[PATCH 05/17] Add shared PCI support and enhance pc386 to support non-legacy PCI configuration space
    Gedare Bloom
    gedare at rtems.org
    Thu Mar 10 02:21:37 UTC 2016
On Wed, Mar 9, 2016 at 5:24 PM, Joel Sherrill <joel at rtems.org> wrote:
> This patch fundamentally results from enhancements to the pc386 BSP
> to support systems which do **NOT** have the legacy PCI BIOS. The
> patch adds support for detecting when legacy PCI BIOS is not
> present and then using IO space to access to PCI Configuration Space.
> This resulted in dynamically selected between two implementations
> of PCI and refactoring out the shared methods.
> This patch adds shared implementations of pci_bus_count() and
> pci_find_device(). Subsequent patches will remove implementations
> of these methods in other BSPs where possible.
>  c/src/lib/libbsp/Makefile.am                   |   3 +
>  c/src/lib/libbsp/i386/Makefile.am              |   1 +
>  c/src/lib/libbsp/i386/pc386/Makefile.am        |   3 +
>  c/src/lib/libbsp/i386/pc386/startup/bspstart.c |  31 ++-
>  c/src/lib/libbsp/i386/shared/pci/pci_io.c      | 200 ++++++++++++++++++
>  c/src/lib/libbsp/i386/shared/pci/pcibios.c     | 149 ++------------
>  c/src/lib/libbsp/shared/pci/pci_bus_count.c    |  67 ++++++
>  c/src/lib/libbsp/shared/pci/pci_find_device.c  | 274 +++++++++++++++++++++++++
>  8 files changed, 594 insertions(+), 134 deletions(-)
>  create mode 100644 c/src/lib/libbsp/i386/shared/pci/pci_io.c
>  create mode 100644 c/src/lib/libbsp/shared/pci/pci_bus_count.c
>  create mode 100644 c/src/lib/libbsp/shared/pci/pci_find_device.c
> diff --git a/c/src/lib/libbsp/Makefile.am b/c/src/lib/libbsp/Makefile.am
> index 16c276f..c54fdcb 100644
> --- a/c/src/lib/libbsp/Makefile.am
> +++ b/c/src/lib/libbsp/Makefile.am
> @@ -29,6 +29,9 @@ EXTRA_DIST += shared/include/coverhd.h
>  EXTRA_DIST += shared/gdbstub/rtems-stub-glue.c
>  EXTRA_DIST += shared/include/bootcard.h
> +EXTRA_DIST += shared/pci/pci_bus_count.c
> +EXTRA_DIST += shared/pci/pci_find_device.c
>  include_bspdir = $(includedir)/bsp
>  include_bsp_HEADERS =
> diff --git a/c/src/lib/libbsp/i386/Makefile.am b/c/src/lib/libbsp/i386/Makefile.am
> index f10b764..3b6df65 100644
> --- a/c/src/lib/libbsp/i386/Makefile.am
> +++ b/c/src/lib/libbsp/i386/Makefile.am
> @@ -22,6 +22,7 @@ EXTRA_DIST += shared/irq/irq_init.c
>  # shared/pci
>  EXTRA_DIST += shared/pci/pcibios.c
> +EXTRA_DIST += shared/pci/pci_io.c
>  include $(top_srcdir)/../../../automake/subdirs.am
>  include $(top_srcdir)/../../../automake/local.am
