[PATCH] Bump OpenRISC versions
Joel Sherrill
joel at rtems.org
Sun Mar 20 15:04:27 UTC 2016
Chris.. this is a 4.11 patch so I think you should approve/merge it.
I don't want to push onto 4.11. Plus it should really have a ticket.
Stefan... I am in the middle of testing new tools on 4.12 and Chris
is trying to get the 4.11 branch wrapped up for a release. Would
you might submitting a second patch to update or1k on the master?
I think those tool versions are ok but the rest of the targets are
at least on a newer gdb.
On Sun, Mar 20, 2016 at 5:27 AM, Stefan Wallentowitz <stefan at wallentowitz.de
> wrote:
> Bump the OpenRISC toolchain to newer versions.
> * Binutils to 2.26
> * GCC to 4.9.3
> * GDB to 7.9
> rtems/config/4.11/rtems-or1k.bset | 14 +++++++-------
> 1 file changed, 7 insertions(+), 7 deletions(-)
> diff --git a/rtems/config/4.11/rtems-or1k.bset
> b/rtems/config/4.11/rtems-or1k.bset
> index e600700..06ba931 100644
> --- a/rtems/config/4.11/rtems-or1k.bset
> +++ b/rtems/config/4.11/rtems-or1k.bset
> @@ -16,12 +16,12 @@
> #gcc
> -%patch add gcc -p1
> https://raw.githubusercontent.com/heshamelmatary/or1k-rtems/master/patches/gcc-4.8.3-or1k-rtems-29072014.diff
> -%hash md5 gcc-4.8.3-or1k-rtems-29072014.diff
> 97be92fbe69a355625633a8d128fb5f5
> +%patch add gcc -p1
> https://github.com/openrisc/or1k-gcc/releases/download/or1k-4.9.3-release/gcc-4.9.3-or1k.patch
> +%hash md5 gcc-4.9.3-or1k.patch 83cddff103da7a2afc888b5ea6a78a0f
> #gdb
> -%patch add gdb -p1
> https://raw.githubusercontent.com/heshamelmatary/or1k-rtems/master/patches/gdb-7.7-or1k-rtems.diff
> -%hash md5 gdb-7.7-or1k-rtems.diff 7565167e02652ff300dd31015499633e
> +%patch add gdb -p1
> https://github.com/openrisc/binutils-gdb/releases/download/gdb-7.9.0-or1k-release/gdb-7.9.0-or1k.patch
> +%hash md5 gdb-7.9.0-or1k.patch 0cae263fba62324cdd1f40125daca2c9
> # or1k specific configurations
> @@ -37,7 +37,7 @@
> 4.11/rtems-autotools
> devel/expat-2.1.0-1
> -tools/rtems-binutils-2.25-1
> -tools/rtems-gcc-4.8.3-newlib-2.2.0-20150423-1.cfg
> +tools/rtems-binutils-2.26-1
> +tools/rtems-gcc-4.9.3-newlib-2.2.0-20150423-1.cfg
> tools/rtems-tools-4.11-1
> -tools/rtems-gdb-7.7-1
> +tools/rtems-gdb-7.9-1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160320/683c29f5/attachment-0002.html>
