[PATCH 7/8] bsp/motorola_powerpc: Add MPCI support for Qemu
Joel Sherrill
joel at rtems.org
Thu Mar 24 15:08:03 UTC 2016
Are there any instructions on how you run mptests on this BSP?
On Thu, Mar 24, 2016 at 9:57 AM, Sebastian Huber <
> .../libbsp/powerpc/motorola_powerpc/Makefile.am | 2 +
> .../libbsp/powerpc/motorola_powerpc/include/bsp.h | 8 +
> .../libbsp/powerpc/motorola_powerpc/shmsupp/mpci.c | 375
> c/src/lib/libbsp/powerpc/shared/startup/bspstart.c | 10 +-
> 4 files changed, 393 insertions(+), 2 deletions(-)
> create mode 100644
> c/src/lib/libbsp/powerpc/motorola_powerpc/shmsupp/mpci.c
> diff --git a/c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am
> b/c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am
> index e09820608..3576b75 100644
> --- a/c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am
> +++ b/c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am
> @@ -136,6 +136,8 @@ noinst_PROGRAMS += ne2000.rel
> ne2000_rel_SOURCES = ../../i386/pc386/ne2000/ne2000.c
> ne2000_rel_CPPFLAGS = $(AM_CPPFLAGS) $(ne2000_CPPFLAGS)
> ne2000_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
> +libbsp_a_SOURCES += shmsupp/mpci.c
> endif
Is this guarded by the proper conditional? It looks like it is inside a
networking enabled one.
> endif
> diff --git a/c/src/lib/libbsp/powerpc/motorola_powerpc/include/bsp.h
> b/c/src/lib/libbsp/powerpc/motorola_powerpc/include/bsp.h
> index 0439e87..b955d72 100644
> --- a/c/src/lib/libbsp/powerpc/motorola_powerpc/include/bsp.h
> +++ b/c/src/lib/libbsp/powerpc/motorola_powerpc/include/bsp.h
> @@ -242,6 +242,14 @@ void zero_bss(void);
> void VIA_isa_bridge_interrupts_setup(void);
> +#ifdef RTEMS_MULTIPROCESSING
> +extern rtems_mpci_table net_mpci_table;
> +#define CONFIGURE_MP_MPCI_TABLE_POINTER &net_mpci_table
> +#endif /* RTEMS_MULTIPROCESSING */
> #endif
Doesn't this imply that networking and MPCI must both be available? How is
this guaranteed?
> diff --git a/c/src/lib/libbsp/powerpc/shared/startup/bspstart.c
> b/c/src/lib/libbsp/powerpc/shared/startup/bspstart.c
> index 0f450fc..ca687ab 100644
> --- a/c/src/lib/libbsp/powerpc/shared/startup/bspstart.c
> +++ b/c/src/lib/libbsp/powerpc/shared/startup/bspstart.c
> @@ -87,13 +87,19 @@ unsigned int BSP_time_base_divisor;
> void BSP_panic(char *s)
> printk("%s PANIC %s\n",_RTEMS_version, s);
> - __asm__ __volatile ("sc");
> + while (true) {
> + /* Do nothing */
> void _BSP_Fatal_error(unsigned int v)
> printk("%s PANIC ERROR %x\n",_RTEMS_version, v);
> + while (true) {
> + /* Do nothing */
What actually changed here?
> 1.8.4.5
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160324/2cc8893a/attachment.html>
