Participation in GSoC 2016
Fri Mar 18 08:43:40 UTC 2016
On 16/03/16 22:11, Chris Johns wrote:
> On 16/03/2016 23:01, Darshit Shah wrote:
>> I have updated my draft proposal with a basic timeline for things that
>> need to be done. The link is shared on the tracking page and has been
>> submitted via the program website as well. I'm sharing it here as well:
>> https://goo.gl/UmgS61
>> Since this is a draft proposal, it may not be completely polished yet.
>> I'd appreciate any comments on it, especially the project description
>> and timeline.
" POSIX mandated processor affinityAPI"
This is actually not defined in POSIX. Its a non-portable Linux/BSD
extension.
"schedulable task sets would miss their deadlines since it does not
consider migrating high priority tasks"
I think this is not correct. The current APA scheduler should implement
strong APA. However, it may iterate several times over all (!) ready
tasks. This is the actual problem.
I would use the name "APA" for the new scheduler, e.g. schedulerapasmp.c.
We already have a ticket for this work:
https://devel.rtems.org/ticket/2510
With respect to the tests. In addition to worst case task sets, we have
to define task sets that cover the basic operations and the corner
cases. I suggest to use test driven development once the data structures
and algorithm is clear. Start with a simple test and implement
everything so that this test passes. Continue until everything is fine.
> Looking good.
> Could you please add something about the method of testing you plan to
> use? Not the tests just the set up details, eg is this with the
> scheduler simulator, qemu, or real hardware or all listed plus also
> which architectures?
We can use Qemu and the hardware here in our office.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
