[PATCH 00/14] Warning Removal
Joel Sherrill
joel at rtems.org
Tue Mar 22 14:40:28 UTC 2016
I have been building using the master for binutils, gdb,
newlib, and GCC. Between newlib and GCC in particular, we
have some new warnings. This set of small patches attempts
to resolve the warnings in an appropriate way.
Joel Sherrill (14):
cpuuse/cpuusagetop.c: Fix unused variable warning
libnetworking/sys/libkern.h: Disable non-POSIX prototype that is
actually unused
telnetd.c: Fix no prototype warning
sptests/Makefile.am: Enable sptls02
libmisc/monitor/mon-prmisc.c: Remove unused rtems_monitor_events_assoc
libmisc/shell/main_hexdump.c: Disable unused copyright string
sp13/task1.c: Remove warning
cpukit/rtems/src/*mp.c: Fix set but not used warning
erc32/*/erc32sonic.c: Fix warnings
mptests/*/*.c: Fix warnings
powerpc/shared/openpic/openpic.c: Ignore warnings for
__builtin_frame_address() usage
libmisc/shell/main_date.c: Define _XOPEN_SOURCE and _BSD_SOURCE to get
access to both APIs
shell/hexdump-conv.c: Disable sccsid to avoid unused warning
shell/hexdump-odsyntax.c: Add define of _GNU_SOURCE to avoid warnings
c/src/lib/libbsp/powerpc/shared/openpic/openpic.c | 5 ++
.../lib/libbsp/sparc/erc32/erc32sonic/erc32sonic.c | 16 +++----
cpukit/libmisc/cpuuse/cpuusagetop.c | 1 -
cpukit/libmisc/monitor/mon-prmisc.c | 36 ---------------
cpukit/libmisc/shell/hexdump-conv.c | 2 +
cpukit/libmisc/shell/hexdump-odsyntax.c | 3 ++
cpukit/libmisc/shell/main_date.c | 2 +
cpukit/libmisc/shell/main_hexdump.c | 2 +
cpukit/libnetworking/sys/libkern.h | 2 +
cpukit/rtems/src/eventmp.c | 5 +-
cpukit/rtems/src/msgmp.c | 2 +
cpukit/rtems/src/partmp.c | 2 +
cpukit/rtems/src/regionmp.c | 2 +
cpukit/rtems/src/semmp.c | 2 +
cpukit/rtems/src/taskmp.c | 2 +
cpukit/score/src/threadglobalconstruction.c | 3 ++
cpukit/telnetd/telnetd.c | 9 ++--
testsuites/mptests/mp05/task1.c | 2 +-
testsuites/mptests/mp06/task1.c | 2 +-
testsuites/mptests/mp07/task1.c | 2 +-
testsuites/mptests/mp14/init.c | 2 +-
testsuites/sptests/sp13/task1.c | 53 ++++++++++++++--------
22 files changed, 83 insertions(+), 74 deletions(-)
1.8.3.1
