[PATCH] [RSB] use updated newlib revision for or1k
Joel Sherrill
joel at rtems.org
Tue Mar 29 23:03:36 UTC 2016
I am OK with this if you want to push it.
I guess you saw that I plan/hope to bump the newlib and gcc versions
on all targets I can when the next newlib snapshot comes out.
--joel
On Tue, Mar 29, 2016 at 5:23 PM, Hesham Almatary <heshamelmatary at gmail.com>
wrote:
> rtems/config/4.12/rtems-or1k.bset | 2 +-
> rtems/config/tools/rtems-gcc-4.9.3-newlib-git-1.cfg | 13 +++++++++++++
> 2 files changed, 14 insertions(+), 1 deletion(-)
> create mode 100644 rtems/config/tools/rtems-gcc-4.9.3-newlib-git-1.cfg
> diff --git a/rtems/config/4.12/rtems-or1k.bset
> b/rtems/config/4.12/rtems-or1k.bset
> index 7d8baba..fe6a23d 100644
> --- a/rtems/config/4.12/rtems-or1k.bset
> +++ b/rtems/config/4.12/rtems-or1k.bset
> @@ -38,7 +38,7 @@
> 4.12/rtems-autotools
> devel/expat-2.1.0-1
> tools/rtems-binutils-2.26-1
> -tools/rtems-gcc-4.9.3-newlib-2.2.0-20150423-1.cfg
> +tools/rtems-gcc-4.9.3-newlib-git-1.cfg
> tools/rtems-tools-4.12-1
> tools/rtems-gdb-7.11-1
> diff --git a/rtems/config/tools/rtems-gcc-4.9.3-newlib-git-1.cfg
> b/rtems/config/tools/rtems-gcc-4.9.3-newlib-git-1.cfg
> new file mode 100644
> index 0000000..ad95302
> --- /dev/null
> +++ b/rtems/config/tools/rtems-gcc-4.9.3-newlib-git-1.cfg
> @@ -0,0 +1,13 @@
> +# GCC 4.9.3., Newlib GIT
> +%define gcc_version 4.9.3
> +%define newlib_version 8b1ede3ce11d53292036aadfcfb6043df0235f9c
> +%hash md5 gcc-%{gcc_version}.tar.bz2 6f831b4d251872736e8e9cc09746f327
> +# The gcc/newlib build instructions.
> +%include tools/rtems-gcc-4.9-newlib-git-1.cfg
> 2.8.0.rc3
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160329/aa8ce6fd/attachment-0001.html>
