[PATCH 2/8] score: Fix CORE mutex RTEMS_MULTIPROCESSING
Thu Mar 24 14:57:41 UTC 2016
Make sure that the thread proxy is registered as the mutex owner.
 cpukit/score/src/coremutexsurrender.c | 11 +++--------
 1 file changed, 3 insertions(+), 8 deletions(-)
diff --git a/cpukit/score/src/coremutexsurrender.c b/cpukit/score/src/coremutexsurrender.c
index 744adc5..da21d4b 100644
--- a/cpukit/score/src/coremutexsurrender.c
+++ b/cpukit/score/src/coremutexsurrender.c
@@ -187,6 +187,9 @@ CORE_mutex_Status _CORE_mutex_Surrender(
     bool unblock;
+    the_mutex->holder     = the_thread;
+    the_mutex->nest_count = 1;
      * We must extract the thread now since this will restore its default
      * thread lock.  This is necessary to avoid a deadlock in the
@@ -205,9 +208,6 @@ CORE_mutex_Status _CORE_mutex_Surrender(
     if ( _Objects_Is_local_id( the_thread->Object.id ) )
 #endif
-      the_mutex->holder     = the_thread;
-      the_mutex->nest_count = 1;
       switch ( the_mutex->Attributes.discipline ) {
         case CORE_MUTEX_DISCIPLINES_FIFO:
         case CORE_MUTEX_DISCIPLINES_PRIORITY:
@@ -237,12 +237,7 @@ CORE_mutex_Status _CORE_mutex_Surrender(
 #if defined(RTEMS_MULTIPROCESSING)
     if ( !_Objects_Is_local_id( the_thread->Object.id ) ) {
-      the_mutex->holder     = NULL;
       ( *api_mutex_mp_support)( the_thread, id );
     _Thread_Dispatch_enable( _Per_CPU_Get() );
1.8.4.5