> diff --git a/c/src/lib/libbsp/i386/pc386/Makefile.am b/c/src/lib/libbsp/i386/pc386/Makefile.am
> index a9c645b..fc73afd 100644
> --- a/c/src/lib/libbsp/i386/pc386/Makefile.am
> +++ b/c/src/lib/libbsp/i386/pc386/Makefile.am
> @@ -141,6 +141,9 @@ libbsp_a_SOURCES += ../../shared/gnatinstallhandler.c
>  # pci
>  libbsp_a_SOURCES += ../../i386/shared/pci/pcibios.c
> +libbsp_a_SOURCES += ../../i386/shared/pci/pci_io.c
> +libbsp_a_SOURCES += ../../shared/pci/pci_bus_count.c
> +libbsp_a_SOURCES += ../../shared/pci/pci_find_device.c
>  include_HEADERS += ../../i386/shared/comm/uart.h
>  # startup
> diff --git a/c/src/lib/libbsp/i386/pc386/startup/bspstart.c b/c/src/lib/libbsp/i386/pc386/startup/bspstart.c
> index ac871f0..a0bbf66 100644
> --- a/c/src/lib/libbsp/i386/pc386/startup/bspstart.c
> +++ b/c/src/lib/libbsp/i386/pc386/startup/bspstart.c
> @@ -34,17 +34,40 @@
>  #include <libcpu/cpuModel.h>
> + * PCI Bus Configuration
> +rtems_pci_config_t BSP_pci_configuration = {
> +  (volatile unsigned char*)0,
> +  NULL
> +const pci_config_access_functions *pci_bios_initialize(void);
> +const pci_config_access_functions *pci_io_initialize(void);
>   * Helper to initialize the PCI Bus
>  static void bsp_pci_initialize_helper(void)
>  #if (BSP_IS_EDISON == 0)
> -  int pci_init_retval;
> +  const pci_config_access_functions *pci_accessors;
> -  pci_init_retval = pci_initialize();
> -  if (pci_init_retval != PCIB_ERR_SUCCESS) {
> -      printk("PCI bus: could not initialize PCI BIOS interface\n");
> +  pci_accessors = pci_bios_initialize();
> +  if (pci_accessors != NULL) {
> +    printk("PCI bus: using PCI BIOS interface\n");
> +    BSP_pci_configuration.pci_functions = pci_accessors;
> +    return;
> +  pci_accessors = pci_io_initialize();
> +    printk("PCI bus: using PCI I/O interface\n");
> +    return;
> +  printk("PCI bus: could not initialize PCI BIOS interface\n");
>  #endif
> diff --git a/c/src/lib/libbsp/i386/shared/pci/pci_io.c b/c/src/lib/libbsp/i386/shared/pci/pci_io.c
> new file mode 100644
> index 0000000..9103b5c
> --- /dev/null
> +++ b/c/src/lib/libbsp/i386/shared/pci/pci_io.c
> @@ -0,0 +1,200 @@
> +#include <rtems.h>
> +#include <rtems/pci.h>
> +#include <bsp.h>
> +static int pci_io_initialized = 0;
> + * Forward reference. Initialized at bottom.
> +static const pci_config_access_functions pci_io_indirect_functions;
> +/* prototype before defining */
Why isn't this coming from a header?
> + * Detects presense of PCI Configuration is in I/O space. If so, return pointer to
> + * accessor methods.
> + * NOTE: TBD to determine if (a) PCI Bus exists and (b) this is the access method.
