[PATCH 2/8] score: Add Processor_mask, etc.
Thu Mar 3 14:47:49 UTC 2016
 cpukit/score/Makefile.am                         |  1 +
 cpukit/score/include/rtems/score/processormask.h | 90 ++++++++++++++++++++++++
 cpukit/score/preinstall.am                       |  4 ++
 3 files changed, 95 insertions(+)
 create mode 100644 cpukit/score/include/rtems/score/processormask.h
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index 8506f22..3d3f1c1 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -61,6 +61,7 @@ include_rtems_score_HEADERS += include/rtems/score/priority.h
 include_rtems_score_HEADERS += include/rtems/score/prioritybitmap.h
 include_rtems_score_HEADERS += include/rtems/score/prioritybitmapimpl.h
 include_rtems_score_HEADERS += include/rtems/score/profiling.h
+include_rtems_score_HEADERS += include/rtems/score/processormask.h
 include_rtems_score_HEADERS += include/rtems/score/rbtree.h
 include_rtems_score_HEADERS += include/rtems/score/rbtreeimpl.h
 include_rtems_score_HEADERS += include/rtems/score/resource.h
diff --git a/cpukit/score/include/rtems/score/processormask.h b/cpukit/score/include/rtems/score/processormask.h
new file mode 100644
index 0000000..5a78dd3
--- /dev/null
+++ b/cpukit/score/include/rtems/score/processormask.h
@@ -0,0 +1,90 @@
+ * @file
+ * @brief Processor Mask API
+ * @ingroup ScoreProcessorMask
+ * Copyright (c) 2016 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#ifndef _RTEMS_SCORE_PROCESSORMASK_H
+#define _RTEMS_SCORE_PROCESSORMASK_H
+#include <rtems/score/cpu.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ * @defgroup ScoreProcessorMask Processor Mask
+ * @ingroup Score
+ * The processor mask provides a bit map large enough to provide one bit for
+ * each processor in the system.  It is a fixed size internal data type
+ * provided for efficiency in addition to the API level cpu_set_t.
+#define PROCESSOR_MASK_BITS_PER_FIELD 32
+#define PROCESSOR_MASK_FIELD_COUNT \
+  ( ( CPU_MAXIMUM_PROCESSORS + PROCESSOR_MASK_BITS_PER_FIELD - 1 ) \
+    / PROCESSOR_MASK_BITS_PER_FIELD )
+#define PROCESSOR_MASK_BIT( index ) \
+  (1UL << ( ( index ) % PROCESSOR_MASK_BITS_PER_FIELD ) )
+#define PROCESSOR_MASK_FIELD( index ) \
+  ( ( index ) / PROCESSOR_MASK_BITS_PER_FIELD )
+ * @brief A bit map consisting of 32-bit integer fields which is large enough
+ * to provide one bit for each processor in the system.
+ * Processor 0 corresponds to the bit 0 (least-significant) of the field 0 in
+ * the array, and so on.
+typedef uint32_t Processor_mask[ PROCESSOR_MASK_FIELD_COUNT ];
+RTEMS_INLINE_ROUTINE void _Processor_mask_Set( Processor_mask mask, uint32_t index )
+  mask[ PROCESSOR_MASK_FIELD( index ) ] |= PROCESSOR_MASK_BIT( index );
+RTEMS_INLINE_ROUTINE void _Processor_mask_Clear( Processor_mask mask, uint32_t index )
+  mask[ PROCESSOR_MASK_FIELD( index ) ] &= ~PROCESSOR_MASK_BIT( index );
+RTEMS_INLINE_ROUTINE bool _Processor_mask_Is_set(
+  const Processor_mask mask,
+  uint32_t index
+  return ( mask[ PROCESSOR_MASK_FIELD( index ) ]
+    & PROCESSOR_MASK_BIT( index ) ) != 0;
+#ifdef __cplusplus
+#endif /* _RTEMS_SCORE_PROCESSORMASK_H */
diff --git a/cpukit/score/preinstall.am b/cpukit/score/preinstall.am
index 0d9cade..3a70bfa 100644
--- a/cpukit/score/preinstall.am
+++ b/cpukit/score/preinstall.am
@@ -212,6 +212,10 @@ $(PROJECT_INCLUDE)/rtems/score/profiling.h: include/rtems/score/profiling.h $(PR
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/profiling.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/profiling.h
+$(PROJECT_INCLUDE)/rtems/score/processormask.h: include/rtems/score/processormask.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/processormask.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/processormask.h
 $(PROJECT_INCLUDE)/rtems/score/rbtree.h: include/rtems/score/rbtree.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/rbtree.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/rbtree.h
1.8.4.5
