GSOC 2016 Aspirant
Joel Sherrill
joel at rtems.org
Fri Mar 25 15:46:56 UTC 2016
Great! Remember today is the deadline to get the Google application in with
the PDF of your proposal. Do your best and we will work to fine tune it
assuming you meet the Google deadline.
Please update the table of students (you need a Trac/wiki account to do
this) and include a link to your proposal in Google docs.
The Pi2 should be an interesting project. Last year's student got stuck on
SMP support. That is important to get working so we have a cheap 4-core ARM
reference target,
--joel
On Fri, Mar 25, 2016 at 10:25 AM, Mudit Jain <muditjain18011995 at gmail.com>
wrote:
> PFA patch and a screen shot as a proof of having completed the environment
> setup.
> I have made an initial draft of the application. Will be updating the
> google portal and the site soon.
> Thanks
> Mudit
> On Fri, Mar 25, 2016 at 6:16 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> OK, that should be a good set for your proposal. I'm not sure what the
>> status is for Pi2 now. It may need some cleanup. Make sure you get
>> your final PDF and enrollment submitted today.
>> Please keep devel on any emails of non-private nature.
>> On Fri, Mar 25, 2016 at 8:33 AM, Mudit Jain <muditjain18011995 at gmail.com>
>> wrote:
>> > Hi Gedare,
>> > I have read the link that you have suggested and it has provided me a
>> good
>> > insight into the matter.
>> > I planned on implementing the support for Pi 2/B
>> > In addition to the SD file system support I also plan on adding DMA
>> support
>> > for I2C and SPI,
>> > support for second SPI device and model identification, detection and
>> > reporting.
>> > Thanks
>> > On Fri, Mar 25, 2016 at 5:23 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> >> For prior effort on SD card see
>> https://devel.rtems.org/wiki/GSoC/2015/RaspberryPi_peripherals_and_SD_card#SDcardsupport
>> >> There is another student that is planning to add USB/NIC support. You
>> >> would be best served to avoid too much overlap, but if you go for a
>> >> different RPi model that may not matter. What specific RPi board do
>> >> you plan to use?
>> >> I would guess SD card is only good for the first half of GSoC, so
>> >> you'll need to identify what else you could do. The other periperhals
>> >> (GPIO, i2c, SPI) support have been merged by Andre.
>> >> On Fri, Mar 25, 2016 at 6:01 AM, Mudit Jain <
>> >> wrote:
>> >> > Hi everyone,
>> >> > I am Mudit Jain, a final year undergraduate student in Electronics
>> and
>> >> > Communication Engineering at BITS Pilani Hyderabad Campus.
>> >> > I wish to apply for GSOC 2016, with RTEMS as the mentoring
>> organization.
>> >> > I have gone through your website for details regarding the
>> development
>> >> > process and the projects that could be done.
>> >> > I am interested in working on the project titled "Low Level
>> Peripherals
>> >> > and
>> >> > SD Card Support for Raspberry PI " [ Project group 1 - Improving
>> >> > Raspberry
>> >> > PI BSP ] under Alan Cudmore as the mentor.
>> >> > Given the limited time I have for the application process, I have
>> >> > parallelly
>> >> > started to set up the RTEMS environment and also write my proposal
>> for
>> >> > the
>> >> > project that I am interested in.
>> >> > I will be updating this email thread once I have set up the env.
>> >> > I understand that I am applying at the last moment, however I request
>> >> > you to
>> >> > consider my application.
>> >> > It would be great if people could suggest any good points that I
>> need to
>> >> > account for, in my application.
>> >> > Thanks
>> >> > Cheers
>> >> > Mudit Jain
>> >> > _______________________________________________
>> >> > devel mailing list
>> >> > devel at rtems.org
>> >> > http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160325/938f6a00/attachment.html>
