[PATCH 7/8] score: Distribute clock tick to all online CPUs
Joel Sherrill
joel at rtems.org
Thu Mar 3 15:15:58 UTC 2016
I don't necessarily see anything wrong but I don't see the overall design
and execution flow from the code. Is there some documentation?
Sorry.. used the wrong reply to email address and it didn't hit the list.
On Thu, Mar 3, 2016 at 8:47 AM, Sebastian Huber <
> Update #2554.
> .../libbsp/arm/shared/arm-a9mpcore-clock-config.c | 68
> c/src/lib/libbsp/arm/shared/arm-gic-irq.c | 18 ++++++
> c/src/lib/libbsp/arm/shared/include/arm-gic-irq.h | 5 ++
> c/src/lib/libbsp/i386/pc386/clock/ckinit.c | 15 +++--
> c/src/lib/libbsp/i386/shared/smp/smp-imps.c | 11 +++-
> .../lib/libbsp/powerpc/qoriq/clock/clock-config.c | 9 ++-
> c/src/lib/libbsp/powerpc/qoriq/include/irq.h | 5 ++
> c/src/lib/libbsp/powerpc/qoriq/irq/irq.c | 20 ++++---
> c/src/lib/libbsp/shared/clockdrv_shell.h | 12 ++++
> c/src/lib/libbsp/shared/include/fatal.h | 1 +
> c/src/lib/libbsp/sparc/erc32/clock/ckinit.c | 5 ++
> c/src/lib/libbsp/sparc/leon3/clock/ckinit.c | 11 ++++
> cpukit/score/include/rtems/score/smpimpl.h | 34 +++++++----
> cpukit/score/include/rtems/score/watchdogimpl.h | 7 ++-
> cpukit/score/src/kern_tc.c | 9 ++-
> cpukit/score/src/smp.c | 5 +-
> cpukit/score/src/watchdogtick.c | 10 ++--
> 17 files changed, 199 insertions(+), 46 deletions(-)
> diff --git a/c/src/lib/libbsp/arm/shared/arm-a9mpcore-clock-config.c
> b/c/src/lib/libbsp/arm/shared/arm-a9mpcore-clock-config.c
> index 8e2e153..3dcf708 100644
> --- a/c/src/lib/libbsp/arm/shared/arm-a9mpcore-clock-config.c
> +++ b/c/src/lib/libbsp/arm/shared/arm-a9mpcore-clock-config.c
> @@ -1,5 +1,5 @@
> - * Copyright (c) 2013-2015 embedded brains GmbH. All rights reserved.
> + * Copyright (c) 2013, 2016 embedded brains GmbH. All rights reserved.
> * embedded brains GmbH
> * Dornierstr. 4
> @@ -15,9 +15,11 @@
> #include <bsp.h>
> #include <bsp/fatal.h>
> #include <bsp/irq.h>
> +#include <bsp/irq-generic.h>
> #include <bsp/arm-a9mpcore-regs.h>
> #include <bsp/arm-a9mpcore-clock.h>
> #include <rtems/timecounter.h>
> +#include <rtems/score/smpimpl.h>
> #define A9MPCORE_GT ((volatile a9mpcore_gt *) BSP_ARM_A9MPCORE_GT_BASE)
> @@ -77,6 +79,60 @@ static uint32_t a9mpcore_clock_get_timecount(struct
> timecounter *tc)
> return gt->cntrlower;
> +static void a9mpcore_clock_gt_init(
> + volatile a9mpcore_gt *gt,
> + uint64_t cmpval,
> + uint32_t interval
> + gt->cmpvallower = (uint32_t) cmpval;
> + gt->cmpvalupper = (uint32_t) (cmpval >> 32);
> + gt->autoinc = interval;
> + gt->ctrl = A9MPCORE_GT_CTRL_AUTOINC_EN
> + | A9MPCORE_GT_CTRL_IRQ_EN
> + | A9MPCORE_GT_CTRL_COMP_EN
> + | A9MPCORE_GT_CTRL_TMR_EN;
> +#ifdef RTEMS_SMP
> +typedef struct {
> + uint64_t cmpval;
> + uint32_t interval;
> +} a9mpcore_clock_init_data;
> +static void a9mpcore_clock_secondary_action(void *arg)
