[PATCH 1/8] score: Add CPU_MAXIMUM_PROCESSORS
Thu Mar 3 14:47:48 UTC 2016
Maximum number of processors of all systems supported by this CPU port.
 cpukit/score/cpu/arm/rtems/score/cpu.h      | 2 ++
 cpukit/score/cpu/bfin/rtems/score/cpu.h     | 2 ++
 cpukit/score/cpu/epiphany/rtems/score/cpu.h | 2 ++
 cpukit/score/cpu/i386/rtems/score/cpu.h     | 2 ++
 cpukit/score/cpu/lm32/rtems/score/cpu.h     | 2 ++
 cpukit/score/cpu/m32c/rtems/score/cpu.h     | 2 ++
 cpukit/score/cpu/m68k/rtems/score/cpu.h     | 2 ++
 cpukit/score/cpu/mips/rtems/score/cpu.h     | 2 ++
 cpukit/score/cpu/moxie/rtems/score/cpu.h    | 2 ++
 cpukit/score/cpu/nios2/rtems/score/cpu.h    | 2 ++
 cpukit/score/cpu/no_cpu/rtems/score/cpu.h   | 6 ++++++
 cpukit/score/cpu/or1k/rtems/score/cpu.h     | 2 ++
 cpukit/score/cpu/powerpc/rtems/score/cpu.h  | 2 ++
 cpukit/score/cpu/sh/rtems/score/cpu.h       | 2 ++
 cpukit/score/cpu/sparc/rtems/score/cpu.h    | 2 ++
 cpukit/score/cpu/sparc64/rtems/score/cpu.h  | 2 ++
 cpukit/score/cpu/v850/rtems/score/cpu.h     | 2 ++
 17 files changed, 38 insertions(+)
diff --git a/cpukit/score/cpu/arm/rtems/score/cpu.h b/cpukit/score/cpu/arm/rtems/score/cpu.h
index 89b7609..4380590 100644
--- a/cpukit/score/cpu/arm/rtems/score/cpu.h
+++ b/cpukit/score/cpu/arm/rtems/score/cpu.h
@@ -204,6 +204,8 @@
 #define CPU_PER_CPU_CONTROL_SIZE 0
+#define CPU_MAXIMUM_PROCESSORS 32
 #ifdef ARM_MULTILIB_HAS_THREAD_ID_REGISTER
diff --git a/cpukit/score/cpu/bfin/rtems/score/cpu.h b/cpukit/score/cpu/bfin/rtems/score/cpu.h
index 3302f47..e4ad87f 100644
--- a/cpukit/score/cpu/bfin/rtems/score/cpu.h
+++ b/cpukit/score/cpu/bfin/rtems/score/cpu.h
@@ -354,6 +354,8 @@ extern "C" {
  *  Processor defined structures required for cpukit/score.
diff --git a/cpukit/score/cpu/epiphany/rtems/score/cpu.h b/cpukit/score/cpu/epiphany/rtems/score/cpu.h
index 896af12..e433e19 100644
--- a/cpukit/score/cpu/epiphany/rtems/score/cpu.h
+++ b/cpukit/score/cpu/epiphany/rtems/score/cpu.h
@@ -795,6 +795,8 @@ typedef struct {
 #define CPU_EXCEPTION_FRAME_SIZE 260
 #ifndef ASM
 typedef uint16_t Priority_bit_map_Word;
diff --git a/cpukit/score/cpu/i386/rtems/score/cpu.h b/cpukit/score/cpu/i386/rtems/score/cpu.h
index d6828dc..9ad9cf2 100644
--- a/cpukit/score/cpu/i386/rtems/score/cpu.h
+++ b/cpukit/score/cpu/i386/rtems/score/cpu.h
@@ -129,6 +129,8 @@ extern "C" {
 #define I386_CONTEXT_CONTROL_EFLAGS_OFFSET 0
 #define I386_CONTEXT_CONTROL_ESP_OFFSET 4
 #define I386_CONTEXT_CONTROL_EBP_OFFSET 8
diff --git a/cpukit/score/cpu/lm32/rtems/score/cpu.h b/cpukit/score/cpu/lm32/rtems/score/cpu.h
index 3ddae7c..1a22da8 100644
--- a/cpukit/score/cpu/lm32/rtems/score/cpu.h
+++ b/cpukit/score/cpu/lm32/rtems/score/cpu.h
@@ -348,6 +348,8 @@ extern "C" {
diff --git a/cpukit/score/cpu/m32c/rtems/score/cpu.h b/cpukit/score/cpu/m32c/rtems/score/cpu.h
index 59e9b4e..de0ead5 100644
--- a/cpukit/score/cpu/m32c/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m32c/rtems/score/cpu.h
@@ -371,6 +371,8 @@ extern "C" {
diff --git a/cpukit/score/cpu/m68k/rtems/score/cpu.h b/cpukit/score/cpu/m68k/rtems/score/cpu.h
index 06d711a..470391a 100644
--- a/cpukit/score/cpu/m68k/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m68k/rtems/score/cpu.h
