4.11 Branch Failures
Mon Mar 21 06:29:55 UTC 2016
On 21/03/16 06:30, Chris Johns wrote:
> On 21/03/2016 14:40, Joel Sherrill wrote:
>>         (2) There is this group of powerpc BSPs failing on dl01:
>   [snip]
>>     No. If could be rtems-tld. What is the error?
>> mv dl01.pre.exe dl01.pre
>> rtems-syms -e -c "-mcpu=603e -mstrict-align -meabi -msdata=sysv
>> -fno-common -O2 -g -fno-keep-inline-functions -Wall -Wmissing-prototypes
>> -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs" -o
>> dl-sym.o dl01.pre
>> powerpc-rtems4.11-gcc -B../../../../../brs5l/lib/ -specs bsp_specs
>> -qrtems -mcpu=603e -mstrict-align -meabi -msdata=sysv -fno-common -O2 -g
>>   -mcpu=603e -mstrict-align -meabi -msdata=sysv -fno-common   \
>>              -o dl01.exe init.o dl-load.o dl-tar.o dl-sym.o
>> /home/joel/rtems-4.11-work/tools/4.11/lib/gcc/powerpc-rtems4.11/4.9.3/../../../../powerpc-rtems4.11/bin/ld:
>> dl-sym.o: the target (rtems__rtl_base_globals_size) of a R_PPC_SDAREL16
>> relocation is in the wrong output section (.text)
>> dl-sym.o: In function `rtems_rtl_base_global_syms_init':
>> rld--bTdaaa.c:(.text+0x6): relocation truncated to fit: R_PPC_SDAREL16
>> against `rtems__rtl_base_globals_size'
>> collect2: error: ld returned 1 exit status
>> Makefile:662: recipe for target 'dl01.exe' failed
> This means the rtems-syms tool needs to be taught how to create a
> suitable symbols file for the PowerPC. Sebastian are you able to have
> a look?
Its already fixed on the master.
https://git.rtems.org/rtems-tools/commit/?id=f027f37661fc8c12ab07f92982f0c86e4e0717de
 From my point of view we should not use branches for the RTEMS Tools
and RSB.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