> +  pci_io_initialized = 1;
> +  printk( "PCI I/O Support Initialized\n" );
> +  return &pci_io_indirect_functions;
> + * Build PCI Address
> +static inline uint32_t pci_io_build_address(
> +  uint16_t  bus,
> +  uint16_t  slot,
> +  uint16_t  function,
> +  uint16_t  offset
> +  uint32_t bus_u32      = (uint32_t)bus;
> +  uint32_t slot_u32     = (uint32_t)slot;
> +  uint32_t function_u32 = (uint32_t)function;
> +  uint32_t address;
> +   * create configuration address as per figure at
> +   *   http://wiki.osdev.org/PCI#Configuration_Space_Access_Mechanism_.231
> +  address  = (uint32_t) 0x80000000;  /* Bit  31    - Enable Bit */
> +                                     /* Bits 30-24 - Reserved */
> +  address |= bus_u32 << 16;          /* Bits 23-16 - Bus Number */
> +  address |= slot_u32 << 11;         /* Bits 15-11 - Device/Slot Number */
> +  address |= function_u32 << 8;      /* Bits 10-8  - Function Number */
> +  address |= offset & 0xfc;          /* Bits 7-2   - Offset/Register Number */
> +                                     /* Bits 1-0   - Reserved 0 */
> +  return address;
> +static int BSP_pci_read_config_byte(
> +  unsigned char bus,
> +  unsigned char slot,
> +  unsigned char function,
> +  unsigned char offset,
> +  unsigned char *value
> +  uint32_t address;
> +  uint32_t tmp;
> +  address = pci_io_build_address( bus, slot, function, offset );
> +  /* write out the address */
> +  outport_long(0xCF8, address);
> +  /* read in the data */
> +  inport_long(0xCFC, tmp);
> +  /* (offset & 3) * 8) = 0 will choose the first byte of the 32 bits register */
> +  *value = (uint16_t)(tmp >> ((offset & 3) * 8)) & 0xff;
> +  return PCIBIOS_SUCCESSFUL;
> +static int BSP_pci_read_config_word(
> +  unsigned short *value
> +  uint32_t address;
> +  uint32_t tmp;
> +  /* (offset & 2) * 8) = 0 will choose the first word of the 32 bits register */
> +  *value = (uint16_t)(tmp >> ((offset & 2) * 8)) & 0xffff;
> +static int BSP_pci_read_config_dword(
> +  uint32_t     *value
> +  uint32_t address;
> +  uint32_t tmp;
> +  *value = tmp;
> +static int BSP_pci_write_config_byte(
> +  unsigned char value
> +  uint32_t address;
> +  outport_byte(0xCFC, value);
> +static int BSP_pci_write_config_word(
> +  unsigned short value
> +  uint32_t address;
> +  outport_word(0xCFC, value);
> +static int BSP_pci_write_config_dword(
> +  uint32_t      value
> +  uint32_t address;
> +  outport_long(0xCFC, value);
> +static const pci_config_access_functions pci_io_indirect_functions = {
> +  BSP_pci_read_config_byte,
> +  BSP_pci_read_config_word,
> +  BSP_pci_read_config_dword,
> +  BSP_pci_write_config_byte,
> +  BSP_pci_write_config_word,
> +  BSP_pci_write_config_dword
> diff --git a/c/src/lib/libbsp/i386/shared/pci/pcibios.c b/c/src/lib/libbsp/i386/shared/pci/pcibios.c
> index 7dc53a1..e746494 100644
> --- a/c/src/lib/libbsp/i386/shared/pci/pcibios.c
> +++ b/c/src/lib/libbsp/i386/shared/pci/pcibios.c
> @@ -40,16 +40,23 @@ static int pcib_convert_err(int err);
>  #define PCIB_DEVSIG_BUS(x) (((x)>>8) &0xff)
>  #define PCIB_DEVSIG_DEV(x) (((x)>>3) & 0x1f)
>  #define PCIB_DEVSIG_FUNC(x) ((x) & 0x7)
> - * Detects presense of PCI BIOS, returns
> - * error code
> -int
> -pci_initialize(void)
> +static const pci_config_access_functions pci_bios_indirect_functions;
> + * Detects presense of PCI BIOS, returns pointer to accessor methods.