> + volatile a9mpcore_gt *gt = A9MPCORE_GT;
> + a9mpcore_clock_init_data *init_data = arg;
> + a9mpcore_clock_gt_init(gt, init_data->cmpval, init_data->interval);
> + bsp_interrupt_vector_enable(A9MPCORE_IRQ_GT);
> +#endif
> +static void a9mpcore_clock_secondary_initialization(
> + uint64_t cmpval,
> + uint32_t interval
> +#ifdef RTEMS_SMP
> + a9mpcore_clock_init_data init_data = {
> + .cmpval = cmpval,
> + .interval = interval
> + _SMP_Before_multitasking_action_broadcast(
> + a9mpcore_clock_secondary_action,
> + &init_data
> + if (cmpval - a9mpcore_clock_get_counter(gt) >= interval) {
> + bsp_fatal(BSP_ARM_A9MPCORE_FATAL_CLOCK_SMP_INIT);
> +#endif
> static void a9mpcore_clock_initialize(void)
> @@ -91,14 +147,8 @@ static void a9mpcore_clock_initialize(void)
> cmpval = a9mpcore_clock_get_counter(gt);
> cmpval += interval;
> - gt->cmpvallower = (uint32_t) cmpval;
> - gt->cmpvalupper = (uint32_t) (cmpval >> 32);
> - gt->autoinc = interval;
> - gt->ctrl = A9MPCORE_GT_CTRL_AUTOINC_EN
> - | A9MPCORE_GT_CTRL_IRQ_EN
> - | A9MPCORE_GT_CTRL_COMP_EN
> - | A9MPCORE_GT_CTRL_TMR_EN;
> + a9mpcore_clock_gt_init(gt, cmpval, interval);
> + a9mpcore_clock_secondary_initialization(gt, cmpval, interval);
> a9mpcore_tc.tc_get_timecount = a9mpcore_clock_get_timecount;
> a9mpcore_tc.tc_counter_mask = 0xffffffff;
> diff --git a/c/src/lib/libbsp/arm/shared/arm-gic-irq.c
> b/c/src/lib/libbsp/arm/shared/arm-gic-irq.c
> index 7623489..487ee16 100644
> --- a/c/src/lib/libbsp/arm/shared/arm-gic-irq.c
> +++ b/c/src/lib/libbsp/arm/shared/arm-gic-irq.c
> @@ -164,3 +164,21 @@ rtems_status_code arm_gic_irq_get_priority(
> return sc;
> +rtems_status_code arm_gic_irq_set_affinity(
> + rtems_vector_number vector,
> + uint8_t targets
> + rtems_status_code sc = RTEMS_SUCCESSFUL;
> + if (bsp_interrupt_is_valid_vector(vector)) {
> + volatile gic_dist *dist = ARM_GIC_DIST;
> + gic_id_set_targets(dist, vector, targets);
> + } else {
> + sc = RTEMS_INVALID_ID;
> + return sc;
> diff --git a/c/src/lib/libbsp/arm/shared/include/arm-gic-irq.h
> b/c/src/lib/libbsp/arm/shared/include/arm-gic-irq.h
> index 7765c00..a8c29bb 100644
> --- a/c/src/lib/libbsp/arm/shared/include/arm-gic-irq.h
> +++ b/c/src/lib/libbsp/arm/shared/include/arm-gic-irq.h
> @@ -58,6 +58,11 @@ rtems_status_code arm_gic_irq_get_priority(
> uint8_t *priority
> + uint8_t targets
> typedef enum {
> ARM_GIC_IRQ_SOFTWARE_IRQ_TO_ALL_IN_LIST,
> ARM_GIC_IRQ_SOFTWARE_IRQ_TO_ALL_EXCEPT_SELF,
> diff --git a/c/src/lib/libbsp/i386/pc386/clock/ckinit.c
> b/c/src/lib/libbsp/i386/pc386/clock/ckinit.c
> index 04514d1..2291839 100644
> --- a/c/src/lib/libbsp/i386/pc386/clock/ckinit.c
> +++ b/c/src/lib/libbsp/i386/pc386/clock/ckinit.c
> @@ -65,11 +65,10 @@ extern volatile uint32_t Clock_driver_ticks;
> } while (0)
> - * Hooks which get swapped based upon which nanoseconds since last
> - * tick method is preferred.
