[PATCH 2/2] confdefs.h hack
Tue Mar 29 11:51:29 UTC 2016
On 29/03/16 13:47, Sebastian Huber wrote:
> Not to be committed. How can we fix this?
I was able to run all MP tests except mp14 successfully using Qemu and a
virtual network. The TCP/IP based MPCI support is basically BSP
independent and should work for all BSPs that support a network
interface driver in the old network stack. So, maybe this MPCI driver
should move to libchip. I am not sure how we should address the
confdefs.h issue.
The mp14 test seems to use a global partition. Does this make sense in a
non-shared memory setup, e.g. message passing via TCP/IP?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
