GSoC 2016 Interested in Tracing was Re:
Joel Sherrill
joel at rtems.org
Thu Mar 3 16:45:27 UTC 2016
On Thu, Mar 3, 2016 at 10:25 AM, Vivek Kukreja <vivekkukreja at outlook.com>
wrote:
> Hi everyone
> I am Vivek Kukreja, currently pursuing Masters from India. I'm interested
> in applying for GSOC this year. I am a skilled C Programmer and have strong
> understanding of OS concepts. I'm interested in system programming
> and kernel development.
> I am interested to work on topics under Tracing. I am intrigued by the
> topic. I think this will be a good place to start for me.
> That's a good area that needs work. Chris Johns is the core person in this
area. He is in
Sydney and will likely comment once he is awake. :)
I gave a presentation at the Flight Software Workshop in 2014 on the RTEMS
ecosystem.
Tracing was included in that presentation and Chris helped with the slides.
The slides are
here:
http://flightsoftware.jhuapl.edu/files/2014/Presentations/Day-2/Session-3/2-RTEMSProjectEcosystem.pdf
There is a video of my presentation if you want to see it. But this
presentation covers the
background and status.
> I have gone through Getting Started documentation and setup RTEMS on my
> machine. I have tried running the provided examples. I tried to run the
> tracing example, but am facing some problem during compilation (wrapper
> compilation error). I will continue looking into it, and report if I can't
> solve the problem on my own.
> Focus first on doing the GSoC Hello World and adding yourself to the list
of students.
Then ask specific questions about those examples.
> Please tell me about the open projects under the Tracing Tool. I request
> you to please give me some pointers to get started.
> Chris is the person to make sure the task list is current and in priority.
But I know there is work to be done on generation of method trace wrappers,
getting trace data off target (tcp/ip, etc), and producing Common Trace
Format
and integrating with the Linux Trace Toolkit.
My understanding is that the Linux Trace Toolkit can also dynamically
interact (bidirectionally) with the target system. I don't know what that
entails but it is desirable. But it requires having basic integration solved
first.
I hope that helps.
--joel
> Regards,
> Vivek
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160303/edb50a90/attachment.html>
