRPWM_CMPCTL_LOADBMODE_FREEZE << \
> +#define EHRPWM_COMPA_LOAD_MASK                  EHRPWM_CMPCTL_LOADAMODE
> +#define EHRPWM_COMPA_LOAD_COUNT_EQUAL_ZERO
> (EHRPWM_CMPCTL_LOADAMODE_TBCTRZERO << \
> EHRPWM_CMPCTL_LOADAMODE_SHIFT)
> +#define EHRPWM_COMPA_LOAD_COUNT_EQUAL_PERIOD
> (EHRPWM_CMPCTL_LOADAMODE_TBCTRPRD << \
> +#define EHRPWM_COMPA_LOAD_COUNT_EQUAL_ZERO_OR_PERIOD \
> (EHRPWM_CMPCTL_LOADAMODE_ZEROORPRD << \
> +#define EHRPWM_COMPA_NO_LOAD
> (EHRPWM_CMPCTL_LOADAMODE_FREEZE << \
> +#define CM_PER_EPWMSS2_CLKCTRL   (0xd8)
> +/* EPWMSS1_CLKCTRL */
> +#define CM_PER_EPWMSS1_CLKCTRL_IDLEST_DISABLE   (0x3u)
> +#define CM_PER_EPWMSS1_CLKCTRL_IDLEST_IDLE   (0x2u)
> +#define CM_PER_EPWMSS1_CLKCTRL_IDLEST_TRANS   (0x1u)
> +#define CM_PER_EPWMSS1_CLKCTRL_MODULEMODE_SHIFT   (0x00000000u)
> +#define CM_PER_EPWMSS1_CLKCTRL_MODULEMODE_DISABLED   (0x0u)
> +#define CM_PER_EPWMSS1_CLKCTRL_MODULEMODE_RESERVED   (0x3u)
> +#define CM_PER_EPWMSS1_CLKCTRL_MODULEMODE_RESERVED_1   (0x1u)
> +/* EPWMSS0_CLKCTRL */
> +#define CM_PER_EPWMSS0_CLKCTRL_IDLEST_DISABLED   (0x3u)
> +#define CM_PER_EPWMSS0_CLKCTRL_IDLEST_IDLE   (0x2u)
> +#define CM_PER_EPWMSS0_CLKCTRL_IDLEST_TRANS   (0x1u)
> +#define CM_PER_EPWMSS0_CLKCTRL_MODULEMODE   (0x00000003u)
> +#define CM_PER_EPWMSS0_CLKCTRL_MODULEMODE_SHIFT   (0x00000000u)
> +#define CM_PER_EPWMSS0_CLKCTRL_MODULEMODE_DISABLE   (0x0u)
> +#define CM_PER_EPWMSS0_CLKCTRL_MODULEMODE_RESERVED   (0x3u)
> +#define CM_PER_EPWMSS0_CLKCTRL_MODULEMODE_RESERVED_1   (0x1u)
> +/* EPWMSS2_CLKCTRL */
> +#define CM_PER_EPWMSS2_CLKCTRL_IDLEST   (0x00030000u)
> +#define CM_PER_EPWMSS2_CLKCTRL_IDLEST_SHIFT   (0x00000010u)
> +#define CM_PER_EPWMSS2_CLKCTRL_IDLEST_DISABLE   (0x3u)
> +#define CM_PER_EPWMSS2_CLKCTRL_IDLEST_FUNC   (0x0u)
> +#define CM_PER_EPWMSS2_CLKCTRL_IDLEST_IDLE   (0x2u)
> +#define CM_PER_EPWMSS2_CLKCTRL_IDLEST_TRANS   (0x1u)
> +#define CM_PER_EPWMSS2_CLKCTRL_MODULEMODE   (0x00000003u)
> +#define CM_PER_EPWMSS2_CLKCTRL_MODULEMODE_SHIFT   (0x00000000u)
> +#define CM_PER_EPWMSS2_CLKCTRL_MODULEMODE_DISABLED   (0x0u)
> +#define CM_PER_EPWMSS2_CLKCTRL_MODULEMODE_ENABLE   (0x2u)
> +#define CM_PER_EPWMSS2_CLKCTRL_MODULEMODE_RESERVED   (0x3u)
> +#define CM_PER_EPWMSS2_CLKCTRL_MODULEMODE_RESERVED_1   (0x1u)
> +#define CONTROL_CONF_GPMC_AD(n)   (0x800 + (n * 4))
> +#define CONTROL_CONF_LCD_DATA(n)   (0x8a0 + (n * 4))
> +#define EHRPWM_TBCNT   0x8
> +#define BBBIO_CONTROL_MODULE 0x44e10000
> +#define BBBIO_PWMSS_CTRL     0x664
> +#define BBBIO_CM_PER_ADDR    0x44e00000
> +#define BBBIO_CM_PER_EPWMSS1_CLKCTRL 0xcc
> +#define BBBIO_CM_PER_EPWMSS0_CLKCTRL 0xd4
> +#define BBBIO_CM_PER_EPWMSS2_CLKCTRL 0xd8
> +#define PWMSS0_MMAP_ADDR       0x48300000
> +#define PWMSS1_MMAP_ADDR       0x48302000
> +#define PWMSS2_MMAP_ADDR       0x48304000
