GSOC 2016
Joel Sherrill
joel at rtems.org
Thu Mar 10 17:36:49 UTC 2016
On Thu, Mar 10, 2016 at 11:18 AM, Gedare Bloom <gedare at rtems.org> wrote:
> Joel should comment on this. He has been making a recent effort at
> unifying the PCI implementations in the BSP layer. However, we also
> have the new "drvmgr" framework in cpukit/libdrvmgr that supports PCI
> plus a lot of other devices and busses.
Gedare.. are you thinking of libpci or both liibdrvmgr and the new libpci
I didn't push on using libpci although I looked at it brief. Both are only
used by SPARC BSPs at the moment but would be good to bring over
to the other.
I left a ticket (https://devel.rtems.org/ticket/2635) where some PowerPC
BSPs couldn't immediately use my shared pci_find_device.c because
I didn't promote out pci_scan().
It would be good to get that issue addressed and then start migrating
BSPs to use libpci and whatever is useful from what I did cleanup
up the pc386.
Between the two of those, there should be a nice GSoC project and
it would be appreciated.
+ migrate to use of libpci including enhancements as needed
I do not know enough about the driver manager to know which BSPs
should use it. The pc386 may be a good candidate. I think if the
devices are dynamically detected on the BSP, it makes sense. But
not sure.
--joel
> On Tue, Mar 8, 2016 at 12:19 PM, animesh pathak <animesh2049 at gmail.com>
> wrote:
> > Hi,
> > Thanks for informing. Another interesting idea on which I would like to
> work
> > upon, from the Ideas page is "Unified Interrupts and Devices" . In case
> this
> > project is already assigned to someone please suggest me the project
> which I
> > can pick up, and can get started with.
> > Regarding my skills, I have good knowledge of GNU/Linux environment,
> > operating system related things like Processes, CPU Scheduling, System
> > calls, Concurrency and Threading, Locking mechanisms, File systems etc
> and
> > also I have implemented custom syscalls in xv6 os. I have experience in
> > programming languages like C, C++, Python, JavaScript and have a good
> > algorithmic background.
> > Regards
> > On Tue, Mar 8, 2016 at 8:59 AM, Gedare Bloom <gedare at rtems.org> wrote:
> >> Hi Animesh,
> >> I think the condition variables will be fixed by another developer
> >> (Sebastian Huber). Any other projects catch your eye?
> >> On Sat, Mar 5, 2016 at 5:31 AM, animesh pathak <animesh2049 at gmail.com>
> >> wrote:
> >> > Hello everyone,
> >> > I am Animesh Chandra Pathak.
> >> > I am pursuing my BTech in Computer Science at IIIT Hyderabad.
> >> > I am interested in working with RTEMS as a part of Google summer of
> code
> >> > 2016 project.
> >> > I have successfully completed the Getting Started part as mentioned in
> >> > the
> >> > quick start and modified the hello world programme. Now when I am
> trying
> >> > to
> >> > compile the network-demos, I am getting "error: too few arguments to
> >> > function 'mg_start' ". How should I do to compile this ?
> >> > Screenshot is attached.
> >> > I want to work on the "Implement Classic API and supercore condition
> >> > variables" as a part of Google summer of code project.
> >> > what should I do before applying for Google summer of code ?
> >> > _______________________________________________
> >> > devel mailing list
> >> > devel at rtems.org
> >> > http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160310/b075eab5/attachment.html>
