Bringing the Scheduling Simulator in synch with RTEMS master
Darshit Shah darnir at gmail.com
Wed Mar 30 14:03:18 UTC 2016
I've started trying to bring the scheduling simulator in synch with the
current RTEMS master. Joel has created Trac Ticket #2679 (
https://devel.rtems.org/ticket/2679) for this task.
While trying to get the simulator to compile, GCC spits out the following
error:
In file included from
/home/thedoctor/Programming/rtems/rtems/cpukit/score/include/rtems/score/threadq.h:25:0,
                 from
/home/thedoctor/Programming/rtems/rtems/cpukit/score/include/rtems/score/thread.h:35,
                 from
/home/thedoctor/Programming/rtems/rtems/cpukit/score/include/rtems/score/heap.h:22,
                 from
/home/thedoctor/Programming/rtems/rtems/cpukit/rtems/include/rtems/rtems/types.h:26,
                 from
/home/thedoctor/Programming/rtems/rtems/cpukit/rtems/include/rtems/rtems/config.h:24,
                 from
/home/thedoctor/Programming/rtems/rtems/cpukit/sapi/include/rtems/config.h:57,
                 from
../../../rtems-schedsim/schedsim/rtems/rtems_init.c:25:
/home/thedoctor/Programming/rtems/rtems/cpukit/score/include/rtems/score/rbtree.h:21:22:
fatal error: sys/tree.h: No such file or directory
Some scouting around reveals that the sys/tree.h header file is available
in Newlib. However, I am unable to find a way to point the compiler in that
direction for the scheduling simulator. Can someone please point me to the
right set of Automake directives I'd require for this?
Thanking You,
Darshit Shah
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160330/f357e878/attachment.html>