> -#define Clock_driver_support_at_tick()
> +#ifdef RTEMS_SMP
> +#define Clock_driver_support_at_tick() \
> + _SMP_Send_message_broadcast(SMP_MESSAGE_CLOCK_TICK)
> +#endif
> #define Clock_driver_support_install_isr( _new, _old ) \
> do { \
> @@ -203,6 +202,12 @@ void Clock_driver_install_handler(void)
> clockOn();
> +#define Clock_driver_support_set_interrupt_affinity(online_processors) \
> + do { \
> + /* FIXME: Is there a way to do this on x86? */ \
> + (void) online_processors; \
> + } while (0)
> void Clock_driver_support_initialize_hardware(void)
> bool use_tsc = false;
> diff --git a/c/src/lib/libbsp/i386/shared/smp/smp-imps.c
> b/c/src/lib/libbsp/i386/shared/smp/smp-imps.c
> index 158a45d..819c65d 100644
> --- a/c/src/lib/libbsp/i386/shared/smp/smp-imps.c
> +++ b/c/src/lib/libbsp/i386/shared/smp/smp-imps.c
> @@ -744,13 +744,22 @@ static void smp_apic_ack(void)
> IMPS_LAPIC_WRITE(LAPIC_EOI, 0 ); /* ACK the interrupt */
> +/* FIXME: There should be a header file for this */
> +void Clock_isr(void *arg);
> static void bsp_inter_processor_interrupt(void *arg)
> + unsigned long message;
> (void) arg;
> smp_apic_ack();
> - _SMP_Inter_processor_interrupt_handler();
> + message = _SMP_Inter_processor_interrupt_handler();
> + if ((message & SMP_MESSAGE_CLOCK_TICK) != 0) {
> + Clock_isr(NULL);
> static void ipi_install_irq(void)
> diff --git a/c/src/lib/libbsp/powerpc/qoriq/clock/clock-config.c
> b/c/src/lib/libbsp/powerpc/qoriq/clock/clock-config.c
> index 8da927f..17d4bde 100644
> --- a/c/src/lib/libbsp/powerpc/qoriq/clock/clock-config.c
> +++ b/c/src/lib/libbsp/powerpc/qoriq/clock/clock-config.c
> @@ -7,7 +7,7 @@
> - * Copyright (c) 2011-2015 embedded brains GmbH. All rights reserved.
> + * Copyright (c) 2011, 2016 embedded brains GmbH. All rights reserved.
> * Dornierstr. 4
> @@ -55,6 +55,7 @@ static void qoriq_clock_handler_install(rtems_isr_entry
> *old_isr)
> *old_isr = NULL;
> +#if defined(RTEMS_MULTIPROCESSING) && !defined(RTEMS_SMP)
> sc = qoriq_pic_set_affinity(
> CLOCK_INTERRUPT,
> ppc_processor_id()
> @@ -62,6 +63,7 @@ static void qoriq_clock_handler_install(rtems_isr_entry
> *old_isr)
> if (sc != RTEMS_SUCCESSFUL) {
> rtems_fatal_error_occurred(0xdeadbeef);
> +#endif
> sc = qoriq_pic_set_priority(
> CLOCK_INTERRUPT,
> @@ -126,8 +128,13 @@ static void qoriq_clock_cleanup(void)
> #define Clock_driver_support_initialize_hardware() \
> qoriq_clock_initialize()
> #define Clock_driver_support_install_isr(clock_isr, old_isr) \
> qoriq_clock_handler_install(&old_isr)
> + qoriq_pic_set_affinities(CLOCK_INTERRUPT, online_processors[0])
