[PATCH 3/3] score: Change Priority_Control to 64-bit
Sebastian Huber
Fri Jun 24 09:57:41 UTC 2016
A 32-bit Priority_Control limits the uptime to 49 days with a 1ms clock
tick in case the EDF scheduler is used. Increase it to 64-bit to enable
proper operation of the EDF scheduler,
Close 2173.
cpukit/posix/include/rtems/posix/priorityimpl.h | 9 ++++++++-
cpukit/posix/src/killinfo.c | 2 +-
cpukit/posix/src/psxpriorityisvalid.c | 9 ---------
cpukit/rtems/include/rtems/rtems/tasks.h | 2 +-
cpukit/score/include/rtems/score/priority.h | 2 +-
cpukit/score/include/rtems/score/scheduleredf.h | 9 ++++++++-
cpukit/score/include/rtems/score/scheduleredfimpl.h | 2 +-
cpukit/score/include/rtems/score/schedulerpriorityimpl.h | 4 ++--
cpukit/score/src/schedulerprioritychangepriority.c | 3 ++-
cpukit/score/src/schedulerpriorityunblock.c | 3 ++-
testsuites/smptests/smpmrsp01/init.c | 2 +-
11 files changed, 27 insertions(+), 20 deletions(-)
diff --git a/cpukit/posix/include/rtems/posix/priorityimpl.h b/cpukit/posix/include/rtems/posix/priorityimpl.h
index b986d64..eb2e3e0 100644
--- a/cpukit/posix/include/rtems/posix/priorityimpl.h
+++ b/cpukit/posix/include/rtems/posix/priorityimpl.h
@@ -20,6 +20,7 @@
#define _RTEMS_POSIX_PRIORITYIMPL_H
+#include <rtems/score/assert.h>
#ifdef __cplusplus
extern "C" {
@@ -48,7 +49,13 @@ extern "C" {
* @return The maximum POSIX API priority for this scheduler instance.
-int _POSIX_Priority_Get_maximum( const Scheduler_Control *scheduler );
+RTEMS_INLINE_ROUTINE int _POSIX_Priority_Get_maximum(
+ const Scheduler_Control *scheduler
+ _Assert( (int) scheduler->maximum_priority > 1 );
+ return (int) scheduler->maximum_priority - 1;
* @brief Converts the POSIX API priority to the corresponding SuperCore
diff --git a/cpukit/posix/src/killinfo.c b/cpukit/posix/src/killinfo.c
index 33754af..b7f0354 100644
--- a/cpukit/posix/src/killinfo.c
+++ b/cpukit/posix/src/killinfo.c
@@ -190,7 +190,7 @@ int _POSIX_signals_Send(
* + rtems internal threads do not receive signals.
interested = NULL;
- interested_priority = PRIORITY_MAXIMUM + 1;
+ interested_priority = UINT64_MAX;
for (the_api = OBJECTS_CLASSIC_API; the_api <= OBJECTS_APIS_LAST; the_api++) {
diff --git a/cpukit/posix/src/psxpriorityisvalid.c b/cpukit/posix/src/psxpriorityisvalid.c
index 7c2300b..5e687ac 100644
--- a/cpukit/posix/src/psxpriorityisvalid.c
+++ b/cpukit/posix/src/psxpriorityisvalid.c
@@ -21,15 +21,6 @@
- if ( scheduler->maximum_priority < INT_MAX ) {
- return (int) scheduler->maximum_priority - 1;
- } else {
- return INT_MAX;
Priority_Control _POSIX_Priority_To_core(
const Scheduler_Control *scheduler,
int posix_priority,
diff --git a/cpukit/rtems/include/rtems/rtems/tasks.h b/cpukit/rtems/include/rtems/rtems/tasks.h
index 84ea806..6273228 100644
--- a/cpukit/rtems/include/rtems/rtems/tasks.h
+++ b/cpukit/rtems/include/rtems/rtems/tasks.h
@@ -75,7 +75,7 @@ extern "C" {
* Define the type for an RTEMS API task priority.
-typedef Priority_Control rtems_task_priority;
+typedef uint32_t rtems_task_priority;
* This is the constant used with the rtems_task_set_priority
diff --git a/cpukit/score/include/rtems/score/priority.h b/cpukit/score/include/rtems/score/priority.h
index 38f3995..842f017 100644
--- a/cpukit/score/include/rtems/score/priority.h
+++ b/cpukit/score/include/rtems/score/priority.h
@@ -53,7 +53,7 @@ extern "C" {
* @note Priority 0 is reserved for internal threads only.
