[PATCH 6/8] score: Add _SMP_Before_multitasking_action()
Thu Mar 3 14:47:53 UTC 2016
Update #2554.
 cpukit/score/include/rtems/score/percpu.h  |  8 +++
 cpukit/score/include/rtems/score/smpimpl.h | 48 +++++++++++++++-
 cpukit/score/src/percpu.c                  | 92 +++++++++++++++++++++++++++---
 cpukit/score/src/smp.c                     | 23 ++++++++
 cpukit/score/src/smpmulticastaction.c      |  4 +-
 5 files changed, 164 insertions(+), 11 deletions(-)
diff --git a/cpukit/score/include/rtems/score/percpu.h b/cpukit/score/include/rtems/score/percpu.h
index 19f46d2..39be1e3 100644
--- a/cpukit/score/include/rtems/score/percpu.h
+++ b/cpukit/score/include/rtems/score/percpu.h
@@ -361,6 +361,14 @@ typedef struct Per_CPU_Control {
     Per_CPU_State state;
+     * @brief Action to be executed by this processor in the
+     * SYSTEM_STATE_BEFORE_MULTITASKING state on behalf of the boot processor.
+     * @see _SMP_Before_multitasking_action().
+    Atomic_Uintptr before_multitasking_action;
      * @brief Indicates if the processor has been successfully started via
      * _CPU_SMP_Start_processor().
diff --git a/cpukit/score/include/rtems/score/smpimpl.h b/cpukit/score/include/rtems/score/smpimpl.h
index 386216f..59a99ec 100644
--- a/cpukit/score/include/rtems/score/smpimpl.h
+++ b/cpukit/score/include/rtems/score/smpimpl.h
@@ -235,7 +235,7 @@ void _SMP_Send_message_multicast(
   unsigned long message
-typedef void ( *SMP_Multicast_action_handler )( void *arg );
+typedef void ( *SMP_Action_handler )( void *arg );
  *  @brief Initiates a SMP multicast action to a set of processors.
@@ -250,10 +250,54 @@ typedef void ( *SMP_Multicast_action_handler )( void *arg );
 void _SMP_Multicast_action(
   const size_t setsize,
   const cpu_set_t *cpus,
-  SMP_Multicast_action_handler handler,
+  SMP_Action_handler handler,
   void *arg
+ * @brief Executes a handler with argument on the specified processor on behalf
+ * of the boot processor.
+ * The calling processor must be the boot processor.  In case the specified
+ * processor is not online or not in the
+ * PER_CPU_STATE_READY_TO_START_MULTITASKING state, then no action is
+ * performed.
+ * @param cpu The processor to execute the action.
+ * @param handler The handler of the action.
+ * @param arg The argument of the action.
+ * @retval true The handler executed on the specified processor.
+ * @retval false Otherwise.
+ * @see _SMP_Before_multitasking_action_broadcast().
+bool _SMP_Before_multitasking_action(
+  Per_CPU_Control    *cpu,
+  void               *arg
+ * @brief Executes a handler with argument on all online processors except the
+ * boot processor on behalf of the boot processor.
+ * @retval true The handler executed on all online processors except the boot
+ * processor.