> #define Clock_driver_support_shutdown_hardware() \
> qoriq_clock_cleanup()
> diff --git a/c/src/lib/libbsp/powerpc/qoriq/include/irq.h
> b/c/src/lib/libbsp/powerpc/qoriq/include/irq.h
> index 1363ec3..fb7be65 100644
> --- a/c/src/lib/libbsp/powerpc/qoriq/include/irq.h
> +++ b/c/src/lib/libbsp/powerpc/qoriq/include/irq.h
> @@ -377,6 +377,11 @@ rtems_status_code qoriq_pic_set_affinity(
> uint32_t processor_index
> +rtems_status_code qoriq_pic_set_affinities(
> + uint32_t processor_affinities
> #ifdef __cplusplus
> diff --git a/c/src/lib/libbsp/powerpc/qoriq/irq/irq.c
> b/c/src/lib/libbsp/powerpc/qoriq/irq/irq.c
> index 6bc70ce..da7def3 100644
> --- a/c/src/lib/libbsp/powerpc/qoriq/irq/irq.c
> +++ b/c/src/lib/libbsp/powerpc/qoriq/irq/irq.c
> @@ -147,21 +147,17 @@ rtems_status_code qoriq_pic_set_priority(
> return sc;
> -rtems_status_code qoriq_pic_set_affinity(
> - uint32_t processor_index
> - if (processor_index <= 1) {
> - volatile qoriq_pic_src_cfg *src_cfg =
> get_src_cfg(vector);
> + volatile qoriq_pic_src_cfg *src_cfg = get_src_cfg(vector);
> - src_cfg->dr = BSP_BIT32(processor_index);
> - } else {
> - sc = RTEMS_INVALID_NUMBER;
> + src_cfg->dr = processor_affinities;
> } else {
> @@ -169,6 +165,14 @@ rtems_status_code qoriq_pic_set_affinity(
> return sc;
> +rtems_status_code qoriq_pic_set_affinity(
> + uint32_t processor_index
> + return qoriq_pic_set_affinities(vector,
> BSP_BIT32(processor_index));
> static rtems_status_code pic_vector_enable(rtems_vector_number vector,
> uint32_t msk)
> diff --git a/c/src/lib/libbsp/shared/clockdrv_shell.h
> b/c/src/lib/libbsp/shared/clockdrv_shell.h
> index 9bf5d9b..af03861 100644
> --- a/c/src/lib/libbsp/shared/clockdrv_shell.h
> +++ b/c/src/lib/libbsp/shared/clockdrv_shell.h
> @@ -20,6 +20,7 @@
> #include <bsp.h>
> #include <rtems/clockdrv.h>
> #include <rtems/score/percpu.h>
> #ifdef Clock_driver_nanoseconds_since_last_tick
> #error "Update driver to use the timecounter instead of nanoseconds
> extension"
> @@ -51,6 +52,13 @@
> #endif
> + * @brief Do nothing by default.
> +#ifndef Clock_driver_support_set_interrupt_affinity
> + #define Clock_driver_support_set_interrupt_affinity(online_processors)
> +#endif
> * A specialized clock driver may use for example
> rtems_timecounter_tick_simple()
> * instead of the default.
> @@ -199,6 +207,10 @@ rtems_device_driver Clock_initialize(
> (void) Old_ticker;
> Clock_driver_support_install_isr( Clock_isr, Old_ticker );
> + #ifdef RTEMS_SMP
> + Clock_driver_support_set_interrupt_affinity( _SMP_Online_processors );
> + #endif
> * Now initialize the hardware that is the source of the tick ISR.
