Participation in GSoC 2016
Deval Shah deval.maker at gmail.com
Tue Mar 22 12:52:10 UTC 2016
Hello,
I have updated my draft proposal and shared on the tracking page. I'm
sharing it here as well. https://goo.gl/QQiAf6
Sorry, I was busy with my Mid-Semester exams, could not update earlier.
Since this is a draft proposal, it may not be completely polished yet.
I'd appreciate any comments on it, especially regarding the project description
and timeline.
Thank you.
Regards,
Deval Shah
On Fri, Mar 11, 2016 at 11:02 PM, Deval Shah <deval.maker at gmail.com> wrote:
> On Fri, Mar 11, 2016 at 8:33 PM, Gedare Bloom <gedare at gwu.edu> wrote:
>> On Fri, Mar 11, 2016 at 8:19 AM, Deval Shah <deval.maker at gmail.com> wrote:
>>> Hello everyone!
>>> I went through the links and blogs of the SD card and USB/Ethernet
>>> project for Raspberry PI. I would like to work for the USB/Ethernet
>>> support project.
>>> I have prepared a draft of the timeline as follows:
>>> Acceptance Waiting Period:
>>> Understanding previous year's GSOC work
>>> First Half:
>>> completing USB support for RPI
>>> Testing USB and add drivers for HIDs like Mouse and Keyboard
>>> Second Half:
>>> Adding Ethernet Support
>>> Testing (ARP, PING, DHCP, FTP, TFTP)
>>> Adding support for lwIP (since it is already ported to BBB, this
>>> should not take more time)
>> Timeline seems good. Is the USB support available from freebsd for the
>> libbsd codebase?
> Yes. libbsd has support for USB.
> Last year issues were in porting the driver (
> http://gtament-rtems.blogspot.in/2015/06/my-progress-report.html ).
>>> If we have wifi support in RTEMS, can support of a USB wifi module be
>>> added to the project?
>> I haven't seen any one using wifi yet.
>>> I'd really appreciate any feedback on my deliverables, especially
>>> regarding the feasibility of doing it in this time frame. If there is
>>> anything I may have missed out or anything else I should consider as a
>>> part of this, I'd be really glad if someone could point that out, so
>>> as to increase my chances of selection.
>>> A quick question: How can I add my name to the tracking list @
>>> https://devel.rtems.org/wiki/GSoC/2016 ?
>> You need to register an account to edit the page through link at the bottom.
>> Okay, Thank you.
>>> Deval Shah
>>> On Tue, Mar 1, 2016 at 3:07 AM, André Marques
>>> <andre.lousa.marques at gmail.com> wrote:
>>>> Hello Jan and Deval,
>>>> Às 20:24 de 29-02-2016, Jan Sommer escreveu:
>>>>> Hi,
>>>>> If you take a look here:
>>>>> https://devel.rtems.org/wiki/GSoC/2015#StudentsSummerofCodeTrackingTable you
>>>>> can find the links to the reports and repositories of the previous GSoC.
>>>>> Yurii Shevtsov was doing the work on the Ethernet/USB part for the pi.
>>>>> Andre Marques worked on the SPI and SD-Card driver.
>>>> I have updated a bit the Raspberry Open Projects page with the state of the
>>>> low level peripherals project, and provided links to the state of each of
>>>> the other projects (the wiki pages of the students working on them last
>>>> year, which also include their blogs and githubs).
>>>> https://devel.rtems.org/wiki/Developer/Projects/Open/ImproveRaspberryPiBSP
>>>>  The other 3 raspberry projects I do not know exactly their current state,
>>>> but they already have some work done (just not in the RTEMS tree yet).
>>>> It seems that only GPIO, I2C and SPI were merged last year.
>>>>> Cheers,
>>>>>     Jan
>>>>> Am Tuesday 01 March 2016, 01:15:24 schrieb Deval Shah:
>>>>>> It looks like there are more useful things in pipeline before raspberry
>>>>>> pi
>>>>>> cam support.
>>>>>> Can anybody give me pointers/links to refer for porting ethernet support
>>>>>> and SD card support?
>>>> For the last year efforts on the SD card support you can refer to:
>>>> https://devel.rtems.org/wiki/GSoC/2015/RaspberryPi_peripherals_and_SD_card#SDcardsupport
>>>>>> On Thursday 18 February 2016, soja-lists at aries.uberspace.de <
>>>>>> soja-lists at aries.uberspace.de> wrote:
>>>>>>> Am 2016-02-18 01:26, schrieb Joel Sherrill:
>>>>>>>> On Feb 17, 2016 6:17 PM, "André Marques"
>>>>>>>> wrote:
>>>>>>>> Was i2c fully delivered for the new driver framework? I don't recall
>>>>>>>>> off-hand.
>>>>>>>>> Yes the i2c driver for the Pi uses the new (linux-based) i2c
>>>>>>>>> framework.
>>>>>>>> 10-bit addressing is untested because I had no compatible slave device.
>>>>>>>>> A detailed report of my last GSOC can be found here:
>>>>>>>>> SD card support was started but not completed last year, so it may be
>>>>>>>> included on a potential Raspberry project. I can help with that if
>>>>>>>> needed.
>>>>>>>> Andres.. Thanks for speaking up. Can you update the project page and
>>>>>>>> link
>>>>>>>> to your blog?
>>>>>>>> What else do you think needs find on the Pi and Pi2?
>>>>>>> Last year there was a GSoC to add ethernet support for the raspberry pi
>>>>>>> via rtems-libbsd, but I think it was never finished.
>>>>>>> Maybe that could be started again?
>>>>>>> I haven't researched it yet to know if it is feasible but I am curious
>>>>>>> if
>>>>>>>> the Arduino HW libraries have a clean porting layer which could provide
>>>>>>>> support for a lot of i2c devices. Is this a wikd goose chase or of
>>>>>>>> potential value?
>>>>>>> Sounds like an interesting idea, but isn't Arduino written in C++?
>>>>>>> Best regards,
>>>>>>>     Jan
>>>>>>>>> I very much look forward for any pointers on this.
>>>>>>>>>>> I am eager to work for RTEMS organization because I believe my skill
>>>>>>>>>>> set is best suited for this.
>>>>>>>>>>> Thanking you,
>>>>>>>>>>> Deval Shah
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> devel mailing list
>>>>>>>>>>> devel at rtems.org
>>>>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
>>>>>>>>> --André Marques
>>>>>>>>> devel mailing list
>>>>>>>>> devel at rtems.org
>>>>>>>> devel mailing list
>>>>>>>> devel at rtems.org
>>>>>>> devel mailing list
>>>>>>> devel at rtems.org
>>>>> devel mailing list
>>>>> devel at rtems.org
>>>> --André Marques
