Potential GSoC Student
Karel Gardas karel.gardas at centrum.cz
Fri Mar 25 20:21:06 UTC 2016
Hi Habeeb,
Cortex-M4F is supported since it is used by several BSPs. Anyway, most
closest to TM4C129 is probably TM4C123 which is supported by lm4f120 BSP
which is a variant of lm3s69xx BSP. Search RTEMS source tree for more
information...
Cheers,
Karel
On 03/25/16 09:13 PM, Olufowobi, Habeeb wrote:
> Greetings,
> I am Habeeb Olufowobi, a graduate student of Systems and Computer
> Science at Howard University, Washington, D.C.
> I would like work to on porting RTEMS to ARM Cortex-M4F microcontroller
> (TI TM4C series Crypto Connected Launchpad
> http://www.ti.com/tool/EK-TM4C129EXL).
> I will like to know if the ARM Cortex-M4 CPU is currently supported and
> if a BSP for this board exist.
> I have a prepared draft proposal for this project on the following link.
> https://docs.google.com/document/d/1gbrlXe8_IAsQiZjkTby4_lHLzQYZkU3-lfRT9-5N33o/edit?usp=sharing
> Your feedbacks and suggestions for this project after reading the
> proposal will be greatly appreciated.
> Currently, I have built RTEMS and run the Hello world and the Ticker for
> the Sparc and ARM Xilinx-zynq and I hope to build on this knowledge for
> my project.
> Thanking you for your much-anticipated response and suggestion.
> Best regards,
> Habeeb
> devel mailing list
> devel at rtems.org