-typedef uint32_t Priority_Control;
+typedef uint64_t Priority_Control;
/** This defines the highest (most important) thread priority. */
#define PRIORITY_MINIMUM 0
diff --git a/cpukit/score/include/rtems/score/scheduleredf.h b/cpukit/score/include/rtems/score/scheduleredf.h
index c236bd5..66bc17e 100644
--- a/cpukit/score/include/rtems/score/scheduleredf.h
+++ b/cpukit/score/include/rtems/score/scheduleredf.h
@@ -24,6 +24,8 @@
#include <rtems/score/schedulerpriority.h>
#include <rtems/score/rbtree.h>
+#include <limits.h>
#ifdef __cplusplus
extern "C" {
#endif
@@ -35,7 +37,12 @@ extern "C" {
-#define SCHEDULER_EDF_MAXIMUM_PRIORITY 0x7fffffff
+ * Actually the EDF scheduler supports a maximum priority of
+ * 0x7fffffffffffffff, but the user API is limited to uint32_t or int for
+ * thread priorities. Ignore ILP64 targets for now.
+#define SCHEDULER_EDF_MAXIMUM_PRIORITY INT_MAX
* Entry points for the Earliest Deadline First Scheduler.
diff --git a/cpukit/score/include/rtems/score/scheduleredfimpl.h b/cpukit/score/include/rtems/score/scheduleredfimpl.h
index 20a5f5c..204660e 100644
--- a/cpukit/score/include/rtems/score/scheduleredfimpl.h
+++ b/cpukit/score/include/rtems/score/scheduleredfimpl.h
@@ -38,7 +38,7 @@ extern "C" {
* ones who do not have any deadlines and thus are considered background
* tasks.
-#define SCHEDULER_EDF_PRIO_MSB 0x80000000
+#define SCHEDULER_EDF_PRIO_MSB 0x8000000000000000
RTEMS_INLINE_ROUTINE Scheduler_EDF_Context *
_Scheduler_EDF_Get_context( const Scheduler_Control *scheduler )
diff --git a/cpukit/score/include/rtems/score/schedulerpriorityimpl.h b/cpukit/score/include/rtems/score/schedulerpriorityimpl.h
index 0f576b6..d03c8d3 100644
--- a/cpukit/score/include/rtems/score/schedulerpriorityimpl.h
+++ b/cpukit/score/include/rtems/score/schedulerpriorityimpl.h
@@ -210,13 +210,13 @@ RTEMS_INLINE_ROUTINE void _Scheduler_priority_Ready_queue_update(
Chain_Control *ready_queues
- ready_queue->current_priority = new_priority;
+ ready_queue->current_priority = (unsigned int) new_priority;
ready_queue->ready_chain = &ready_queues[ new_priority ];
_Priority_bit_map_Initialize_information(
bit_map,
&ready_queue->Priority_map,
- new_priority
+ (unsigned int) new_priority
diff --git a/cpukit/score/src/schedulerprioritychangepriority.c b/cpukit/score/src/schedulerprioritychangepriority.c
index 04599f5..4fc46cf 100644
--- a/cpukit/score/src/schedulerprioritychangepriority.c
+++ b/cpukit/score/src/schedulerprioritychangepriority.c
@@ -37,7 +37,8 @@ Scheduler_Void_or_thread _Scheduler_priority_Update_priority(
node = _Scheduler_priority_Thread_get_node( the_thread );
- priority = _Scheduler_Node_get_priority( &node->Base, &prepend_it );
+ priority = (unsigned int )
+ _Scheduler_Node_get_priority( &node->Base, &prepend_it );
if ( priority == node->Ready_queue.current_priority ) {
/* Nothing to do */
diff --git a/cpukit/score/src/schedulerpriorityunblock.c b/cpukit/score/src/schedulerpriorityunblock.c
index ba8501b..9fc266b 100644
--- a/cpukit/score/src/schedulerpriorityunblock.c
+++ b/cpukit/score/src/schedulerpriorityunblock.c
@@ -34,7 +34,8 @@ Scheduler_Void_or_thread _Scheduler_priority_Unblock (
context = _Scheduler_priority_Get_context( scheduler );
(void) prepend_it;
if ( priority != node->Ready_queue.current_priority ) {
diff --git a/testsuites/smptests/smpmrsp01/init.c b/testsuites/smptests/smpmrsp01/init.c
index dca8662..30fb577 100644
--- a/testsuites/smptests/smpmrsp01/init.c
+++ b/testsuites/smptests/smpmrsp01/init.c
@@ -204,7 +204,7 @@ static void print_switch_events(test_context *ctx)
rtems_object_get_name(e->heir_node->Object.id, sizeof(hn), &hn[0]);
printf(
- "[%" PRIu32 "] %4s -> %4s (prio %3" PRIu32 ", node %4s)\n",
+ "[%" PRIu32 "] %4s -> %4s (prio %3" PRIu64 ", node %4s)\n",
e->cpu_index,
&ex[0],
&hr[0],
1.8.4.5