> diff --git a/c/src/lib/libbsp/shared/include/fatal.h
> b/c/src/lib/libbsp/shared/include/fatal.h
> index 6c390d0..25dda39 100644
> --- a/c/src/lib/libbsp/shared/include/fatal.h
> +++ b/c/src/lib/libbsp/shared/include/fatal.h
> @@ -47,6 +47,7 @@ typedef enum {
> BSP_ARM_PL111_FATAL_REGISTER_DEV,
> BSP_ARM_PL111_FATAL_SEM_CREATE,
> BSP_ARM_PL111_FATAL_SEM_RELEASE,
> + BSP_ARM_A9MPCORE_FATAL_CLOCK_SMP_INIT,
> /* LEON3 fatal codes */
> LEON3_FATAL_NO_IRQMP_CONTROLLER = BSP_FATAL_CODE_BLOCK(2),
> diff --git a/c/src/lib/libbsp/sparc/erc32/clock/ckinit.c
> b/c/src/lib/libbsp/sparc/erc32/clock/ckinit.c
> index f2d493e..d78fb0e 100644
> --- a/c/src/lib/libbsp/sparc/erc32/clock/ckinit.c
> +++ b/c/src/lib/libbsp/sparc/erc32/clock/ckinit.c
> @@ -41,6 +41,11 @@
> _old = set_vector( _new, CLOCK_VECTOR, 1 ); \
> } while(0)
> +#define Clock_driver_support_set_interrupt_affinity( _online_processors )
> + do { \
> + (void) _online_processors; \
> + } while (0)
> extern int CLOCK_SPEED;
> static rtems_timecounter_simple erc32_tc;
> diff --git a/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
> b/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
> index 5d645dc..601d329 100644
> --- a/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
> +++ b/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
> @@ -155,6 +155,17 @@ static void bsp_clock_handler_install(rtems_isr *new)
> + do { \
> + uint32_t cpu_count = _SMP_Processor_count; \
> + uint32_t cpu_index; \
> + for (cpu_index = 0; cpu_index < cpu_count; ++cpu_index) { \
> + if (_Processor_mask_Is_set(online_processors, cpu_index)) { \
> + BSP_Cpu_Unmask_interrupt(clkirq, cpu_index); \
> + } while (0)
> static void leon3_clock_initialize(void)
> volatile struct irqmp_timestamp_regs *irqmp_ts =
> diff --git a/cpukit/score/include/rtems/score/smpimpl.h
> b/cpukit/score/include/rtems/score/smpimpl.h
> index 59a99ec..d1b7214 100644
> --- a/cpukit/score/include/rtems/score/smpimpl.h
> +++ b/cpukit/score/include/rtems/score/smpimpl.h
> @@ -60,6 +60,16 @@ extern "C" {
> #define SMP_MESSAGE_MULTICAST_ACTION 0x4UL
> + * @brief SMP message to request a clock tick.
> + * This message is provided for systems without a proper interrupt
> affinity
> + * support and may be used by the clock driver.
> + * @see _SMP_Send_message().
> +#define SMP_MESSAGE_CLOCK_TICK 0x8UL
> * @brief SMP fatal codes.
> typedef enum {
> @@ -152,10 +162,13 @@ void _SMP_Multicast_actions_process( void );
> * @brief Interrupt handler for inter-processor interrupts.
> + * @return The received message.
> -static inline void _SMP_Inter_processor_interrupt_handler( void )
> +static inline long unsigned _SMP_Inter_processor_interrupt_handler( void )
> Per_CPU_Control *cpu_self = _Per_CPU_Get();
> + unsigned long message = 0;
> * In the common case the inter-processor interrupt is issued to carry
> out a
> @@ -164,7 +177,7 @@ static inline void
> cpu_self->dispatch_necessary = true;
> if ( _Atomic_Load_ulong( &cpu_self->message, ATOMIC_ORDER_RELAXED ) !=
> 0 ) {
> - unsigned long message = _Atomic_Exchange_ulong(
> + message = _Atomic_Exchange_ulong(
> &cpu_self->message,
> 0UL,
> @@ -183,6 +196,8 @@ static inline void
> _SMP_Multicast_actions_process();
> + return message;
> @@ -197,7 +212,7 @@ static inline void
> bool _SMP_Should_start_processor( uint32_t cpu_index );
> - * @brief Sends a SMP message to a processor.
> + * @brief Sends an SMP message to a processor.
> * The target processor may be the sending processor.
> @@ -207,21 +222,16 @@ bool _SMP_Should_start_processor( uint32_t cpu_index
> void _SMP_Send_message( uint32_t cpu_index, unsigned long message );
> - * @brief Request of others CPUs.
> + * @brief Sends an SMP message to all other online processors.
> - * This method is invoked by RTEMS when it needs to make a request
> - * of the other CPUs. It should be implemented using some type of
> - * interprocessor interrupt. CPUs not including the originating
> - * CPU should receive the message.
> - * @param [in] message is message to send
> + * @param[in] message The message.
> void _SMP_Send_message_broadcast(
> - * @brief Sends a SMP message to a set of processors.
