[PATCH 8/8] score: Replace watchdog handler implementation
    Sebastian Huber
    Fri Mar  4 06:25:01 UTC 2016
On 03/03/16 23:44, Joel Sherrill wrote:
>     > "be placed on Red-Black Trees for set management." copy-pasted
>     comment
>     > should be Chains?
>     Thanks, for spotting this.
>     > "watchdog is scheduled and a black node". ditto, black should be red
>     > for the second one.
>     Oh, yes.
>     > _Watchdog_Ticks_from_seconds(): why is ticks = seconds<<30 the right
>     > thing to do? Same for _Watchdog_Ticks_from_timespec(). I am missing
>     > some assumption here, I guess. It might improve readability to
>     provide
>     > a helper function for this.
>     Ok, sorry for the magic numbers.  2**30 == 1073741824 enough to
>     cope with 1e9 nanoseconds.  So, we have 2**34 seconds available,
>     leading to a year 2514 problem.
> That's pretty close to the 2^64 nanosecond limit as I recall. So
> reasonable but
> I suppose that should be very explicit somewhere in a comment.
> Funny, before there was a wiki, we had a FAQ document which had a
> section on
> date/time overflow issues. We probably need a section in the users
> manual with
> the current truth on this:
> https://docs.rtems.org/releases/rtemsdocs-4.6.4/share/rtems/html/FAQ/FAQ00100.html
> We have multiple date/time and interval representations in the score,
> classic and
> POSIX APIs. It would be good to capture them again.
Yes, this is on my TODO list along with the year 2038 problem.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