>    unsigned char *ucp;
> -  unsigned char sum;
> -  int      i;
> +  unsigned char  sum;
> +  int            i;
>    pcibInitialized = 0;
> @@ -80,7 +87,7 @@ pci_initialize(void)
>    if (ucp >= (unsigned char *)0xFFFFF) {
>      /* BIOS-32 not found */
> -    return PCIB_ERR_NOTPRESENT;
> +    return NULL;
>    /* BIOS-32 found, let us find PCI BIOS */
> @@ -102,7 +109,7 @@ pci_initialize(void)
>    if ((pcibExchg[0] & 0xff) != 0) {
>      /* Not found */
> +    return NULL;
>    /* Found PCI entry point */
> @@ -125,130 +132,18 @@ pci_initialize(void)
>    if ((pcibExchg[0] & 0xff00) != 0) {
>      /* Not found */
> +    return NULL;
>    if (pcibExchg[3] != 0x20494350) {
>      /* Signature does not match */
> +    return NULL;
>    /* Success */
>    pcibInitialized = 1;
> -  return PCIB_ERR_SUCCESS;
> - * Find specified device and return its signature: combination
> - * of bus number, device number and function number
> -static int
> -pcib_find_by_devid(int vendorId, int devId, int idx, int *sig)
> -  if (!pcibInitialized) {
> -    return PCIB_ERR_UNINITIALIZED;
> -  pcibExchg[0] = pcibEntry;
> -  pcibExchg[1] = vendorId;
> -  pcibExchg[2] = devId;
> -  pcibExchg[3] = idx;
> -  __asm__ ("    pusha");
> -  __asm__ ("    movl pcibExchg, %edi");
> -  __asm__ ("    movb $0xb1, %ah");
> -  __asm__ ("    movb $0x02, %al");
> -  __asm__ ("    movl pcibExchg+4, %edx");
> -  __asm__ ("    movl pcibExchg+8, %ecx");
> -  __asm__ ("    movl pcibExchg+12, %esi");
> -  __asm__ ("    pushl %cs");
> -  __asm__ ("    call *%edi");
> -  __asm__ ("    movl %eax, pcibExchg");
> -  __asm__ ("    movl %ebx, pcibExchg+4");
> -  __asm__ ("    popa");
> -  *sig = pcibExchg[1] & 0xffff;
> -  return pcib_convert_err((pcibExchg[0] >> 8) & 0xff);
> -int
> -pci_find_device(
> -  unsigned short vendorid,
> -  unsigned short deviceid,
> -  int instance,
> -  int *pbus,
> -  int *pdev,
> -  int *pfun
> -  int status;
> -  int sig = 0;
> -  status = pcib_find_by_devid( vendorid, deviceid, instance, &sig );
> -  *pbus = PCIB_DEVSIG_BUS(sig);
> -  *pdev = PCIB_DEVSIG_DEV(sig);
> -  *pfun = PCIB_DEVSIG_FUNC(sig);
> -  return status ? -1 : 0;
> -static uint8_t ucBusCount = 0xff;
> -unsigned char
> -pci_bus_count(void)
> -  if ( ucBusCount == 0xff ) {
> -    unsigned char bus;
> -    unsigned char dev;
> -    unsigned char fun;
> -    unsigned char nfn;
> -    unsigned char hd = 0;
> -    uint32_t d = 0;
> -    ucBusCount = 0;
> -    for (bus=0; bus< 0xff; bus++) {
> -      for (dev=0; dev<PCI_MAX_DEVICES; dev++) {
> -        pci_read_config_dword(bus, dev, fun, PCI_VENDOR_ID, &d);
> -        if ( -1 == d ) {
> -          continue;
> -        pci_read_config_byte(bus, dev, fun, PCI_HEADER_TYPE, &hd);
> -        nfn = (hd & 0x80) ? PCI_MAX_FUNCTIONS : 1;
> -        for ( fun=0; fun<nfn; fun++ ) {
> -          if ( -1 == d )
> -            continue;
> -          pci_read_config_dword(bus, dev, fun, PCI_CLASS_REVISION, &d);
> -          if ( (d >> 16) == PCI_CLASS_BRIDGE_PCI ) {
> -            pci_read_config_byte(bus, dev, fun, PCI_SUBORDINATE_BUS, &hd);
> -            if ( hd > ucBusCount )
> -              ucBusCount = hd;
> -    if ( ucBusCount == 0 ) {
> -      printk("pci_bus_count() found 0 busses, assuming 1\n");
> -      ucBusCount = 1;
> -    } else if ( ucBusCount == 0xff ) {
> -      printk("pci_bus_count() found 0xff busses, assuming 1\n");
> -      ucBusCount = 1;
> -  return ucBusCount;
> +  return &pci_bios_indirect_functions;
> @@ -568,7 +463,7 @@ BSP_pci_write_config_dword(
> -const pci_config_access_functions pci_indirect_functions = {
> +static const pci_config_access_functions pci_bios_indirect_functions = {
> @@ -576,9 +471,3 @@ const pci_config_access_functions pci_indirect_functions = {
> -rtems_pci_config_t BSP_pci_configuration = {
> -  (volatile unsigned char*)0,
> -  &pci_indirect_functions
> diff --git a/c/src/lib/libbsp/shared/pci/pci_bus_count.c b/c/src/lib/libbsp/shared/pci/pci_bus_count.c
> index 0000000..d0c7c80
> --- /dev/null
> +++ b/c/src/lib/libbsp/shared/pci/pci_bus_count.c
> @@ -0,0 +1,67 @@
> + * This software is Copyright (C) 1998 by T.sqware - all rights limited
> + * It is provided in to the public domain "as is", can be freely modified
> + * as far as this copyight notice is kept unchanged, but does not imply
> + * an endorsement by T.sqware of the product in which it is included.
