4.11 Branch Failures
Joel Sherrill
joel at rtems.org
Mon Mar 21 03:40:45 UTC 2016
On Sun, Mar 20, 2016 at 9:31 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 21/03/2016 13:24, Joel Sherrill wrote:
>> My 4.11 build sweep
> Thanks for doing this.
> isn't finished yet but there are a couple of things to report:
> Is this rc3 or the 4.11 branch in git?
4.11 on git.
>> (1) The moxie tools failed to build.
> Please raise a ticket.
I will in the morning.
> (2) There is this group of powerpc BSPs failing on dl01:
>> $ grep "dl01.exe.*failed" log/*
>> log/powerpc-brs5l.log:Makefile:662: recipe for target 'dl01.exe' failed
>> log/powerpc-brs6l.log:Makefile:662: recipe for target 'dl01.exe' failed
>> log/powerpc-br_uid.log:Makefile:662: recipe for target 'dl01.exe' failed
>> log/powerpc-dp2.log:Makefile:662: recipe for target 'dl01.exe' failed
>> log/powerpc-hsc_cm01.log:Makefile:662: recipe for target 'dl01.exe' failed
>> log/powerpc-icecube.log:Makefile:662: recipe for target 'dl01.exe' failed
>> log/powerpc-mbx821_001.log:Makefile:662: recipe for target 'dl01.exe'
>> failed
>> log/powerpc-mbx821_002b.log:Makefile:662: recipe for target 'dl01.exe'
>> failed
>> log/powerpc-mbx821_002.log:Makefile:662: recipe for target 'dl01.exe'
>> failed
>> log/powerpc-mbx860_001b.log:Makefile:662: recipe for target 'dl01.exe'
>> failed
>> log/powerpc-mbx860_002.log:Makefile:662: recipe for target 'dl01.exe'
>> failed
>> log/powerpc-mbx860_005b.log:Makefile:662: recipe for target 'dl01.exe'
>> failed
>> log/powerpc-mbx860_1b.log:Makefile:662: recipe for target 'dl01.exe'
>> failed
>> log/powerpc-mpc8260ads.log:Makefile:662: recipe for target 'dl01.exe'
>> failed
>> log/powerpc-mpc8309som.log:Makefile:662: recipe for target 'dl01.exe'
>> failed
>> log/powerpc-mpc8313erdb.log:Makefile:662: recipe for target 'dl01.exe'
>> failed
>> log/powerpc-mpc8349eamds.log:Makefile:662: recipe for target 'dl01.exe'
>> failed
>> log/powerpc-pghplus.log:Makefile:662: recipe for target 'dl01.exe' failed
>> log/powerpc-pm520_cr825.log:Makefile:662: recipe for target 'dl01.exe'
>> failed
>> log/powerpc-pm520_ze30.log:Makefile:662: recipe for target 'dl01.exe'
>> failed
>> log/powerpc-psim.log:Makefile:662: recipe for target 'dl01.exe' failed
>> log/powerpc-t32mppc.log:Makefile:662: recipe for target 'dl01.exe' failed
>> log/powerpc-tqm8xx_stk8xx.log:Makefile:662: recipe for target 'dl01.exe'
>> failed
>> log/powerpc-virtex.log:Makefile:662: recipe for target 'dl01.exe' failed
>> Do we update the *.tcfg for these?
> No. If could be rtems-tld. What is the error?
> mv dl01.pre.exe dl01.pre
rtems-syms -e -c "-mcpu=603e -mstrict-align -meabi -msdata=sysv -fno-common
-O2 -g -fno-keep-inline-functions -Wall -Wmissing-prototypes
-Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs" -o
dl-sym.o dl01.pre
powerpc-rtems4.11-gcc -B../../../../../brs5l/lib/ -specs bsp_specs -qrtems
-mcpu=603e -mstrict-align -meabi -msdata=sysv -fno-common -O2 -g
-mcpu=603e -mstrict-align -meabi -msdata=sysv -fno-common \
-o dl01.exe init.o dl-load.o dl-tar.o dl-sym.o
/home/joel/rtems-4.11-work/tools/4.11/lib/gcc/powerpc-rtems4.11/4.9.3/../../../../powerpc-rtems4.11/bin/ld:
dl-sym.o: the target (rtems__rtl_base_globals_size) of a R_PPC_SDAREL16
relocation is in the wrong output section (.text)
dl-sym.o: In function `rtems_rtl_base_global_syms_init':
rld--bTdaaa.c:(.text+0x6): relocation truncated to fit: R_PPC_SDAREL16
against `rtems__rtl_base_globals_size'
collect2: error: ld returned 1 exit status
Looks to be the same on all the BSPs I listed.
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160320/739770ae/attachment-0002.html>
