Building RTEMS hello world image using CMake
Sun Mar 13 21:35:34 UTC 2016
On Sun, Mar 13, 2016 at 5:28 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 13/03/2016 1:53 AM, Gedare Bloom wrote:
>> If this works for you, and you are sufficiently interested, it would
>> be useful to provide CMake example for the examples-v2.git repository
>> for others to benefit.
> I am not sure about adding this to examples-v2.git. I would prefer it to
> be a waf only build system. I am not sure if make support is still
> present and working but it will go once Makefile.inc goes as it is not
> supported in the new RTEMS waf build system.
> Adding a range of build systems to examples-v2.git makes the maintenance
> harder because a change requires testing with each build system. To me
> the focus of the example-v2 repo is on examples of RTEMS code and not
> built systems.
> I would suggest a separate rtems-builder.git repo or something like that
> to hold separate self contained build system examples. The focus can be
> on build systems and not the application code.
This is a fine idea. It would be good to provide a set of examples for
users to follow to use their preferred build system to compile
applications that link to RTEMS. I liked examples-v2 because it offers
a variety of application requirements, and a new repo with some
examples that show different build requirements (e.g. binary blobs,
file systems) makes sense.
