[PATCH 1/2] score: Add RTEMS_UNREACHABLE
Tue Mar 22 14:49:26 UTC 2016
In case we reach the program point marked with RTEMS_UNREACHABLE(), then
the behaviour is undefined according to the GCC documentation. Maybe we
should add some stuff if RTEMS_DEBUG is defined.
On 22/03/16 07:25, Sebastian Huber wrote:
>   cpukit/score/include/rtems/score/basedefs.h | 9 +++++++++
>   1 file changed, 9 insertions(+)
> diff --git a/cpukit/score/include/rtems/score/basedefs.h b/cpukit/score/include/rtems/score/basedefs.h
> index facaed9..5d7f5b4 100644
> --- a/cpukit/score/include/rtems/score/basedefs.h
> +++ b/cpukit/score/include/rtems/score/basedefs.h
> @@ -191,6 +191,15 @@
>   /* Provided for backward compatibility */
>   #define RTEMS_COMPILER_PACKED_ATTRIBUTE RTEMS_PACKED
> + * @brief Tells the compiler that this program point is unreachable.
> +#if defined(__GNUC__)
> +  #define RTEMS_UNREACHABLE() __builtin_unreachable()
> +#else
> +#endif
>   #if __cplusplus >= 201103L
>     #define RTEMS_STATIC_ASSERT(cond, msg) \
>       static_assert(cond, # msg)
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