+bool _SMP_Before_multitasking_action_broadcast(
+  void               *arg
 #endif /* defined( RTEMS_SMP ) */
diff --git a/cpukit/score/src/percpu.c b/cpukit/score/src/percpu.c
index 730528a..0e4c067 100644
--- a/cpukit/score/src/percpu.c
+++ b/cpukit/score/src/percpu.c
@@ -20,6 +20,7 @@
+#include <rtems/score/isrlock.h>
 #include <rtems/score/smpimpl.h>
 #include <rtems/config.h>
@@ -35,11 +36,48 @@ RTEMS_STATIC_ASSERT(
 #if defined(RTEMS_SMP)
-static SMP_lock_Control _Per_CPU_State_lock =
-  SMP_LOCK_INITIALIZER("per-CPU state");
+typedef struct {
+  SMP_Action_handler handler;
+  void *arg;
+} SMP_Before_multicast_action;
+ISR_LOCK_DEFINE( static, _Per_CPU_State_lock, "Per-CPU State" )
+static void _Per_CPU_State_acquire( ISR_lock_Context *lock_context )
+  _ISR_lock_ISR_disable_and_acquire( &_Per_CPU_State_lock, lock_context );
+static void _Per_CPU_State_release( ISR_lock_Context *lock_context )
+  _ISR_lock_Release_and_ISR_enable( &_Per_CPU_State_lock, lock_context );
+static void _Per_CPU_State_before_multitasking_action( Per_CPU_Control *cpu )
+  uintptr_t action_value;
+  action_value = _Atomic_Load_uintptr(
+    &cpu->before_multitasking_action,
+    ATOMIC_ORDER_ACQUIRE
+  if ( action_value != 0 ) {
+    SMP_Before_multicast_action *action =
+      (SMP_Before_multicast_action *) action_value;
+    ( *action->handler )( action->arg );
+    _Atomic_Store_uintptr(
+      0,
+      ATOMIC_ORDER_RELEASE
 static void _Per_CPU_State_busy_wait(
-  const Per_CPU_Control *cpu,
   Per_CPU_State new_state
@@ -60,6 +98,7 @@ static void _Per_CPU_State_busy_wait(
         state != PER_CPU_STATE_REQUEST_START_MULTITASKING
           && state != PER_CPU_STATE_SHUTDOWN
+        _Per_CPU_State_before_multitasking_action( cpu );
         _CPU_SMP_Processor_event_receive();
         state = cpu->state;
@@ -122,13 +161,12 @@ void _Per_CPU_State_change(
-  SMP_lock_Control *lock = &_Per_CPU_State_lock;
-  SMP_lock_Context lock_context;
+  ISR_lock_Context lock_context;
   Per_CPU_State next_state;
   _Per_CPU_State_busy_wait( cpu, new_state );
-  _SMP_lock_ISR_disable_and_acquire( lock, &lock_context );
+  _Per_CPU_State_acquire( &lock_context );
   next_state = _Per_CPU_State_get_next( cpu->state, new_state );
   cpu->state = next_state;
@@ -157,7 +195,7 @@ void _Per_CPU_State_change(
   _CPU_SMP_Processor_event_broadcast();
-  _SMP_lock_Release_and_ISR_enable( lock, &lock_context );
+  _Per_CPU_State_release( &lock_context );
   if (
     next_state == PER_CPU_STATE_SHUTDOWN
@@ -167,6 +205,46 @@ void _Per_CPU_State_change(
+  void               *arg
+  bool done;
+  _Assert( _Per_CPU_Is_boot_processor( _Per_CPU_Get() ) );
+  if ( _Per_CPU_Is_processor_online( cpu ) ) {
+    SMP_Before_multicast_action action = {
+      .handler = handler,
+      .arg = arg
+    Per_CPU_State expected_state = PER_CPU_STATE_READY_TO_START_MULTITASKING;
+      (uintptr_t) &action,
+    _CPU_SMP_Processor_event_broadcast();
+    _Per_CPU_State_busy_wait( cpu, expected_state );
+    do {
+      done = _Atomic_Load_uintptr(
+      ) == 0;
+    } while ( !done && cpu->state == expected_state );
+  } else {
+    done = false;
+  return done;
 #else
    * On single core systems, we can efficiently directly access a single
diff --git a/cpukit/score/src/smp.c b/cpukit/score/src/smp.c
index 8049643..4dacd4e 100644
--- a/cpukit/score/src/smp.c
+++ b/cpukit/score/src/smp.c
@@ -211,4 +211,27 @@ void _SMP_Send_message_multicast(
+  void               *arg
+  bool done = true;
+  uint32_t cpu_count = _SMP_Get_processor_count();
+  uint32_t cpu_index;
+  for ( cpu_index = 0 ; done && cpu_index < cpu_count ; ++cpu_index ) {
+    Per_CPU_Control *cpu = _Per_CPU_Get_by_index( cpu_index );
+    if (
+      !_Per_CPU_Is_boot_processor( cpu )
+        && _Per_CPU_Is_processor_online( cpu )
+      done = _SMP_Before_multitasking_action( cpu, handler, arg );
+  return done;
 SMP_Test_message_handler _SMP_Test_message_handler;
diff --git a/cpukit/score/src/smpmulticastaction.c b/cpukit/score/src/smpmulticastaction.c
index 2e59262..d5d0064 100644
--- a/cpukit/score/src/smpmulticastaction.c
+++ b/cpukit/score/src/smpmulticastaction.c
@@ -17,7 +17,7 @@
 typedef struct {
   Chain_Node Node;
-  SMP_Multicast_action_handler handler;
   void *arg;
   cpu_set_t *recipients;
   size_t setsize;
@@ -94,7 +94,7 @@ _SMP_Multicast_actions_try_process( void )
   void *arg
1.8.4.5