> +#include <rtems.h>
> +static uint8_t pci_number_of_buses = 0xff;
> +unsigned char pci_bus_count(void)
> +  if ( pci_number_of_buses != 0xff ) {
> +    return pci_number_of_buses;
> +  uint8_t  bus;
> +  uint8_t  device;
> +  uint8_t  function;
> +  uint8_t  number_of_functions;
> +  uint8_t  header = 0;
> +  uint8_t  buses = 0;
> +  uint32_t vendor = 0;
> +  uint32_t class_rev = 0;
> +  pci_number_of_buses = 0;
> +  for (bus=0; bus < 0xff; bus++) {
> +    for (device=0; device < PCI_MAX_DEVICES; device++) {
> +       pci_read_config_dword(bus, device, 0, PCI_VENDOR_ID, &vendor);
> +       if ( vendor == -1 ) {
> +         continue;
> +       pci_read_config_byte(bus, device, 0, PCI_HEADER_TYPE, &header);
> +       number_of_functions = (header & 0x80) ? PCI_MAX_FUNCTIONS : 1;
> +       for ( function=0; function < number_of_functions; function++ ) {
> +         pci_read_config_dword(bus, device, function, PCI_VENDOR_ID, &vendor);
> +           continue;
> +         pci_read_config_dword(bus, device, function, PCI_CLASS_REVISION, &class_rev);
> +         if ( (class_rev >> 16) == PCI_CLASS_BRIDGE_PCI ) {
> +            pci_read_config_byte(bus, device, function, PCI_SUBORDINATE_BUS, &buses);
> +            if ( buses > pci_number_of_buses ) {
> +              pci_number_of_buses = buses;
> +  if ( pci_number_of_buses == 0 ) {
> +    printk("pci_bus_count() found 0 busses, assuming 1\n");
> +    pci_number_of_buses = 1;
> +  } else if ( pci_number_of_buses == 0xff ) {
> +    printk("pci_bus_count() found 0xff busses, assuming 1\n");
> diff --git a/c/src/lib/libbsp/shared/pci/pci_find_device.c b/c/src/lib/libbsp/shared/pci/pci_find_device.c
> index 0000000..1feddcc
> --- /dev/null
> +++ b/c/src/lib/libbsp/shared/pci/pci_find_device.c
> @@ -0,0 +1,274 @@
> + * @file
> + * This file implements a BSP independent version of pci_find_device().
> + * The software in this file was based upon the pci_find_device()
> + * implementation provided by  Till Straumann under the following terms.
> + * That implementation had been copied to multiple BSPs. This implementation
> + * is BSP independent and follows RTEMS Project coding guidelines.
> + * COPYRIGHT (c) 2016.
> + * On-Line Applications Research Corporation (OAR).
> + * Authorship
> + * This software was created by
> + *     Till Straumann <strauman at slac.stanford.edu>, 2001,
> + *      Stanford Linear Accelerator Center, Stanford University.
> + * Acknowledgement of sponsorship
> + * This software was produced by
> + *     the Stanford Linear Accelerator Center, Stanford University,
> + *      under Contract DE-AC03-76SFO0515 with the Department of Energy.
