Participation in GSoC 2016
Sat Mar 12 13:13:24 UTC 2016
On Thu, Mar 10, 2016 at 9:25 AM, Gedare Bloom <gedare at rtems.org> wrote:
> Joel might answer about the state of the scheduling simulator.
> I believe you eventually have to copy-paste your application into a
> form, so it is better if you stick to plain text. I don't even know if
> you can put images in. You may optionally link to a generated PDF,
> too.
It looks like the proposal submission is a PDF, so you can use Latex
to prepare it if you like.
