Participation in GSoC 2016
Darshit Shah
darnir at gmail.com
Thu Mar 10 11:13:57 UTC 2016
Hi,
I've been a little busy with my semester end exams and other things
recently. But I have spent time looking into the RTEMS Priority
Scheduler with Processor Affinities and the paper mentioned in the trac
ticket.
At this point, I have a decent understanding of the paper and its
algorithm and am looking into how we may implement it in RTEMS. To this
end, I am looking for help / guidance.
>This would be a good project. I would add a few steps to simply implementing
>it.
>+ Update the scheduling simulator since it is a lot easier to test using
>that.
> It is also easier to ensure you keep the same behavior.
This sounds like it would be in important part of the implementation of
the paper. However, I do not know anything about the existing scheduling
simulator. Any links to this and basic pointers on how I should go about
extending it would be a great start. I'll incorporate this into my draft
proposal as soon as I have a better idea of what needs to be done.
>+ Propose criteria for knowing if the new algorithm is really better for
> RTEMS than the old one. Evaluating algorithms for RTEMS use involves
> big-O of the algorithm, data space requirements (and big-O of that),
> global knowledge required, and maybe other factors.
The new algorithm is almost definitely worse in time and space than the
existing algorithm. Based on a preliminary analysis, it will be able to
use the existing Priority Affinity Scheduler for the most part and add a
O(|E|) complexity to each thread blocking and unblocking operation.
Here, E is the set of all processor affinity assignments, so it will
approximately add an extra linear increase in scheduling overhead w.r.t.
the number of processes that use this scheduler.
I haven't specifically looked into the space requirements, but it will
be worse than the existing scheduler.
However, the point to realize is that after these changes, more user
programs that set processor affinities will be able to meet their
deadlines as compared to the existing scheduler. This should happen
despite the higher scheduling overheads.
>+ Testing on scheduling simulator and in RTEMS testsuite to ensure
> it is functionally identical to the current algorithm.
Once again, some pointers tot he scheduling simulator would help me a
lot.
>If the algorithm is functionally identical to the current one and superior
>in execution time/data requirements, then replacing it is a no brainer.
>If there are trade-offs on when one is better than the other in real life,
>then we will all have to characterize those.
I was thinking more along the lines of writing a new scheduler instead
of replacing the existing one. A PriorityStringAPA scheduler that pretty
much reuses all the existing priority affinity scheduler code apart from
the two operations. This is because, with some task sets where the
affinity assignments are not too restrictive, the lower overheads of the
existing scheduler may be preferred over the new one.
I have also been writing my draft proposal for GSoC. A version is
currently available on GDrive and a link has been put on on the student
tracking page. However, I wanted to ask if sharing a PDF of the proposal
would be possible. Since, I would be more comfortable in making the
entire proposal in Latex and sharing the final PDF. If not, I can keep
working on the proposal in Google Docs.
Thanking You,
Darshit Shah
Type: application/pgp-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160310/e2eb8650/attachment.bin>