> +#define BBBIO_PWMSS_CTRL_PWMSS0_TBCLKEN   (0x00000001u)
> +#define BBBIO_PWMSS_CTRL_PWMSS1_TBCLKEN   (0x00000002u)
> +#define BBBIO_PWMSS_CTRL_PWMSS2_TBCLKEN   (0x00000004u)
> +#define PWMSS_CLKCONFIG        0x8
> +#define PWMSS_CLK_EN_ACK          0x100
> +#define TBCTL_CLKDIV     (0x1C00u)
> +#define TBCTL_CLKDIV_SHIFT    (0x000Au)
> +#define TBCTL_CLKDIV_DIVBY1   (0x0000u)
> +#define TBCTL_CLKDIV_DIVBY2   (0x0001u)
> +#define TBCTL_CLKDIV_DIVBY4   (0x0002u)
> +#define TBCTL_CLKDIV_DIVBY8   (0x0003u)
> +#define TBCTL_CLKDIV_DIVBY16  (0x0004u)
> +#define TBCTL_CLKDIV_DIVBY32  (0x0005u)
> +#define TBCTL_CLKDIV_DIVBY64  (0x0006u)
> +#define TBCTL_CLKDIV_DIVBY128 (0x0007u)
> +#define TBCTL_HSPCLKDIV  (0x0380u)
> +#define TBCTL_HSPCLKDIV_SHIFT (0x0007u)
> +#define TBCTL_HSPCLKDIV_DIVBY1 (0x0000u)
> +#define TBCTL_HSPCLKDIV_DIVBY2 (0x0001u)
> +#define TBCTL_HSPCLKDIV_DIVBY4 (0x0002u)
> +#define TBCTL_HSPCLKDIV_DIVBY6 (0x0003u)
> +#define TBCTL_HSPCLKDIV_DIVBY8 (0x0004u)
> +#define TBCTL_HSPCLKDIV_DIVBY10 (0x0005u)
> +#define TBCTL_HSPCLKDIV_DIVBY12 (0x0006u)
> +#define TBCTL_HSPCLKDIV_DIVBY14 (0x0007u)
> +#define                TBCTL_CLKDIV(x)         ((x) << 10)
> +#define                TBCTL_CLKDIV_MASK       (3 << 10)
> +#define                TBCTL_HSPCLKDIV(x)      ((x) << 7)
> +#define                TBCTL_HSPCLKDIV_MASK    (3 << 7)
> +#define         TBCTL_FREERUN           (2 << 14)
> +#define         TBCTL_CTRMODE_UP        (0 << 0)
> diff --git a/testsuites/samples/Makefile.am
> b/testsuites/samples/Makefile.am
> index 374617b..70ebe57 100644
> --- a/testsuites/samples/Makefile.am
> +++ b/testsuites/samples/Makefile.am
> @@ -1,6 +1,6 @@
>  ACLOCAL_AMFLAGS = -I ../aclocal
> -_SUBDIRS = hello capture ticker base_sp unlimited minimum fileio
> +_SUBDIRS = hello capture ticker base_sp unlimited minimum fileio pwm
>  if MPTESTS
>  ## base_mp is a sample multiprocessing test
> diff --git a/testsuites/samples/configure.ac b/testsuites/samples/
> configure.ac
> index 91a3661..72a64a0 100644
> --- a/testsuites/samples/configure.ac
> +++ b/testsuites/samples/configure.ac
> @@ -62,6 +62,7 @@ AC_CHECK_SIZEOF([time_t])
>  AC_CONFIG_FILES([Makefile
>  base_sp/Makefile
>  hello/Makefile
> +pwm/Makefile
>  loopback/Makefile
>  minimum/Makefile
>  fileio/Makefile
> diff --git a/testsuites/samples/pwm/Makefile.am
> b/testsuites/samples/pwm/Makefile.am
> index 0000000..85d0fc1
> --- /dev/null
> +++ b/testsuites/samples/pwm/Makefile.am
> @@ -0,0 +1,19 @@
> +rtems_tests_PROGRAMS = pwm
> +pwm_SOURCES = init.c
> +dist_rtems_tests_DATA = pwm.scn
> +dist_rtems_tests_DATA += pwm.doc
> +include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
> +include $(top_srcdir)/../automake/compile.am
> +include $(top_srcdir)/../automake/leaf.am
> +LINK_OBJS = $(pwm_OBJECTS)
> +LINK_LIBS = $(pwm_LDLIBS)
