[PATCH] [RSB 4.11] Bump OpenRISC versions
Hesham Almatary heshamelmatary at gmail.com
Sun Mar 20 21:17:59 UTC 2016
Hi Stefan,
Thanks you! The gcc-4.8 patch was aging, so updating it is great.
Have you had a chance to build the or1k BSP and run ticker or hello on
or1ksim with those new patches?
Cheers,
Hesham
On Mon, Mar 21, 2016 at 2:50 AM, Stefan Wallentowitz
<stefan at wallentowitz.de> wrote:
> Bump the OpenRISC toolchain to newer versions.
> * Binutils to 2.26
> * GCC to 4.9.3
> * GDB to 7.9
> updates #2668
>  rtems/config/4.11/rtems-or1k.bset | 14 +++++++-------
>  1 file changed, 7 insertions(+), 7 deletions(-)
> diff --git a/rtems/config/4.11/rtems-or1k.bset b/rtems/config/4.11/rtems-or1k.bset
> index e600700..06ba931 100644
> --- a/rtems/config/4.11/rtems-or1k.bset
> +++ b/rtems/config/4.11/rtems-or1k.bset
> @@ -16,12 +16,12 @@
>  #gcc
> -%patch add gcc -p1 https://raw.githubusercontent.com/heshamelmatary/or1k-rtems/master/patches/gcc-4.8.3-or1k-rtems-29072014.diff
> -%hash  md5 gcc-4.8.3-or1k-rtems-29072014.diff 97be92fbe69a355625633a8d128fb5f5
> +%patch add gcc -p1 https://github.com/openrisc/or1k-gcc/releases/download/or1k-4.9.3-release/gcc-4.9.3-or1k.patch
> +%hash  md5 gcc-4.9.3-or1k.patch 83cddff103da7a2afc888b5ea6a78a0f
>  #gdb
> -%patch add gdb -p1 https://raw.githubusercontent.com/heshamelmatary/or1k-rtems/master/patches/gdb-7.7-or1k-rtems.diff
> -%hash  md5 gdb-7.7-or1k-rtems.diff 7565167e02652ff300dd31015499633e
> +%patch add gdb -p1 https://github.com/openrisc/binutils-gdb/releases/download/gdb-7.9.0-or1k-release/gdb-7.9.0-or1k.patch
> +%hash  md5 gdb-7.9.0-or1k.patch 0cae263fba62324cdd1f40125daca2c9
>  # or1k specific configurations
> @@ -37,7 +37,7 @@
>  4.11/rtems-autotools
>  devel/expat-2.1.0-1
> -tools/rtems-binutils-2.25-1
> -tools/rtems-gcc-4.8.3-newlib-2.2.0-20150423-1.cfg
> +tools/rtems-binutils-2.26-1
> +tools/rtems-gcc-4.9.3-newlib-2.2.0-20150423-1.cfg
>  tools/rtems-tools-4.11-1
> -tools/rtems-gdb-7.7-1
> +tools/rtems-gdb-7.9-1
> 2.1.4
> devel mailing list
> devel at rtems.org
Hesham
