Should rtems_error() use fprintf()?
Peter Dufault dufault at hda.com
Wed Mar 16 19:41:04 UTC 2016
I’m answering only by looking at this email and not hunting through the source.  But if “rtems_error()” can easily be replaced by either "fprintf(stderr, …)" or "printk()" then deprecate it with that recommendation.  I’ve often had spirited discussions with clients because I think "fprintf(stderr, …)" needs to be supported cleanly in an embedded environment (as early as possible, and in as many environments as possible, leaving an escape hatch for a “printk()” in an ISR etc), since if the customer can’t use “fprintf(stderr, …)" they can’t use libraries easily.  The customer usually specifies a special “my_error_prinft(...)" that they want to use instead of “fprintf(stderr, …)”, and if that’s what “rtems_error()” is then deprecate it.
> On Mar 16, 2016, at 15:27 , Joel Sherrill <joel at rtems.org> wrote:
> Hi
> I know this is a very old piece of code and predates printk() but should
> this routine be changed to use printk()?
> Is it still safe? Especially in light of SMP demands.
> --joel
> devel mailing list
> devel at rtems.org
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
This email, like most email, is delivered unencrypted via internet email protocols subject to interception and tampering.  Contact HDA to discuss methods we can use that ensure secure communication.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160316/8cddfd08/attachment-0002.html>
