[PATCH 1/2] score: Add RTEMS_UNREACHABLE
Tue Mar 22 14:55:33 UTC 2016
On Tue, Mar 22, 2016 at 9:49 AM, Sebastian Huber <
> In case we reach the program point marked with RTEMS_UNREACHABLE(), then
> the behaviour is undefined according to the GCC documentation. Maybe we
> should add some stuff if RTEMS_DEBUG is defined.
> That seems reasonable. It is unlikely that we get there but if we do, you
really want to know.
The newlib patch for pthread_exit() should have hit their list.
> On 22/03/16 07:25, Sebastian Huber wrote:
>>   cpukit/score/include/rtems/score/basedefs.h | 9 +++++++++
>>   1 file changed, 9 insertions(+)
>> diff --git a/cpukit/score/include/rtems/score/basedefs.h
>> b/cpukit/score/include/rtems/score/basedefs.h
>> index facaed9..5d7f5b4 100644
>> --- a/cpukit/score/include/rtems/score/basedefs.h
>> +++ b/cpukit/score/include/rtems/score/basedefs.h
>> @@ -191,6 +191,15 @@
>>   /* Provided for backward compatibility */
>>   #define RTEMS_COMPILER_PACKED_ATTRIBUTE RTEMS_PACKED
>> + * @brief Tells the compiler that this program point is unreachable.
>> +#if defined(__GNUC__)
>> +  #define RTEMS_UNREACHABLE() __builtin_unreachable()
>> +#else
>> +#endif
>>   #if __cplusplus >= 201103L
>>     #define RTEMS_STATIC_ASSERT(cond, msg) \
>>       static_assert(cond, # msg)
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160322/d6a87926/attachment-0002.html>
