SD driver status
Mudit Jain muditjain18011995 at gmail.com
Sun Jun 26 07:38:04 UTC 2016
An update regarding the driver is that, Pavel's patch has fixed the mailbox
error that was occurring.
Previously, set power gave a -2 error.
*** LIBBSD SDHCI 01 TEST ***
nexus0: <RTEMS Nexus device>
bcm_dma0: <BCM2835 DMA Controller> on nexus0
sdhci_bcm0: <Broadcom 2708 SDHCI controller> on nexus0
Enable the power returns 0
mmc0: <MMC/SD bus> on sdhci_bcm0
Sleeping to see what happens
Stack usage by thread
    ID      NAME    LOW          HIGH     CURRENT     AVAILABLE     USED
0x09010001  IDLE 0x12c668 - 0x12d667 0x12d600      4080        128
0x0a010001  UI1  0x12d880 - 0x13587f 0x1354a8     32752       1008
0x0a010002  TIME 0x135fd0 - 0x13dfcf 0x13df10     32752        332
0x0a010003  IRQS 0x13dfd8 - 0x145fd7 0x145f18     32752        308
0x0a010004  _BSD 0x158678 - 0x160677 0x1605b0     32752        336
0x0a010005  _BSD 0x1607d0 - 0x1687cf 0x168708     32752        240
0x0a010006  _BSD 0x16a9f8 - 0x1729f7 0x172938     32752        232
0x0a010007  _BSD 0x172ab8 - 0x17aab7 0x17a9f8     32752        232
0x0a010008  _BSD 0x17ac58 - 0x182c57 0x182b90     32752        240
0x0a010009  _BSD 0x182df8 - 0x18adf7 0x18ad30     32752        240
*** END OF TEST LIBBSD SDHCI 01 ***
Thanks
Mudit
On Tue, Jun 21, 2016 at 4:24 PM, Sebastian Huber <
> For an example see media01 test.
> On 21/06/16 12:40, Mudit Jain wrote:
>> Hi all,
>> This is what I get on minicom.
>> RTEMS Shell on /dev/console. Use 'help' to list commands.
>> [/] # ls /dev
>> bpf     bpf0    console ttyS0
>>  The app code -
>> https://github.com/spark1729/rtems-libbsd/blob/ae67c8bf554b3d59ab5c8a0da70d244a5ffbbc4b/testsuite/sdhci01/test_main.c
>> Ideally an mmc device should be initialized. It would be great if someone
>> could direct me in the right direction here.
>> Thanks.
>> Mudit
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160626/e2def267/attachment-0002.html>
