Compiling RTEMS
Wang, John (IVV-1800) john.wang-1 at nasa.gov
Wed Mar 16 13:10:28 UTC 2016
I have downloaded the RCC compiler.  Added to my $PATH.
The particular thing is that the C compiler / cross compiler shows that it's working during the .configure phase.  However, during gmake phase, the compiler cannot be found.
-----Original Message-----
From: soja-lists at aries.uberspace.de [mailto:soja-lists at aries.uberspace.de]
Sent: Wednesday, March 16, 2016 4:21 AM
To: Wang, John (IVV-1800)
Cc: users at rtems.org; devel at rtems.org
Subject: Re: Compiling RTEMS
Am 2016-03-16 01:45, schrieb Wang, John (IVV-1800):
> Hi,
> I am attempting to build RTEMS in Ubuntu.  The version I am using is
> from Gaisler - 4.10-1.2.16.
> I am run the bootstrap, and configure command with no issues.
> However, when I run the make / gmake I command I receive the following
> error:
> Checking for sparc-rtems4.10-gcc... no No acceptable cc found in $PATH
The RTEMS sources alone are not enough. Do you have a working cross-compiler?
You can either download the prebuilt one from gaisler or build one using the rtems-source-builder.
If you already have one, you might have simply forgotten to add the location to your PATH environment variable.
Cheers,
    Jan
> Can anyone help me with this?
> Thank you
> devel mailing list
> devel at rtems.org
