[PATCH 2/8] score: Add Processor_mask, etc.
Thu Mar 3 15:18:58 UTC 2016
OK. Makes sense based on what appears to be coming.
On Thu, Mar 3, 2016 at 8:47 AM, Sebastian Huber <
>  cpukit/score/Makefile.am                         |  1 +
>  cpukit/score/include/rtems/score/processormask.h | 90
>  cpukit/score/preinstall.am                       |  4 ++
>  3 files changed, 95 insertions(+)
>  create mode 100644 cpukit/score/include/rtems/score/processormask.h
> diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
> index 8506f22..3d3f1c1 100644
> --- a/cpukit/score/Makefile.am
> +++ b/cpukit/score/Makefile.am
> @@ -61,6 +61,7 @@ include_rtems_score_HEADERS +=
> include/rtems/score/priority.h
>  include_rtems_score_HEADERS += include/rtems/score/prioritybitmap.h
>  include_rtems_score_HEADERS += include/rtems/score/prioritybitmapimpl.h
>  include_rtems_score_HEADERS += include/rtems/score/profiling.h
> +include_rtems_score_HEADERS += include/rtems/score/processormask.h
>  include_rtems_score_HEADERS += include/rtems/score/rbtree.h
>  include_rtems_score_HEADERS += include/rtems/score/rbtreeimpl.h
>  include_rtems_score_HEADERS += include/rtems/score/resource.h
> diff --git a/cpukit/score/include/rtems/score/processormask.h
> b/cpukit/score/include/rtems/score/processormask.h
> new file mode 100644
> index 0000000..5a78dd3
> --- /dev/null
> +++ b/cpukit/score/include/rtems/score/processormask.h
> @@ -0,0 +1,90 @@
> + * @file
> + * @brief Processor Mask API
> + * @ingroup ScoreProcessorMask
> + * Copyright (c) 2016 embedded brains GmbH.  All rights reserved.
> + *  embedded brains GmbH
> + *  Dornierstr. 4
> + *  82178 Puchheim
> + *  Germany
> + *  <rtems at embedded-brains.de>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.org/license/LICENSE.
> +#ifndef _RTEMS_SCORE_PROCESSORMASK_H
> +#define _RTEMS_SCORE_PROCESSORMASK_H
> +#include <rtems/score/cpu.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif /* __cplusplus */
> + * @defgroup ScoreProcessorMask Processor Mask
> + * @ingroup Score
> + * The processor mask provides a bit map large enough to provide one bit
> for
> + * each processor in the system.  It is a fixed size internal data type
> + * provided for efficiency in addition to the API level cpu_set_t.
> +#define PROCESSOR_MASK_BITS_PER_FIELD 32
> +#define PROCESSOR_MASK_FIELD_COUNT \
> +  ( ( CPU_MAXIMUM_PROCESSORS + PROCESSOR_MASK_BITS_PER_FIELD - 1 ) \
> +    / PROCESSOR_MASK_BITS_PER_FIELD )
> +#define PROCESSOR_MASK_BIT( index ) \
> +  (1UL << ( ( index ) % PROCESSOR_MASK_BITS_PER_FIELD ) )
> +#define PROCESSOR_MASK_FIELD( index ) \
> +  ( ( index ) / PROCESSOR_MASK_BITS_PER_FIELD )
> + * @brief A bit map consisting of 32-bit integer fields which is large
> enough
> + * to provide one bit for each processor in the system.
> + * Processor 0 corresponds to the bit 0 (least-significant) of the field
> 0 in
> + * the array, and so on.
> +typedef uint32_t Processor_mask[ PROCESSOR_MASK_FIELD_COUNT ];
> +RTEMS_INLINE_ROUTINE void _Processor_mask_Set( Processor_mask mask,
> uint32_t index )
> +  mask[ PROCESSOR_MASK_FIELD( index ) ] |= PROCESSOR_MASK_BIT( index );
> +RTEMS_INLINE_ROUTINE void _Processor_mask_Clear( Processor_mask mask,
> uint32_t index )
> +  mask[ PROCESSOR_MASK_FIELD( index ) ] &= ~PROCESSOR_MASK_BIT( index );
> +RTEMS_INLINE_ROUTINE bool _Processor_mask_Is_set(
> +  const Processor_mask mask,
> +  uint32_t index
> +  return ( mask[ PROCESSOR_MASK_FIELD( index ) ]
> +    & PROCESSOR_MASK_BIT( index ) ) != 0;
> +#ifdef __cplusplus
> +#endif /* _RTEMS_SCORE_PROCESSORMASK_H */
> diff --git a/cpukit/score/preinstall.am b/cpukit/score/preinstall.am
> index 0d9cade..3a70bfa 100644
> --- a/cpukit/score/preinstall.am
> +++ b/cpukit/score/preinstall.am
> @@ -212,6 +212,10 @@ $(PROJECT_INCLUDE)/rtems/score/profiling.h:
> include/rtems/score/profiling.h $(PR
>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/profiling.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/profiling.h
> +$(PROJECT_INCLUDE)/rtems/score/processormask.h:
> $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/processormask.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/processormask.h
>  $(PROJECT_INCLUDE)/rtems/score/rbtree.h: include/rtems/score/rbtree.h
>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/rbtree.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/rbtree.h
> 1.8.4.5
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160303/d0f65ae2/attachment-0002.html>