@@ -115,6 +115,8 @@ extern "C" {
 #if ( CPU_HARDWARE_FP == TRUE ) && !defined( __mcoldfire__ )
   #if defined( __mc68060__ )
     #define M68K_FP_STATE_SIZE 16
diff --git a/cpukit/score/cpu/mips/rtems/score/cpu.h b/cpukit/score/cpu/mips/rtems/score/cpu.h
index cb66b89..67a9ea6 100644
--- a/cpukit/score/cpu/mips/rtems/score/cpu.h
+++ b/cpukit/score/cpu/mips/rtems/score/cpu.h
@@ -313,6 +313,8 @@ extern "C" {
diff --git a/cpukit/score/cpu/moxie/rtems/score/cpu.h b/cpukit/score/cpu/moxie/rtems/score/cpu.h
index 9f0b9b4..ad40ff4 100644
--- a/cpukit/score/cpu/moxie/rtems/score/cpu.h
+++ b/cpukit/score/cpu/moxie/rtems/score/cpu.h
@@ -285,6 +285,8 @@ extern "C" {
diff --git a/cpukit/score/cpu/nios2/rtems/score/cpu.h b/cpukit/score/cpu/nios2/rtems/score/cpu.h
index 1008865..0dd7ed4 100644
--- a/cpukit/score/cpu/nios2/rtems/score/cpu.h
+++ b/cpukit/score/cpu/nios2/rtems/score/cpu.h
@@ -111,6 +111,8 @@ extern "C" {
 #ifndef ASM
 typedef struct {
diff --git a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
index 1c29bd6..a56bc17 100644
--- a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
+++ b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
@@ -391,6 +391,12 @@ extern "C" {
+ * @brief Maximum number of processors of all systems supported by this CPU
+ * port.
diff --git a/cpukit/score/cpu/or1k/rtems/score/cpu.h b/cpukit/score/cpu/or1k/rtems/score/cpu.h
index 7364343..5d7a72f 100644
--- a/cpukit/score/cpu/or1k/rtems/score/cpu.h
+++ b/cpukit/score/cpu/or1k/rtems/score/cpu.h
@@ -788,6 +788,8 @@ typedef struct {
 #define CPU_SIZEOF_POINTER 4
 #ifndef ASM
 typedef uint32_t CPU_Counter_ticks;
diff --git a/cpukit/score/cpu/powerpc/rtems/score/cpu.h b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
index f988f8a..0f5c8d8 100644
--- a/cpukit/score/cpu/powerpc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
@@ -173,6 +173,8 @@ extern "C" {
diff --git a/cpukit/score/cpu/sh/rtems/score/cpu.h b/cpukit/score/cpu/sh/rtems/score/cpu.h
index 2bddba7..fd657dd 100644
--- a/cpukit/score/cpu/sh/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sh/rtems/score/cpu.h
@@ -260,6 +260,8 @@ extern "C" {
diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
index c2b5f4c..96b6ac5 100644
--- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
@@ -363,6 +363,8 @@ typedef struct {
   #define CPU_PER_CPU_CONTROL_SIZE 4
 #endif
  * @brief Offset of the CPU_Per_CPU_control::isr_dispatch_disable field
  * relative to the Per_CPU_Control begin.
diff --git a/cpukit/score/cpu/sparc64/rtems/score/cpu.h b/cpukit/score/cpu/sparc64/rtems/score/cpu.h
index aa756f9..a669c54 100644
--- a/cpukit/score/cpu/sparc64/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc64/rtems/score/cpu.h
@@ -209,6 +209,8 @@ extern "C" {
  *  This structure represents the organization of the minimum stack frame
  *  for the SPARC.  More framing information is required in certain situaions
diff --git a/cpukit/score/cpu/v850/rtems/score/cpu.h b/cpukit/score/cpu/v850/rtems/score/cpu.h
index e910ae1..36e271c 100644
--- a/cpukit/score/cpu/v850/rtems/score/cpu.h
+++ b/cpukit/score/cpu/v850/rtems/score/cpu.h
 typedef struct {
   /* There is no CPU specific per-CPU state */
 } CPU_Per_CPU_control;
1.8.4.5