> + * @brief Sends an SMP message to a set of processors.
> * The sending processor may be part of the set.
> @@ -238,7 +248,7 @@ void _SMP_Send_message_multicast(
> typedef void ( *SMP_Action_handler )( void *arg );
> - * @brief Initiates a SMP multicast action to a set of processors.
> + * @brief Initiates an SMP multicast action to a set of processors.
> * The current processor may be part of the set.
> diff --git a/cpukit/score/include/rtems/score/watchdogimpl.h
> b/cpukit/score/include/rtems/score/watchdogimpl.h
> index 8064c77..49ac2a1 100644
> --- a/cpukit/score/include/rtems/score/watchdogimpl.h
> +++ b/cpukit/score/include/rtems/score/watchdogimpl.h
> @@ -23,6 +23,7 @@
> #include <rtems/score/assert.h>
> #include <rtems/score/chainimpl.h>
> #include <rtems/score/isrlock.h>
> +#include <rtems/score/percpu.h>
> #ifdef __cplusplus
> extern "C" {
> @@ -139,11 +140,11 @@ RTEMS_INLINE_ROUTINE void _Watchdog_Flash(
> void _Watchdog_Handler_initialization( void );
> - * @brief Triggers a watchdog tick.
> + * @brief Performs a watchdog tick.
> - * This routine executes TOD, watchdog and scheduler ticks.
> + * @param cpu The processor for this watchdog tick.
> -void _Watchdog_Tick( void );
> +void _Watchdog_Tick( Per_CPU_Control *cpu );
> * @brief Removes @a the_watchdog from the watchdog chain.
> diff --git a/cpukit/score/src/kern_tc.c b/cpukit/score/src/kern_tc.c
> index 16d76a1..e56c292 100644
> --- a/cpukit/score/src/kern_tc.c
> +++ b/cpukit/score/src/kern_tc.c
> @@ -1974,10 +1974,15 @@ tc_ticktock(int cnt)
> void
> _Timecounter_Tick(void)
> + Per_CPU_Control *cpu_self = _Per_CPU_Get();
> + if (_Per_CPU_Is_boot_processor(cpu_self)) {
> #endif /* __rtems__ */
> tc_windup();
> #ifdef __rtems__
> - _Watchdog_Tick();
> + _Watchdog_Tick(cpu_self);
> #ifdef __rtems__
> @@ -2016,7 +2021,7 @@ _Timecounter_Tick_simple(uint32_t delta, uint32_t
> offset,
> _Timecounter_Release(lock_context);
> - _Watchdog_Tick();
> + _Watchdog_Tick(_Per_CPU_Get());
> diff --git a/cpukit/score/src/smp.c b/cpukit/score/src/smp.c
> index 4dacd4e..9d9507d 100644
> --- a/cpukit/score/src/smp.c
> +++ b/cpukit/score/src/smp.c
> @@ -189,7 +189,10 @@ void _SMP_Send_message_broadcast( unsigned long
> message )
> _Assert( _Debug_Is_thread_dispatching_allowed() );
> for ( cpu_index = 0 ; cpu_index < cpu_count ; ++cpu_index ) {
> - if ( cpu_index != cpu_index_self ) {
> + if (
> + cpu_index != cpu_index_self
> + && _Processor_mask_Is_set( _SMP_Online_processors, cpu_index )
> _SMP_Send_message( cpu_index, message );
> diff --git a/cpukit/score/src/watchdogtick.c
> b/cpukit/score/src/watchdogtick.c
> index cb68ea2..e89c088 100644
> --- a/cpukit/score/src/watchdogtick.c
> +++ b/cpukit/score/src/watchdogtick.c
> @@ -22,13 +22,15 @@
> #include "config.h"
> #endif
> _Assert( !_Thread_Dispatch_is_enabled() );
> - _TOD_Tickle_ticks();
> + if ( _Per_CPU_Is_boot_processor( cpu ) ) {
> + _TOD_Tickle_ticks();
> - _Watchdog_Tickle_ticks();
> + _Watchdog_Tickle_ticks();
> - _Scheduler_Tick();
> + _Scheduler_Tick();
> 1.8.4.5
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160303/e61ce494/attachment-0001.html>
