[PATCH 12/17] libbsp/shared/console.c: Clean up memory allocation for per device data
Thu Mar 10 02:15:32 UTC 2016
On Wed, Mar 9, 2016 at 5:24 PM, Joel Sherrill <joel at rtems.org> wrote:
>  c/src/lib/libbsp/shared/console.c | 49 ++++++++++++++++++++++++++++-----------
>  1 file changed, 36 insertions(+), 13 deletions(-)
> diff --git a/c/src/lib/libbsp/shared/console.c b/c/src/lib/libbsp/shared/console.c
> index 81a70b1..d030065 100644
> --- a/c/src/lib/libbsp/shared/console.c
> +++ b/c/src/lib/libbsp/shared/console.c
> @@ -7,7 +7,7 @@
> - *  COPYRIGHT (c) 1989-2011.
> + *  COPYRIGHT (c) 1989-2011, 2016.
>   *  On-Line Applications Research Corporation (OAR).
>   *  The license and distribution terms for this file may be
> @@ -46,13 +46,28 @@ void console_initialize_data(void)
>    if ( Console_Port_Tbl )
>      return;
> +   * Allocate memory for the table of device pointers.
>    Console_Port_Count = Console_Configuration_Count;
>    Console_Port_Tbl   = malloc( Console_Port_Count * sizeof( console_tbl * ) );
>    if (Console_Port_Tbl == NULL)
>      bsp_fatal( BSP_FATAL_CONSOLE_NO_MEMORY_0 );
> -  for (i=0 ; i < Console_Port_Count ; i++)
> +   * Allocate memory for the table of device specific data pointers.
> +  Console_Port_Data  = calloc( Console_Port_Count, sizeof( console_data ) );
why calloc ...
> +  if ( Console_Port_Data == NULL ) {
> +    bsp_fatal( BSP_FATAL_CONSOLE_NO_MEMORY_3 );
> +   * Fill in the Console Table
> +  for (i=0 ; i < Console_Port_Count ; i++) {
>      Console_Port_Tbl[i] = &Console_Configuration_Ports[i];
... if you will immediately initialize it
> @@ -69,10 +84,13 @@ void console_register_devices(
>    int  old_number_of_ports;
>    int  i;
> +   * Initialize the console data elements
>    console_initialize_data();
> -   *  console_initialize has been invoked so it is now too late to
> +   *  console_initialize() has been invoked so it is now too late to
>     *  register devices.
>    if ( console_initialized ) {
> @@ -86,23 +104,31 @@ void console_register_devices(
>    Console_Port_Count += number_of_ports;
>    Console_Port_Tbl = realloc(
>      Console_Port_Tbl,
> -    Console_Port_Count * sizeof( console_tbl * )
> +    Console_Port_Count * sizeof(console_tbl *)
>    if ( Console_Port_Tbl == NULL ) {
>      bsp_fatal( BSP_FATAL_CONSOLE_NO_MEMORY_1 );
> -  Console_Port_Data  = calloc( Console_Port_Count, sizeof( console_data ) );
> +   * Since we can only add devices before console_initialize(),
> +   * the data area will contain no information and must be zero
> +   * before it is used. So extend the area and zero it out.
> +  Console_Port_Data = realloc(
> +    Console_Port_Data,
>      bsp_fatal( BSP_FATAL_CONSOLE_NO_MEMORY_2 );
> +  memset(&Console_Port_Data, '\0', Console_Port_Count * sizeof(console_tbl *));
>     *  Now add the new devices at the end.
>    for (i=0 ; i < number_of_ports ; i++) {
> -    Console_Port_Tbl[old_number_of_ports + i] = &new_ports[i];
> +    Console_Port_Tbl[old_number_of_ports + i]  = &new_ports[i];
> @@ -249,14 +275,11 @@ rtems_device_driver console_initialize(
>     * If we have no devices which were registered earlier then we
> -   * must still initialize pointers and set Console_Port_Data.
> +   * must still initialize pointers for Console_Port_Tbl and
> +   * Console_Port_Data.
> -  if ( ! Console_Port_Tbl ) {
> +  if ( !Console_Port_Tbl ) {
> -    if ( Console_Port_Data == NULL ) {
> -      bsp_fatal( BSP_FATAL_CONSOLE_NO_MEMORY_3 );
> 1.8.3.1
> devel mailing list
> devel at rtems.org
