[PATCH 2/2] score: Use constant for maximum count of CORE sema
Wed Mar 23 09:19:37 UTC 2016
 cpukit/libmisc/monitor/mon-sema.c              |  7 ++-----
 cpukit/posix/src/semaphorecreatesupp.c         |  1 -
 cpukit/rtems/src/semcreate.c                   |  1 -
 cpukit/score/include/rtems/score/coresem.h     | 13 -------------
 cpukit/score/include/rtems/score/coresemimpl.h |  4 +---
 cpukit/score/src/coresem.c                     |  3 ---
 cpukit/score/src/mpci.c                        |  1 -
 7 files changed, 3 insertions(+), 27 deletions(-)
diff --git a/cpukit/libmisc/monitor/mon-sema.c b/cpukit/libmisc/monitor/mon-sema.c
index f7e35ed..5add7cf 100644
--- a/cpukit/libmisc/monitor/mon-sema.c
+++ b/cpukit/libmisc/monitor/mon-sema.c
@@ -28,11 +28,8 @@ rtems_monitor_sema_canonical(
     if (_Attributes_Is_counting_semaphore(canonical_sema->attribute)) {
       /* we have a counting semaphore */
-      canonical_sema->cur_count  =
-	rtems_sema->Core_control.semaphore.count;
-      canonical_sema->max_count  =
-	rtems_sema->Core_control.semaphore.Attributes.maximum_count;
+      canonical_sema->cur_count  = rtems_sema->Core_control.semaphore.count;
+      canonical_sema->max_count  = UINT32_MAX;
     else {
       /* we have a binary semaphore (mutex) */
diff --git a/cpukit/posix/src/semaphorecreatesupp.c b/cpukit/posix/src/semaphorecreatesupp.c
index c527a9b..9a24e0a 100644
--- a/cpukit/posix/src/semaphorecreatesupp.c
+++ b/cpukit/posix/src/semaphorecreatesupp.c
@@ -95,7 +95,6 @@ int _POSIX_Semaphore_Create_support(
   _CORE_semaphore_Initialize(
     &the_semaphore->Semaphore,
     CORE_SEMAPHORE_DISCIPLINES_FIFO,
-    0xFFFFFFFF,
     value
diff --git a/cpukit/rtems/src/semcreate.c b/cpukit/rtems/src/semcreate.c
index c8111fd..d289546 100644
--- a/cpukit/rtems/src/semcreate.c
+++ b/cpukit/rtems/src/semcreate.c
@@ -153,7 +153,6 @@ rtems_status_code rtems_semaphore_create(
       &the_semaphore->Core_control.semaphore,
       semaphore_discipline,
-      0xFFFFFFFF,
       count
 #if defined(RTEMS_SMP)
diff --git a/cpukit/score/include/rtems/score/coresem.h b/cpukit/score/include/rtems/score/coresem.h
index 44e17c3..84fde0b 100644
--- a/cpukit/score/include/rtems/score/coresem.h
+++ b/cpukit/score/include/rtems/score/coresem.h
@@ -50,15 +50,6 @@ typedef enum {
 }   CORE_semaphore_Disciplines;
- *  The following defines the control block used to manage the
- *  attributes of each semaphore.
-typedef struct {
-  /** This element indicates the maximum count this semaphore may have. */
-  uint32_t                    maximum_count;
-}   CORE_semaphore_Attributes;
  *  The following defines the control block used to manage each
  *  counting semaphore.
@@ -73,10 +64,6 @@ typedef struct {
   const Thread_queue_Operations *operations;
-  /** This element is the set of attributes which define this instance's
-   *  behavior.
-  CORE_semaphore_Attributes   Attributes;
   /** This element contains the current count of this semaphore. */
   uint32_t                    count;
 }   CORE_semaphore_Control;
diff --git a/cpukit/score/include/rtems/score/coresemimpl.h b/cpukit/score/include/rtems/score/coresemimpl.h
index 365345a..c70e54f 100644
--- a/cpukit/score/include/rtems/score/coresemimpl.h
+++ b/cpukit/score/include/rtems/score/coresemimpl.h
@@ -87,13 +87,11 @@ typedef void ( *CORE_semaphore_API_mp_support_callout )(
  *  @param[in] the_semaphore is the semaphore to initialize
  *  @param[in] discipline the blocking discipline
- *  @param[in] maximum_count the maximum count
  *  @param[in] initial_value is the initial count of the semaphore
 void _CORE_semaphore_Initialize(
   CORE_semaphore_Control     *the_semaphore,
   CORE_semaphore_Disciplines  discipline,
-  uint32_t                    maximum_count,
   uint32_t                    initial_value
@@ -158,7 +156,7 @@ RTEMS_INLINE_ROUTINE CORE_semaphore_Status _CORE_semaphore_Surrender(
     _Thread_Dispatch_enable( _Per_CPU_Get() );
 #endif
   } else {
-    if ( the_semaphore->count < the_semaphore->Attributes.maximum_count )
+    if ( the_semaphore->count < UINT32_MAX )
       the_semaphore->count += 1;
     else
       status = CORE_SEMAPHORE_MAXIMUM_COUNT_EXCEEDED;
diff --git a/cpukit/score/src/coresem.c b/cpukit/score/src/coresem.c
index db2d47f..2bdd81c 100644
--- a/cpukit/score/src/coresem.c
+++ b/cpukit/score/src/coresem.c
@@ -23,12 +23,9 @@
-  the_semaphore->Attributes.maximum_count = maximum_count;
   the_semaphore->count = initial_value;
   _Thread_queue_Initialize( &the_semaphore->Wait_queue );
diff --git a/cpukit/score/src/mpci.c b/cpukit/score/src/mpci.c
index 8e93d74..132d3e5 100644
--- a/cpukit/score/src/mpci.c
+++ b/cpukit/score/src/mpci.c
@@ -120,7 +120,6 @@ static void _MPCI_Handler_initialization( void )
     &_MPCI_Semaphore,
-    0xffffffff,
     0                         /* initial_value */
1.8.4.5
