[PATCH] FreeBSD compatibility for <sys/select.h>
Sebastian Huber
Fri Mar 18 10:49:23 UTC 2016
* libc/include/sys/_sigset.h: New.
* libc/include/sys/select.h: Do not include <sys/types.h> and
<sys/time.h> to avoid cyclic header file dependencies. Include
specialized header files instead.
(sigset_t): Conditionally define.
* libc/include/sys/signal.h (sigset_t): Likewise.
* libc/include/sys/time.h: Include <sys/select.h> if
__BSD_VISIBLE.
* libc/include/sys/types.h: Likewise.
newlib/libc/include/sys/_sigset.h | 45 +++++++++++++++++++++++++++++++++++++++
newlib/libc/include/sys/select.h | 18 ++++++++--------
newlib/libc/include/sys/signal.h | 6 ++++--
newlib/libc/include/sys/time.h | 4 ++--
newlib/libc/include/sys/types.h | 2 ++
5 files changed, 62 insertions(+), 13 deletions(-)
create mode 100644 newlib/libc/include/sys/_sigset.h
diff --git a/newlib/libc/include/sys/_sigset.h b/newlib/libc/include/sys/_sigset.h
new file mode 100644
index 0000000..38ff1f1
--- /dev/null
+++ b/newlib/libc/include/sys/_sigset.h
@@ -0,0 +1,45 @@
+ * Copyright (c) 1982, 1986, 1989, 1991, 1993
+ * The Regents of the University of California. All rights reserved.
+ * (c) UNIX System Laboratories, Inc.
+ * All or some portions of this file are derived from material licensed
+ * to the University of California by American Telephone and Telegraph
+ * Co. or Unix System Laboratories, Inc. and are reproduced herein with
+ * the permission of UNIX System Laboratories, Inc.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * 4. Neither the name of the University nor the names of its contributors
+ * may be used to endorse or promote products derived from this software
+ * without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * @(#)signal.h 8.4 (Berkeley) 5/4/95
+ * $FreeBSD$
+#ifndef _SYS__SIGSET_H_
+#define _SYS__SIGSET_H_
+#ifndef __CYGWIN__
+typedef unsigned long __sigset_t;
+#endif
+#endif /* !_SYS__SIGSET_H_ */
diff --git a/newlib/libc/include/sys/select.h b/newlib/libc/include/sys/select.h
index ffe8900..2412ff6 100644
--- a/newlib/libc/include/sys/select.h
+++ b/newlib/libc/include/sys/select.h
@@ -23,15 +23,15 @@ details. */
#include <sys/cdefs.h>
-/* Get fd_set, and macros like FD_SET */
-#include <sys/types.h>
-/* Get definition of timeval. */
-#include <sys/time.h>
-#include <time.h>
-/* Get definition of sigset_t. */
-#include <signal.h>
+#include <sys/_sigset.h>
+#include <sys/_timeval.h>
+#include <sys/timespec.h>
+/* Cygwin defines it's own sigset_t in include/cygwin/signal.h */
+#if !defined(__CYGWIN__) && !defined(_SIGSET_T_DECLARED)
+#define _SIGSET_T_DECLARED
+typedef __sigset_t sigset_t;
+#endif
# define _SYS_TYPES_FD_SET
diff --git a/newlib/libc/include/sys/signal.h b/newlib/libc/include/sys/signal.h
index 09f0778..e423fb8 100644
--- a/newlib/libc/include/sys/signal.h
+++ b/newlib/libc/include/sys/signal.h
@@ -10,13 +10,15 @@ extern "C" {
#include <sys/features.h>
#include <sys/_timespec.h>
/* #ifndef __STRICT_ANSI__*/
-#ifndef __CYGWIN__
-typedef unsigned long sigset_t;
#endif
#if defined(__rtems__)
diff --git a/newlib/libc/include/sys/time.h b/newlib/libc/include/sys/time.h
index 7e7205b..3b41f81 100644
--- a/newlib/libc/include/sys/time.h
+++ b/newlib/libc/include/sys/time.h
@@ -45,9 +45,9 @@
/* Cygwin exposes sys/select.h to users of sys/time.h for a couple of years
so we have to maintain that. Note that this is in accordance with POSIX. */
-#ifdef __CYGWIN__
+#if defined(__CYGWIN__) || __BSD_VISIBLE
#include <sys/select.h>
-#endif /* __CYGWIN__ */
+#endif
struct timezone {
int tz_minuteswest; /* minutes west of Greenwich */
diff --git a/newlib/libc/include/sys/types.h b/newlib/libc/include/sys/types.h
index 5dd6c75..207c8f8 100644
--- a/newlib/libc/include/sys/types.h
+++ b/newlib/libc/include/sys/types.h
@@ -86,6 +86,8 @@ typedef quad_t * qaddr_t;
# if __BSD_VISIBLE
+#include <sys/select.h>
# define physadr physadr_t
# define quad quad_t
1.8.4.5
