[PATCH] score603e: Rename PCI.h to pciimpl.h to avoid name clash on case insensitive file systems
Mon Mar 28 21:09:16 UTC 2016
closes #2677.
 c/src/lib/libbsp/powerpc/score603e/Makefile.am     |  2 +-
 c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.h   | 42 ----------------------
 c/src/lib/libbsp/powerpc/score603e/PCI_bus/flash.c |  4 +--
 .../lib/libbsp/powerpc/score603e/PCI_bus/pciimpl.h | 42 ++++++++++++++++++++++
 .../libbsp/powerpc/score603e/PCI_bus/universe.c    |  2 +-
 c/src/lib/libbsp/powerpc/score603e/preinstall.am   |  6 ++--
 6 files changed, 49 insertions(+), 49 deletions(-)
 delete mode 100644 c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.h
 create mode 100644 c/src/lib/libbsp/powerpc/score603e/PCI_bus/pciimpl.h
diff --git a/c/src/lib/libbsp/powerpc/score603e/Makefile.am b/c/src/lib/libbsp/powerpc/score603e/Makefile.am
index 2e9eebb..07daafe 100644
--- a/c/src/lib/libbsp/powerpc/score603e/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/score603e/Makefile.am
@@ -32,7 +32,7 @@ console_SOURCES = console/85c30.c console/85c30.h console/console.c \
     console/tbl85c30.c console/consolebsp.h
 include_bsp_HEADERS = ../../powerpc/shared/pci/pci.h \
-	PCI_bus/PCI.h \
+	PCI_bus/pciimpl.h \
 	../../powerpc/shared/residual/residual.h \
 	../../powerpc/shared/residual/pnp.h \
 	../../powerpc/shared/console/consoleIo.h
diff --git a/c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.h b/c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.h
deleted file mode 100644
index 7b1526f..0000000
--- a/c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.h
+++ /dev/null
@@ -1,42 +0,0 @@
- *  @file
- *  This include file contains prototypes for chips attached to the
- *  PCI bus.
- *  COPYRIGHT (c) 1989-2009.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#ifndef __PCI_h
-#define __PCI_h
- * PCI.c
-void PCI_bus_write(
-  volatile uint32_t         * _addr,
-  uint32_t         _data
-uint32_t         PCI_bus_read(
-uint32_t         Read_pci_device_register(
-  uint32_t         address
-void  Write_pci_device_register(
-  uint32_t         address,
-  uint32_t         data
-#endif
diff --git a/c/src/lib/libbsp/powerpc/score603e/PCI_bus/flash.c b/c/src/lib/libbsp/powerpc/score603e/PCI_bus/flash.c
index a2e084a..a5f697b 100644
--- a/c/src/lib/libbsp/powerpc/score603e/PCI_bus/flash.c
+++ b/c/src/lib/libbsp/powerpc/score603e/PCI_bus/flash.c
@@ -1,5 +1,5 @@
+ *  COPYRIGHT (c) 1989-2009,2016.
@@ -14,7 +14,7 @@
 #include <bsp.h>
 #include <bsp/irq.h>
-#include "PCI.h"
+#include <bsp/pciimpl.h>
  *  SCORE603e_FLASH_Disable
diff --git a/c/src/lib/libbsp/powerpc/score603e/PCI_bus/pciimpl.h b/c/src/lib/libbsp/powerpc/score603e/PCI_bus/pciimpl.h
new file mode 100644
index 0000000..c0b21b4
--- /dev/null
+++ b/c/src/lib/libbsp/powerpc/score603e/PCI_bus/pciimpl.h
@@ -0,0 +1,42 @@
+ *  @file
+ *  This include file contains prototypes for chips attached to the
+ *  PCI bus.
+ *  COPYRIGHT (c) 1989-2009, 2016.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#ifndef __BSP_PCIimpl_h
+#define __BSP_PCIimpl_h
+ * PCI.c
+void PCI_bus_write(
+  volatile uint32_t * _addr,
+  uint32_t           _data
+uint32_t         PCI_bus_read(
+uint32_t         Read_pci_device_register(
+  uint32_t         address
+void  Write_pci_device_register(
+  uint32_t         address,
+  uint32_t         data
+#endif
diff --git a/c/src/lib/libbsp/powerpc/score603e/PCI_bus/universe.c b/c/src/lib/libbsp/powerpc/score603e/PCI_bus/universe.c
index c373aa6..8565236 100644
--- a/c/src/lib/libbsp/powerpc/score603e/PCI_bus/universe.c
+++ b/c/src/lib/libbsp/powerpc/score603e/PCI_bus/universe.c
@@ -14,7 +14,7 @@
 #include <rtems/bspIo.h>
 #include <bsp.h>
-#include "PCI.h"
 typedef struct {
   uint32_t         PCI_ID;                 /* 0x80030000 */
diff --git a/c/src/lib/libbsp/powerpc/score603e/preinstall.am b/c/src/lib/libbsp/powerpc/score603e/preinstall.am
index da25a43..042bb47 100644
--- a/c/src/lib/libbsp/powerpc/score603e/preinstall.am
+++ b/c/src/lib/libbsp/powerpc/score603e/preinstall.am
@@ -69,9 +69,9 @@ $(PROJECT_INCLUDE)/bsp/pci.h: ../../powerpc/shared/pci/pci.h $(PROJECT_INCLUDE)/
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/pci.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/pci.h
-$(PROJECT_INCLUDE)/bsp/PCI.h: PCI_bus/PCI.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/PCI.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/PCI.h
+$(PROJECT_INCLUDE)/bsp/pciimpl.h: PCI_bus/pciimpl.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/pciimpl.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/pciimpl.h
 $(PROJECT_INCLUDE)/bsp/residual.h: ../../powerpc/shared/residual/residual.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/residual.h
1.8.3.1