> + * Government disclaimer of liability
> + * Neither the United States nor the United States Department of Energy,
> + * nor any of their employees, makes any warranty, express or implied, or
> + * assumes any legal liability or responsibility for the accuracy,
> + * completeness, or usefulness of any data, apparatus, product, or process
> + * disclosed, or represents that its use would not infringe privately owned
> + * rights.
> + * Stanford disclaimer of liability
> + * Stanford University makes no representations or warranties, express or
> + * implied, nor assumes any liability for the use of this software.
> + * Stanford disclaimer of copyright
> + * Stanford University, owner of the copyright, hereby disclaims its
> + * copyright and all other rights in this software.  Hence, anyone may
> + * freely use it for any purpose without restriction.
> + * Maintenance of notices
> + * In the interest of clarity regarding the origin and status of this
> + * SLAC software, this and all the preceding Stanford University notices
> + * are to remain affixed to any copy or derivative of this software made
> + * or distributed by the recipient and are to be affixed to any copy of
> + * software made or distributed by the recipient that contains a copy or
> + * derivative of this software.
> + * ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
> +#include <rtems/bspIo.h>
> +#include <inttypes.h>
> +#include <stdio.h>
> + *  Public methods from this file
> +void pci_dump(FILE *f);
> + * These are used to construct the handle returned by pci_find_device()
> + * but the caller does not need to know how to decode them.
> +#define PCIB_DEVSIG_BUS(x) (((x)>>8) &0xff)
> +#define PCIB_DEVSIG_DEV(x) (((x)>>3) & 0x1f)
> +#define PCIB_DEVSIG_FUNC(x) ((x) & 0x7)
> +#define PCIB_DEVSIG_MAKE(b,d,f) ((b<<8)|(d<<3)|(f))
> + * Function pointer to helper function called during bus iteration.
> +typedef int (*pci_scan_helper_t)(
> +  int   bus,
> +  int   dev,
> +  int   fun,
> +  void *uarg
> +static uint32_t pci_scan(
> +  uint32_t           handle,
> +  pci_scan_helper_t  helper,
> +  void              *uarg
> +typedef struct {
> +  uint16_t   vendor_id;
> +  uint16_t   device_id;
> +  int        instance;
> +  uint8_t    bus;
> +  uint8_t    device;
> +  uint8_t    function;
> +} pci_scan_arg_t;
> +static int find_dev_helper(
> +  int   bus,
> +  int   device,
> +  int   function,
> +  void *uarg
> +  pci_scan_arg_t  *scan = uarg;
> +  uint16_t         vendor_tmp;
> +  uint16_t         device_tmp;
> +  pci_read_config_word(bus, device, function, PCI_VENDOR_ID, &vendor_tmp);
> +  if (scan->vendor_id == vendor_tmp) {
> +    pci_read_config_word(bus, device, function, PCI_DEVICE_ID, &device_tmp);
> +    if (scan->device_id == device_tmp && scan->instance-- == 0) {
> +      scan->bus      = bus;
> +      scan->device   = device;
> +      scan->function = function;
> +      return 1;
> +  return 0;
> +int pci_find_device(
> +  uint16_t vendorid,
> +  uint16_t deviceid,
> +  int      instance,
> +  int     *bus,
> +  int     *device,
> +  int     *function
> +  pci_scan_arg_t  scan;
> +  scan.instance   = instance;
> +  scan.vendor_id  = vendorid;
> +  scan.device_id  = deviceid;
