[PATCH 1/8] score: Add CPU_MAXIMUM_PROCESSORS
Joel Sherrill
joel at rtems.org
Thu Mar 3 15:17:41 UTC 2016
On Thu, Mar 3, 2016 at 9:12 AM, Sebastian Huber <
> On 03/03/16 16:10, Joel Sherrill wrote:
>> How does this interact with the pthread affinity and cpuset size?
> Its unrelated to the high level API.
>> If we end up with a port that can support more than 32, then do we
>> increase the cpuset size or make applications more to variable cpuset's?
> No, the high level API is a different issue.
>> What's the intended use?
> The high level API cpu_set_t is to inefficient for internal use. Linux
> uses something similar internally.
So the affinity data structure internally is going to change?
This constant was added for some purpose. What is it?
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160303/acb4f9fd/attachment-0002.html>
