[PATCH 5/8] score: Add _Per_CPU_Is_boot_processor()
Thu Mar 3 14:47:52 UTC 2016
 cpukit/score/include/rtems/score/percpu.h | 19 +++++++++++++++++++
 cpukit/score/src/smp.c                    |  2 ++
 2 files changed, 21 insertions(+)
diff --git a/cpukit/score/include/rtems/score/percpu.h b/cpukit/score/include/rtems/score/percpu.h
index 2b05b78..19f46d2 100644
--- a/cpukit/score/include/rtems/score/percpu.h
+++ b/cpukit/score/include/rtems/score/percpu.h
@@ -365,6 +365,12 @@ typedef struct Per_CPU_Control {
      * _CPU_SMP_Start_processor().
     bool online;
+     * @brief Indicates if the processor is the one that performed the initial
+     * system initialization.
+    bool boot;
   #endif
   Per_CPU_Stats Stats;
@@ -536,6 +542,19 @@ static inline bool _Per_CPU_Is_processor_online(
 #endif
+static inline bool _Per_CPU_Is_boot_processor(
+  const Per_CPU_Control *cpu
+#if defined( RTEMS_SMP )
+  return cpu->boot;
+#else
+  (void) cpu;
+  return true;
+#endif
 static inline void _Per_CPU_Send_interrupt( const Per_CPU_Control *cpu )
diff --git a/cpukit/score/src/smp.c b/cpukit/score/src/smp.c
index 68a55ff..8049643 100644
--- a/cpukit/score/src/smp.c
+++ b/cpukit/score/src/smp.c
@@ -57,6 +57,8 @@ static void _SMP_Start_processors( uint32_t cpu_count )
     } else {
       started = true;
+      cpu->boot = true;
       if ( !_Scheduler_Should_start_processor( assignment ) ) {
         _SMP_Fatal( SMP_FATAL_BOOT_PROCESSOR_NOT_ASSIGNED_TO_SCHEDULER );
1.8.4.5
