[PATCH 1/8] score: Add CPU_MAXIMUM_PROCESSORS
Thu Mar 3 15:12:57 UTC 2016
On 03/03/16 16:10, Joel Sherrill wrote:
> How does this interact with the pthread affinity and cpuset size?
Its unrelated to the high level API.
> If we end up with a port that can support more than 32, then do we
> increase the cpuset size or make applications more to variable cpuset's?
No, the high level API is a different issue.
> What's the intended use?
The high level API cpu_set_t is to inefficient for internal use. Linux
uses something similar internally.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