> +  if ( pci_scan(0, find_dev_helper, (void*)&scan) != 0 ) {
> +    *bus      = scan.bus;
> +    *device   = scan.device;
> +    *function = scan.function;
> +    return 0;
> +  return -1;
> +static int dump_dev_helper(
> +  int   bus,
> +  int   device,
> +  int   function,
> +  void *arg
> +  uint16_t  cmd;
> +  uint16_t  status;
> +  uint32_t  base0;
> +  uint32_t  base1;
> +  uint8_t   irq_pin;
> +  uint8_t   int_line;
> +  FILE     *fp = arg;
> +  pci_read_config_word (bus, device, function, PCI_VENDOR_ID,      &vendor_id);
> +  pci_read_config_word (bus, device, function, PCI_DEVICE_ID,      &device_id);
> +  pci_read_config_word (bus, device, function, PCI_COMMAND,        &cmd);
> +  pci_read_config_word (bus, device, function, PCI_STATUS,         &status);
> +  pci_read_config_dword(bus, device, function, PCI_BASE_ADDRESS_0, &base0);
> +  pci_read_config_dword(bus, device, function, PCI_BASE_ADDRESS_1, &base1);
> +  pci_read_config_byte (bus, device, function, PCI_INTERRUPT_PIN,  &irq_pin);
> +  pci_read_config_byte (bus, device, function, PCI_INTERRUPT_LINE, &int_line);
> +  fprintf(
> +    fp,
> +    "%3d:0x%02x:%d   0x%04x:0x%04x 0x%04x 0x%04x 0x%08" PRIx32 " 0x%08" PRIx32 "   %d %3d(0x%02x)\n",
> +    bus,
> +    device,
> +    function,
> +    vendor_id,
> +    device_id,
> +    cmd,
> +    status,
> +    base0,
> +    base1,
> +    irq_pin,
> +    int_line,
> +    int_line
> +  return 0;
> +void pci_dump(
> +  FILE *fp
> +  if ( !fp )
> +    fp = stdout;
> +  fprintf(
> +    fp,
> +    "BUS:SLOT:FUN VENDOR:DEV_ID   CMD  STAT   BASE_ADDR0 BASE_ADDR1 INTn IRQ_LINE\n"
> +  pci_scan(0, dump_dev_helper, fp);
> +  uint32_t           handle,
> +  void               *arg
> +  uint32_t vendor;
> +  uint8_t  bus;
> +  uint8_t  dev;
> +  uint8_t  fun;
> +  uint8_t  hd;
> +  bus = PCIB_DEVSIG_BUS(  (unsigned long)handle );
> +  dev = PCIB_DEVSIG_DEV(  (unsigned long)handle );
> +  fun = PCIB_DEVSIG_FUNC( (unsigned long)handle );
> +  hd = fun > 0 ? PCI_MAX_FUNCTIONS : 1;
> +  for (; bus<pci_bus_count(); bus++, dev=0) {
> +    for (; dev<PCI_MAX_DEVICES; dev++, fun=0) {
> +      for (; fun<hd; fun++) {
> +         * The last devfn id/slot is special; must skip it
> +        if ((PCI_MAX_DEVICES-1 == dev) && (PCI_MAX_FUNCTIONS-1 == fun) )
> +          break;
> +        (void)pci_read_config_dword(bus, dev, 0, PCI_VENDOR_ID, &vendor);
> +        if (PCI_INVALID_VENDORDEVICEID == vendor)
> +          continue;
> +        if ( fun == 0 ) {
> +          pci_read_config_byte(bus,dev, 0,  PCI_HEADER_TYPE, &hd);
> +          hd = (hd & PCI_HEADER_TYPE_MULTI_FUNCTION ? PCI_MAX_FUNCTIONS : 1);
> +        (void)pci_read_config_dword(bus, dev, fun, PCI_VENDOR_ID, &vendor);
> +          continue;
> +        #ifdef PCI_DEBUG
> +          fprintf(
> +            stderr,
> +            "pci_scan: found 0x%08" PRIx32 " at %d/x%02x/%d\n", vendor, bus, dev, fun
> +        #endif
> +        if ( (*helper)(bus, dev, fun, arg) > 0 ) {
> +          if ( ++fun >= hd ) {
> +            fun = 0;
> +            if ( ++dev >= PCI_MAX_DEVICES ) {
> +              dev = 0;
> +              bus++;
> +          return PCIB_DEVSIG_MAKE(bus,dev,fun);
> +  return 0;
> 1.8.3.1
> devel mailing list
> devel at rtems.org