> +hello$(EXEEXT): $(pwm_OBJECTS) $(pwm_DEPENDENCIES)
> +       @rm -f pwm$(EXEEXT)
> +       $(make-exe)
> +include $(top_srcdir)/../automake/local.am
> diff --git a/testsuites/samples/pwm/init.c b/testsuites/samples/pwm/init.c
> index 0000000..0814720
> --- /dev/null
> +++ b/testsuites/samples/pwm/init.c
> @@ -0,0 +1,70 @@
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include<rtems/test.h>
> +#include<bsp.h>
> +#include<stdio.h>
> +#include<stdlib.h>
> +const char rtems_test_name[] = "Punit PWM test GSOC 2016";
> +rtems_printer rtems_test_printer;
> +static void inline delay_sec(int sec)
> +  rtems_task_wake_after(sec*rtems_clock_get_ticks_per_second());
> +rtems_task Init(rtems_task_argument argument);
> +rtems_task Init(
> +       rtems_task_argument ignored
> +       rtems_test_begin();
> +       printf("Starting PWM Testing");
> +/* Initialization PWM API*/
> +rtems_gpio_initialize();
> +pwm_init(PWMSS2_MMAP_ADDR, 2);
> +PWMSS_TB_clock_check(2);
> +       float PWM_HZ = 1.0f ;
> +       float duty_A = 50.0f ;    /* 50% Duty cycle for PWM 2_A output */
> +       const float duty_B = 50.0f ;    /* 50% Duty cycle for PWM 2_B
> output*/
> +       for(PWM_HZ=1; PWM_HZ <=100000000; PWM_HZ= PWM_HZ*3)
> +       printf("\n Generating frequency : %f\n",PWM_HZ);
> +       PWMSS_Setting(SOC_EPWM_2_REGS, PWM_HZ ,duty_A , duty_B);
> +        printf("PWM  enable for 10s ....\n");
> +        ehrPWM_Enable(SOC_EPWM_2_REGS);
> +       delay_sec(10);
> +       ehrPWM_Disable(SOC_EPWM_2_REGS);
> +       printf("close\n");
> +/* NOTICE: the clock driver is enabled */
> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> +#define CONFIGURE_MAXIMUM_TASKS            1
> +#define CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
> +#define CONFIGURE_MAXIMUM_SEMAPHORES    1
> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> +#define CONFIGURE_EXTRA_TASK_STACKS         (2 * RTEMS_MINIMUM_STACK_SIZE)
> +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> +#include <rtems/confdefs.h>
> diff --git a/testsuites/samples/pwm/pwm.doc
> b/testsuites/samples/pwm/pwm.doc
> index 0000000..9812864
> --- /dev/null
> +++ b/testsuites/samples/pwm/pwm.doc
> @@ -0,0 +1,9 @@
> +#  COPYRIGHT (c) 1989-1999.
> +#  On-Line Applications Research Corporation (OAR).
> +#  The license and distribution terms for this file may be
> +#  found in the file LICENSE in this distribution or at
> +#  http://www.rtems.org/license/LICENSE.
> diff --git a/testsuites/samples/pwm/pwm.scn
> b/testsuites/samples/pwm/pwm.scn
> index 0000000..057ab6e
> --- /dev/null
> +++ b/testsuites/samples/pwm/pwm.scn
> @@ -0,0 +1,3 @@
> +*** GPIO TEST ***
> +Gpio Testing
> +*** END OF GPIO TEST ***
> 2.7.1
Cheers,
Ketul
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160623/255962e0/attachment-0002.html>
