[PATCH 00/17] pc386 non-legacy enhancements
Joel Sherrill
joel at rtems.org
Wed Mar 9 22:24:45 UTC 2016
First, there are only 15 patches in this series. The last two
are additions of commands directly to fileio. Both may be of
interest but should be discussed separately.
This series started with the need to get the pc386 BSP working
on an embedded PC without legacy PCI BIOS and with a COM1 port
on the PCI and not in I/O space. This target board does not have
an IDE/ATA controller. The probe hangs so the build disables that.
The first patches eliminate the need for the pc386 specific pcibios.h
and add dynamic detection of using PCI BIOS or I/O space accesses for
PCI Configuration Space. It also added a shared implementation of
pci_find_device() and later patches use this to eliminate copies
in other BSPs. A ticket will be filed for the last case.
There are patches to add boot command line arguments for --printk=XXX
to specify printk output go somewhere besides the --console=XXX device.
There is also a --disable-com1-com4 boot command line argument to
disable those at run-time. The BSP is booted with these arguments:
The PCI UART is added as /dev/pcicom1. It uses a UART PCI table from
FreeBSD and probes for all PCI UARTs. These are dynamically installed.
The dynamic registration support in the shared console was enhanced
to be able to be called multiple times.
kernel tftp://192.168.1.92/fileio.exe --console=pcicom1 --printk=vgacons --disable-com1-com4
boot fileio.exe
Along the way, there is also miscellaneous clean up to comments, a warning
in bsp_fatal_halt.c, etc.
I hope the description helps.
--joel
Joel Sherrill (17):
pc386: Eliminate pcibios.h and begin removal obsolete PCI BIOS API
uses
i386/shared/pci/pcibios.c: Remove unused pcib_special_cycle()
i386/shared/pci/pcibios.c: Remove unused pcib_find_by_class()
pc386/configure.ac: Delete incorrect and unused AM_CONDITIONAL
Add shared PCI support and enhance pc386 to support non-legacy PCI
configuration space
pc386: Improve boot command arguments for console/printk device
selection
console_private.h: Remove prototypes for non-existent methods
bsp_com_inch() and bsp_com_outch()
console_private.h: Improve comment for vt_ioctl()
pc386: Add PCI UART support
pc386/startup/bspstart.c: Reformat and cleanup file header
pc386/startup/bsp_fatal_halt.c: Fix noreturn does return warning
libbsp/shared/console.c: Clean up memory allocation for per device
data
pc386: Add --disable-com1-com4 boot argument
mips/malta: Use shared pci_find_device() and removed unused
pci_list_devices()
powerpc/mvme5500: Use shared pci_find_device()
fileio: lspci candidate command
fileio: Add command "com" to write to files
c/src/lib/libbsp/Makefile.am | 3 +
c/src/lib/libbsp/i386/Makefile.am | 2 +-
c/src/lib/libbsp/i386/pc386/Makefile.am | 8 +-
c/src/lib/libbsp/i386/pc386/configure.ac | 1 -
c/src/lib/libbsp/i386/pc386/console/conscfg.c | 29 +-
.../lib/libbsp/i386/pc386/console/console_select.c | 217 +++++++++--
c/src/lib/libbsp/i386/pc386/console/uart_bus_pci.c | 398 +++++++++++++++++++++
c/src/lib/libbsp/i386/pc386/include/bsp.h | 10 +
c/src/lib/libbsp/i386/pc386/preinstall.am | 4 -
.../lib/libbsp/i386/pc386/startup/bsp_fatal_halt.c | 3 +
c/src/lib/libbsp/i386/pc386/startup/bspstart.c | 102 ++++--
c/src/lib/libbsp/i386/shared/pci/pci_io.c | 200 +++++++++++
c/src/lib/libbsp/i386/shared/pci/pcibios.c | 246 ++-----------
c/src/lib/libbsp/i386/shared/pci/pcibios.h | 62 ----
c/src/lib/libbsp/mips/malta/Makefile.am | 3 +-
c/src/lib/libbsp/mips/malta/include/pci.h | 32 --
c/src/lib/libbsp/mips/malta/pci/pcifinddevice.c | 277 --------------
c/src/lib/libbsp/mips/malta/pci/pcilistdevices.c | 102 ------
c/src/lib/libbsp/powerpc/mvme5500/Makefile.am | 6 +-
.../libbsp/powerpc/mvme5500/pci/pcifinddevice.c | 62 ----
c/src/lib/libbsp/shared/console.c | 57 ++-
c/src/lib/libbsp/shared/console_private.h | 35 +-
c/src/lib/libbsp/shared/pci/pci_bus_count.c | 67 ++++
c/src/lib/libbsp/shared/pci/pci_find_device.c | 274 ++++++++++++++
c/src/libchip/network/if_fxp.c | 43 ++-
testsuites/samples/fileio/Makefile.am | 2 +-
testsuites/samples/fileio/init.c | 7 +-
testsuites/samples/fileio/main_com.c | 129 +++++++
testsuites/samples/fileio/main_lspci.c | 43 +++
29 files changed, 1540 insertions(+), 884 deletions(-)
create mode 100644 c/src/lib/libbsp/i386/pc386/console/uart_bus_pci.c
create mode 100644 c/src/lib/libbsp/i386/shared/pci/pci_io.c
delete mode 100644 c/src/lib/libbsp/i386/shared/pci/pcibios.h
delete mode 100644 c/src/lib/libbsp/mips/malta/pci/pcifinddevice.c
delete mode 100644 c/src/lib/libbsp/mips/malta/pci/pcilistdevices.c
delete mode 100644 c/src/lib/libbsp/powerpc/mvme5500/pci/pcifinddevice.c
create mode 100644 c/src/lib/libbsp/shared/pci/pci_bus_count.c
create mode 100644 c/src/lib/libbsp/shared/pci/pci_find_device.c
create mode 100644 testsuites/samples/fileio/main_com.c
create mode 100644 testsuites/samples/fileio/main_lspci.c
1.8.3.1
