[PATCH] [RSB] use updated newlib revision for or1k
Joel Sherrill
joel at rtems.org
Tue Mar 29 23:15:22 UTC 2016
On Tue, Mar 29, 2016 at 6:08 PM, Hesham Almatary <heshamelmatary at gmail.com>
wrote:
> Building RTEMS without this patch will fail with some nfs and rpc libs
> since newlib version is outdated (March 2015).
> Then this will fix one of the two repeating BSP build failures. :)
If you can fix the sh4 BSP, then another gets knocked off. lol
> On Wed, Mar 30, 2016 at 10:03 AM Joel Sherrill <joel at rtems.org> wrote:
>> I am OK with this if you want to push it.
>> I guess you saw that I plan/hope to bump the newlib and gcc versions
>> on all targets I can when the next newlib snapshot comes out.
>> --joel
>> On Tue, Mar 29, 2016 at 5:23 PM, Hesham Almatary <
>> heshamelmatary at gmail.com> wrote:
>>> rtems/config/4.12/rtems-or1k.bset | 2 +-
>>> rtems/config/tools/rtems-gcc-4.9.3-newlib-git-1.cfg | 13 +++++++++++++
>>> 2 files changed, 14 insertions(+), 1 deletion(-)
>>> create mode 100644 rtems/config/tools/rtems-gcc-4.9.3-newlib-git-1.cfg
>>> diff --git a/rtems/config/4.12/rtems-or1k.bset
>>> b/rtems/config/4.12/rtems-or1k.bset
>>> index 7d8baba..fe6a23d 100644
>>> --- a/rtems/config/4.12/rtems-or1k.bset
>>> +++ b/rtems/config/4.12/rtems-or1k.bset
>>> @@ -38,7 +38,7 @@
>>> 4.12/rtems-autotools
>>> devel/expat-2.1.0-1
>>> tools/rtems-binutils-2.26-1
>>> -tools/rtems-gcc-4.9.3-newlib-2.2.0-20150423-1.cfg
>>> +tools/rtems-gcc-4.9.3-newlib-git-1.cfg
>>> tools/rtems-tools-4.12-1
>>> tools/rtems-gdb-7.11-1
>>> diff --git a/rtems/config/tools/rtems-gcc-4.9.3-newlib-git-1.cfg
>>> b/rtems/config/tools/rtems-gcc-4.9.3-newlib-git-1.cfg
>>> new file mode 100644
>>> index 0000000..ad95302
>>> --- /dev/null
>>> +++ b/rtems/config/tools/rtems-gcc-4.9.3-newlib-git-1.cfg
>>> @@ -0,0 +1,13 @@
>>> +# GCC 4.9.3., Newlib GIT
>>> +%define gcc_version 4.9.3
>>> +%define newlib_version 8b1ede3ce11d53292036aadfcfb6043df0235f9c
>>> +%hash md5 gcc-%{gcc_version}.tar.bz2 6f831b4d251872736e8e9cc09746f327
>>> +# The gcc/newlib build instructions.
>>> +%include tools/rtems-gcc-4.9-newlib-git-1.cfg
>>> 2.8.0.rc3
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160329/3baec4b3/attachment.html>
